Question about Ricoh Aficio 1035 Copier
Networking at Ricoh 1035
Where can I find a Technical Manual for a ricoh 1035 ??
Found the users manual - but no Technical Manual.
Need instructions on connecting a Ricoh 1035 to a router and sharing it with multiple computers connected to the same router. All the computers are running Windows Vista.
I've done this with hundreds of printers.
It's been 4 years since I've dealt with a networked copier.
Any suggestions ??
Thanks,
Guy A.
GuyA@cox.net
    Problem Solver:
  • 9 Answers
Does your 1035 have either a printer or printer /scanner option. If it does just hook s line up to the network connector on the back of the controller. hit user tools, system settings, interface settings, network settings and then select auto obtain. now exit from the user tools to the regular screen. wait about ten seconds to let the settings take effect. Now hit user tools , printer features, lists and hit configuration page. Take this page to the computers with you. Go to start, add a printer add a local printer, deselect auto detect, hit next. Now hit add port select tcp/ip from drop down button. in location where is it says printer name or ip address enter the printer name located on the bottom right section of the configuration page you printed. now go to ricohs website www.ricoh.com, americas, then at the top you will see downloads. then a screen will apper that says drivers and manuals. select black and white, 1035 and windows vista. create a folder on your desktop called printer. once in the folder, open it double click and unzip it into the same folder.now back to page after you have typed in the printer name and hit next. go to have disc, browse to the folder on the desktop and follow the prompts form set up, drivers, vista, pcl 5, english and the select if this is your default printer, do not select sharing and ask it to print a test page. once this has printed go to the properties tab on the drive itself and select accessories. and add whatever options your copier has ie. sorter, duplex or extra paper drawers. Now do this to all your copiers on the network. doing this allows you to print from any computer regardless if any other computer goes down
Posted on Dec 16, 2008
How to find out where to read meter on my ricoh aficio 1035 copier machine
Ricoh Aficio 1035 have two meter those are the electronic counter and the magnetic counter type but they are program to synchronize. to look for the magnetic counter just open the front door and you will find it at the middle and to open the electronic counter just press the user tools/counter key located on the upper left side of your operation counter then press the counter on the LCD display. Hope this helps, thanks for using Fixya
May 03, 2011 | Ricoh Aficio 1035 Copier
Sc690 for ricoh 1035
That is not an easy task...
From what the manual says you have a BICU defective. Looks like a bad connection or somethings.
I advise you to call your provider. I think there is nothing you can do
Mar 05, 2011 | Ricoh Aficio 1035 Copier
How to convert ricoh aficio 1027 from german to english?
User manuals are available in pdf from ricoh-usa.com
Nov 25, 2009 | Ricoh Aficio 1035 Copier
Password for User Tools
Go to www.savin.com (I used savin because the 1035 is the same as a 2535 or B003), go to downloads, select manuals, select B/W Digital and 2535/2545, select the System Settings manual, download it and on page 48 it tells you how to lock out the Key Operator settings.
Jul 28, 2009 | Ricoh Aficio 1035 Copier
I have just purchased a 2nd hand Ricoh copier model 2022 and there was no manual. Would you happen to know of a web site I can download the manual. Many Thanks Warren
please download manual from below link :-
http://www.devicemanuals.com/guide/Copier/Ricoh/Ricoh-Copier-Wide-Format-FW770-User%27s-Guide-TXpBNU5EUT.html
or
http://safemanuals.com/user-guide-instructions-owner-manual/RICOH/AFICIO%202022-_E
Thanks
veeru
May 09, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Connecting ricoh 1035 to pc
connect your copier to a switch or router.
Goto user tools/counter. Select interface settings. Enter the IP address of the copier, enter the gateway address to the router. Press file transfer. Turn the deliver server on. It will take a few seconds but it should populate the IP address to the computer that desktop binder is installed to and insert the users assigned to the scanner program.
Sep 02, 2008 | Ricoh Aficio 1035 Copier
How to connect ricoh 1035
First, check on the left side of the machine to see if it has either a USB or RJ-45 receptical to plug your computer into. If not, the machine lacks the hardware needed to print from your computer. A Ricoh technician must install it at extra cost. If you DO have either of these recepticals, go to:www.ricoh-usa.com/downloads, to download the manual and drivers you need.
Ricoh Aficio 1035 Copier Logo
393 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
