Question about KitchenAid Microwave Ovens
Spontaneous fan on/off
Fan goes on and off at will...otherwise perfectly functioning built-in ovens. Any ideas?
    Master:
  • 479 Answers
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Posted on Dec 11, 2008
I have a Maytag Microwave/Hood MMV4203DS00. Twenty minutes after its last use as a microwave oven, the Vent Fan spontaneously went on and the Display Shows: VENT...FAN..--5E-- (or SE?). The microwave...
"SE" error means you have a shorted membrane keypad.
On this model, the membrane keypad is not available as a separate part, so the control panel frame assembly (which comes with a new keypad) would have to be ordered and replaced.
It's actually a pretty simple DIY repair.
The frame assembly is part number W10258190 and you can get it for $67.98 (subject to change) from the Pros here. You can also order the thermostat (part number WB27X10567 ) from them.
Their is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad as per the photo below.
Some connectors on the relays have a lock:
positivelock.jpg Then move your circuit board into the new frame. Be careful, the display is made of glass.
Sep 01, 2013 | Microwave Ovens
The exhaust fan does not come on despite the control panel saying otherwise...all other functions seem to be working...when I do run the oven I do not hear the fan running then too...
It is vital that this problem get fixed, the fan cools the magnetron "heats food" so it won't overheat and burn out. The cause could be an open winding in the motor, or there is no power getting to the fan, I recommend an appliance repair man to get to the root of the problem.
Jan 23, 2011 | Microwave Ovens
I have a Whirlpool MH7130XEQ-1 microwave. Sometimes it doesn't start. Sometimes the timer works, but nothing else happens. Sometimes it works perfectly. What could be the problem. Other times the fan...
hello,
what this means is partial contact problem from the internal wire from the power supply.
however, what you need to do tofix up your oven back to live i to unscrew your your oven from the luck key (stroll) and then trace down the wire to the element i.e heat provider and the fan to see which wire has gone wrong .
please before you can carry out this function you will have to disconnect any form of power supply on the oven.
thank you and thanks for using fixya.
Jun 01, 2010 | Whirlpool MH7130XE Microwave Oven
Whirlpool microwave fan spontaneously came on
some of these unit detect heat from the stove while cooking.there are designed to turn the exhaust fan on until the temprature gets cooler to prevent any interior damage.
there also could be a problem with your microwave circuit board.
check with whirlpool and see if there is any recalled notices for you microwave
Jan 30, 2010 | Whirlpool MH7130XE Microwave Oven
The fan on our Kenmore microwave oven is not working.
My husband took the unit off the wall looked down into the fan and found a dead mouse keeping the fan from spinning. We removed the dead mouse cleaned up the area. Turned on the oven. The fan worked perfectly. Then he rehung the microwave.
Thanks!
Aug 18, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Kitchenaide Microwave KHMS145KSS rattling noise
there is a possibility that sme of the wireing or the fan has become loose best checking it .
Jan 01, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My built-in KitchenAid microwave/convection oven/oven fan comes on and goes off spontaneously. I have to turn it off at the breaker. Otherwisel, both micro/convection and the lower oven are functioning...
I have the same problem
any hints to solve it.
It's a 1988 vintage oven/microwave so I can't complain but it 's a pain if
I have to replace the unit
Dec 11, 2008 | Microwave Ovens
Kenmore 665 68610891- built-in 1998 model
Fan relay on circuit board stuck. Give it a tap (the relay), to free it up. Otherwise get the relay or driver transistor replaced. Easy fix. Take it to an electronic repair place, not the brand agent.(They,ll just replace the whole board).If this Item is under warranty you should not be wasting my time.:::Spiceweasel.au
Mar 30, 2008 | Kenmore 80809 Microwave Oven
Microwave Ovens Logo
129 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
