Question about Microwave Ovens
My built-in KitchenAid microwave/convection oven/oven fan comes on and goes off spontaneously. I have to turn it off at the breaker. Otherwisel, both micro/convection and the lower oven are functioning beautifully. Any ideas?
  • 2 more comments
  • merryhrt Dec 13, 2008
    I'd say it's the internal cooling fan. The green "on" light is also illuminated when the fan comes on, but the interior light is off and the turntable does not turn during this "phantom" operation. The model# is KEMS376TBL3, serial# XA0202483. It went about 24 hours operating just fine, then spontaneously came on again this afternoon so I had to throw the breaker to turn it off. Any ideas?
    Thanks so much.
  • brokenaid Dec 25, 2008
    Guess what, I think I have the same model oven and microwave.It's a #KEMS376. And we have been having this problem for  many years now and haven't looked into getting this fixed.
    We end up flipping the breaker switch on and off each time we want to use it or the "fan" will turn on mysteriously, it has gotten worse over the years where it would turn on almost immediately after each microwave use.
    Any easy fix?
  • William Miller
    William Miller May 11, 2010
    This seems like a good clue, but which light? Where is it?
    The manuals for your oven and for the microwave can be downloaded here if you don't have them.
    Sorry for the back and forth, but I'm pretty sure I can figure this out for you with just a little more info.
    Can you look at the manual and let me know which light that is and where it is, or upload a good digital photo?
  • William Miller
    Do you know which fan it is coming on by itself?
    This should have three fans:
    1. an internal cooling fan that comes on automatically when you microwave
    2. A hood vent exhaust fan that you can turn on and off
    3. the convection fan that is only used when cooking in convection mode
    Also, please let us know your model model so we can help you best.
I have the same problem
any hints to solve it.
It's a 1988 vintage oven/microwave so I can't complain but it 's a pain if
I have to replace the unit
Posted on Dec 21, 2010
How did you fix this. Im having the same problem
Posted on Apr 16, 2012
Oven has quit seems to have no power, checked breaker ok. nothing works not even the fan or light
your problem is more then likely the fuse, but the fuse holder is most likely bad as well
Feb 04, 2010 | KitchenAid KHMC107BT Convection/Microwave...
Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
Whirlpool microwave fan spontaneously came on
some of these unit detect heat from the stove while cooking.there are designed to turn the exhaust fan on until the temprature gets cooler to prevent any interior damage.
there also could be a problem with your microwave circuit board.
check with whirlpool and see if there is any recalled notices for you microwave
Jan 30, 2010 | Whirlpool MH7130XE Microwave Oven
Kitchenaid microwave model KBMC140HSS03 will not start, sounds 3 tones when any key is pressed. If circuit breaker is turned off and back on it works for awhile, but goes back to 3 tones, sometimes whil...
Your membrane keypad is shorting.
It comes as an assembly, so it's pretty easy to replace yourself. It is part number 4453420 and you can get it here for $235.33 plus shipping.
You can also find helpful exploded views at that link.
The picture below shows you how to unlock a typical membrane keypad connector.
Jan 09, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
Sharp Microwave Oven over stove fan goes on by itself
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So please post a
NEW question, and please include your brand name and the full model number from the tag in or on the unit, as well as the answers to these questions:
Which fan is it?
The
internal cooling fan, which comes on automatically whenever the unit is microwaving?
Or the hood vent exhaust fan which you can turn on and off manually?
Or the convection fan, if it is a convection model?
When is it coming on?
Is it coming on whenever you cook on the stove top?
Thanks!
Oct 09, 2009 | Sharp R-1870 Convection/Microwave Oven
Microwave will turn on by itself and display PAN on screen.
Does everything come on by itself or is it just a fan that comes on? If so, is it a convection oven?
Sep 12, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Spontaneous fan on/off
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Dec 11, 2008 | KitchenAid Microwave Ovens
Microwave/Convection Oven has mind of its own: turns to Crisp mode on its own.
Yes this is a touchpad issue. As you have noted the crisp button is stuck and this is the cause of this. You can try removing the keypad and push up the pressed button. If its jammed then replacing it is the only way.
Sep 02, 2008 | KitchenAid KBHC109J Convection/Microwave...
Microwave Ovens Logo
299 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
