Compaq Presario CQ 20 start up problem
Hi^^ thanks for the response.. thank you :)
yeah.. i m having problem with both ac power and the battery -
i disconnected my Presario with it, hold the start up button for 30 seconds, then tried both ac power and battery seperately
and both wont work -
perhaps you might know what's the problem and how i can fix it?
thanks once again :)
  • 81 Answers
The sound you hear is the hard drive starting, and after a few seconds stop because there is no communication with the main board.
Most likely, your main board is dead, if it was a minor problem, you should hear some beeps (indicating the problem).
You are going to have to take to a repair shop to test it.
Good luck
Posted on Dec 12, 2008
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
Battery cq 40 not charging
replace new battery, or...try to install new windows
Sep 08, 2012 | HP Compaq Presario CQ40-330TU
Serial number not found hp compaq presario
I HAVE A LAPTOP OF COMPAQ MODEL NO . PRESARIO CQ 61. WHEN I START IT IT DISPLAY "SERIAL NO NOT FOUND" ON BOOT SCREE. AND IT BECOME HANG.PLEASE HELP ME SOLVE THIS PROBLEM.
THANK YOU
Feb 10, 2012 | Compaq Presario CQ61-310US Laptop
Hello my laptop will power on but nothing but a black screen
Hi map_507,
Your system might have a display issue. Please try to power drain the computer to check if you can still bring back the default setting of the bios. During the process it will remove the existing power inside the system.
How to perform Power drain:
1. First turn off the computer.
2. Remove the battery from the computer and disconnect the AC adapter.
3. Now press and hold down the power button for 15-20 seconds.
4. Insert the battery back in and connect the AC adapter.
5. Just allow the computer to boot up.
Hope it helps.
Thank you for using FixYa.
Feb 12, 2011 | HP Compaq Presario F756NR Notebook
How do i hard reset compaq presario cq 62
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
hope it helps...
Nov 13, 2010 | Compaq Presario PCCOM2232US Notebook
My Touch pad mouse doesn'e work
hi. if its a physical problem, try using a eraser with it and then clean the thing with the eraser. i do it on my my laptop and it works for me. so yeah.
May 20, 2009 | Compaq Computers & Internet
Problem with power, plugged in, not charging
For just such occasions, I recommend that everyone have a low-cost multimeter at home. They are versatile and give you the features for measuring AC/DC voltage (which is what you need), resistance and a few current ranges.  They cost less than $20 US at Radio Shack or auto parts stores or if near a Harbor Freight Tool store, underr $10 US.
You need to verify if you have any voltage from your adapter/charger and whether the battery pack is still intact (they have thermal fuses inside).
The meters come with an adequate Chinglish basic instruction sheet and leads and battery.
Apr 01, 2009 | Compaq Presario CQ60-220US PC Laptop
Compaq Presario V2000 battery
if the computer will turn on with it plugged into ac power than it is most likely the battery. batteries on these machines are cheap. Mine died after a year
Jan 18, 2009 | HP Compaq Presario V2000 Notebook
Laptop wont start ... ( Presario 700 )
chk your ac adapter bro .. i think its not working
Aug 27, 2008 | Compaq Presario 700 470024-192 Notebook
Does not power on
First try removing the battery.
Try to power on again, if not mail me.
Erik.
May 13, 2008 | Compaq Presario M2000 Notebook
Computers & Internet Logo
110 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
