Question about LG RC797T
DVD receiver lg rc68223 not working properly
My lg rc68223 dvd receiver is not working properly. eg. sometimes he accept a dvd - sometimes not. Even his own produced dvd. On other dvd player this "problem" dvd are working without problems. Often the notice "unknown disk ... " is shown on the screen.
SOURCE: Recording problem with LG RH266 Recorder..
Just bought unit. Had same problem.Tried lots of different types of disks with no luck. Tried to play already written +R disk. Worked OK. Then took out and replaced with blank -R. Came up with new screen asking me if I wanted to initialize disk. Answered yes and it took about 20 seconds. Then tried to DUB from HDD to DVD again. This time it came up with the dubbing menu, I hadn't seen before, and worked.
Hardly ideal, but the trick was to get it to recognise it as a blank and initialize. Currently burning my first disk. Didnt realise about 'FAST' mode, so taking ages.
Posted on Apr 19, 2008
SOURCE: LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Posted on Jun 05, 2008
Shuttle83
  • 1139 Answers
SOURCE: LG DVD RECEIVER LH T-9654
Hello shelby4844,
Is the front panel coming on? I ask because if it is not this is indicating possible power supply failure. In this case the switching power supply might be having a problem. I would suggest that you have someone who is skilled in electronics work on this problem for you since the power supply delivers current and voltage that could be hazardous to your health. Now that being said, this problem could be cause by a blown fuse, first unplug the DVD player, open it up, and find the fuse. The fuse will look like two metal caps separated by a glass or ceramic housing containing a strand of wire. Once you find this fuse. Take it out and measure it with an ohmmeter, the fuse should read 0 ohms (dead short from one cap to the other.  If the fuse is not bad then one of the other components may be bad, at this point, the testing should be done by someone who is skilled in electronics.
I hope this help,
Thank you,
Shuttle83
Posted on Jul 23, 2008
SOURCE: My LG LRH-880 HDD/DVD recorder
Somehow, my HDD/DVD recorder recorded correctly 2 times last night, even if I did not do anything specific to fix. I will keep an eye on new occurences of this problem, but it appears at the moment that the issue disappeared by itself.
Posted on Sep 14, 2008
SOURCE: LG RC797T Won't read disks
I had this problem last year. It had to be sent back to the company to replace the entire dvd unit; however, I found that it probably had been caused by electrical surges. Once I got it back after repair (replacement) I put the best possible surge protector I could buy on it and have not had a problem with that issue again. The idea of a surge problem came about because I blew 3 Onkyo stereos while still in warranty several years ago and they did the same thing- would not read discs, would say no disc, etc. & the protector ended the problem.
Posted on Dec 23, 2008
Remote Code with Onkyo Receiver
I'm not familiar with this specific model or remote, but in general, after correctly adding a code, you get two flashes to confirm the code was correctly entered. One flash means the code was not correctly accepted or available. If it's an older universal remote, it may not support that specific code for a newer device. Also codes are specific to the device, so make sure you are hitting the correct device key....eg: DVD, hold set up until two flashes, punch in the correct code, and you should get two flashes. Others are hold setup, two flashes, then DVD, then the code, etc. If it's a 3 digit code and your device requires four digits, add a zero first. 0123 rather than 123. I've had very good luck with the One For All remotes.
Jan 01, 2014 | LG Bp325 3D Slim Smart BRay Player - Black
My sony dvd oplayer/recorder only sometimes accepts the dvd-rw discs without displaying disc error
That is odd, the only other option is buy a DVD cleaning kit and follow the instructions it might solve your problem.
Mar 07, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
My TV has the built in DVD. When I try yo use it I"m receiving the message NO SIGNAL. However the TV is working with th cable box.
Do you have to choose the tv signal on the remote??
E.G. press tv choice, choose HD, Component, Digital......one maybe DVD.
Jan 24, 2011 | LG 32LG30 32 in. LCD HDTV
When i load a DVD in the system it is telling that there is no disk it is not reading the disk
if u r sure about properly working of software & os ,u must check internal hardwares of it,like lens motor & its lever.even,sometimes by an easy cleaning of the lens,u can solve thisproblem
May 16, 2010 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
(LG GSA H42N) IS NOT DETECTING ANY DISC
if u r sure about properly working of software & os ,u must check internal hardwares of it,like lens motor & its lever.even,sometimes by an easy cleaning of the lens,u can solve thisproblem...
May 16, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
The cd is detected but the dvd can not even when i tried checking on its dvd properties, there's no sign of a blank cd available. what should i do with this?
If you are trying to use built in Windows XP burning software, this will not work with DVDs. You need some third party burning software, eg Nero to get that functionality.
Oct 15, 2009 | LG Computers & Internet
It doesn't accept any of my dvd's anymore
i have the same problem it seems that you need a good repair man to mend it even lg cant do it
Oct 06, 2009 | LG DR275 Recorder
MY LG DVD WRITER IS NOT ACCEPTING DVD DISK BUT IS ACCEPTING CD DISK. WHAT SHOULD I DO?
Right click on your DVD drive, go to Properties. In there there should be a tab that says Enable Write CD, make sure the box is checked so that you can write using the drive, click OK or Apply. Then restart your computer and put in a DVD, it should read properly now.
Oct 03, 2009 | LG (GDR8163BB) (gdr8163bb 10pk) Internal...
DVD disc tray keeps popping out
I had mine for 2 years and within the first 12 months the tray would not always pop out when I wanted it to. Then finally the machine would not recognise the disc type. Its in getting fixed but although the dvd drive and associated pcb have been replaced the guy says it still can't recognise the dvd disc type. Still trying to work it out.
Mar 25, 2009 | LG DVB418 DVD Player
DVD burner problem
hi DARBAIL!
I have the same unit like you. I Have experienced that the cd/ dvd burner doesn't work because cables might have loosen up. Check the IDE cable if it was connected properly. Try to Check also the burner eg. Nero maybe it was not installed properly. Check the installation settings If it was installed completely. Try to check also the system of your computers may be the Direct X component was not installed.
If you have tune up utilities, Try to Check it properly using the device manager if it was installed in your system.
Lastly, after you have tried all of this but nothing is happening. Your unit CD/ DVD has faulted. Better buy a new one.
Jonags3
Jan 13, 2009 | LG Computers & Internet
LG RC797T Logo
337 people viewed this question
Computer Repairing
Computer Repairing
