Question about Samsung BlackJack II Smartphone
Storage problems on BlackjackII
My BJII is telling me I need to open storage. When I check the memory the STORAGE is maxed out at 155mb.
I have a 1GB storage card installed, but it has 870mb free space.
I cannot figure out how to fix the storage problem on the 155mb in the phone. I cannot find WHAT is using the storage up. I go to the memory function and all it shows it how much memory is being used - NOT what is using up the memory.
I have attempted to make sure I have no songs or photos loaded in the 155mb of the phone memory.
Any suggestions?
Thanks.
Bob Petty
I am currently dealing with the same problem with my BJ III aka Samsung Jack. I had the BJ II before upgrading and had the same problems, but assumed that Samsung would have fixed this problem with the new phone. Apparantly NOT! Or it's just a stupid windows bug. idk, either way, it sucks! because i have deleted MOST of my messages, all of my "sent" and "deleted" folders in messaging, i've moved all pictures, sounds, media etc to my storage card, and yet STILL only have 10MB of storage available. oh, aaaand i ONLY have google maps installed as an add-on application. really? really samsung?!??!
Posted on Aug 06, 2010
Unable to download anything keep being told insufficient memory.
Start by checking storage space available. some older versions of android have a nag of accumulating useless data in some corners of the system. You may not be able to see what uses the space, but at least it will tell you if there is space or not. To help you, i need to know if there is actually any storage left or not.
This can be found in "settings -> storage"
Note: Internal storage = the onboard storage from the factory. memory is the RAM, nothing can be saved here. So if you have an EXTERNAL micro sd put in, please provide this information.
Apr 12, 2016 | Nextbook 8" LCD 1GHz Processor Wi-Fi...
I d need to get a larger memory car for this camera like a 4GB please advice.
4G is huge for an older camera like this. Are you sure you want 4GB of storage? May not even take anything larger than 1GB, look up specs and find max memory stick size.
Jul 18, 2011 | Sony Cyber-Shot DSC-P8 Digital Camera
My Nokia 6600 fone is very slow when I open application and any folder please help any body and write me to rbmah_123@hotmail.com
Rest your phone. don ot install unnecessary programs. Check if your storage card is less than 1gb
Aug 25, 2009 | Nokia 6600
Memory card
I experienced the same problem with my Kodak C330. I took it to Walgreens and the tech stated that the C330 was created before 2 GB memory cards were invented; therefore, the software inside it doesn't recognize a larger GB capacity. In short, the C330 has a 1GB max capacity. Considering you can take 1200 pictures with a 1GB card, a larger size really isn't necessary.
Aug 12, 2009 | Kodak EasyShare C330 Digital Camera
Ram upgrade on Sony Viao PCVRS420
You can use even 1 stick of 2GIG of RAM or 2 X 1GIG of RAM or any combination will do for as long it will just be a max of 2GIG since that's the max support of your motherboard....
Oct 15, 2008 | Computers & Internet
My PC won't work with 3Gb of RAM
THE RAM CAPACITY OF THIS BOARD IS
DDR266/200, Max. capacity of system memory: 3GB
- DDR333, Max. capacity of system memory: 2GB
- DDR400, Max. capacity of system memory: 1GB
Oct 03, 2008 | Asrock K7S8X-R3 Motherboard
K7VT4A-Pro Mobo
Greetings,
The motherboard will read 1GB DDR400 memory per slot only.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Asrock K7VT4A-Pro Motherboard
Upgrading ram
Hi reisrui, yes it is odd. (It's not the first time I have seen this.)
According to you're manual on page 6, under Specifications. The manual say's you can run up to a Max speed of PC3200 400MHz, 1GB in slot one. In slot 2 you can run a Max of 1GB of PC2700 333MHz in slot 2. Every motherboard I have come across that can run two different speeds of memory. The system will reduce the Max speed to the lower MHz memory speed. If you currently are using 512MB PC3200 400MHz in slot 1 & add 1GB of PC3200 400MHz into slot 2 for a total of 1.5GB of memory. The motherboard will ruduce the total memory over all speed to PC2700 333MHz. Motherboards alway run at the lower memory speed if two different speeds are presant.
I can’t be 100% sure of the 1GB of PC3200 400MHz into slot 2, will run at all! Or if it will be reduce down to 333MHz. I am sure you can run 2GB of PC2700 333MHz, 1GB of memory per slot in you're board for a total of 2GB.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Asrock 775VM800 Motherboard
RAM upgrate
you can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
Dec 22, 2007 | FIC P4M-800T Motherboard
Storage capacity limit
Only the Camera Manual will tell you the max capacity. They do have their limits and you could a be wasting your money or even find the camera does not accept it. Check the manual thoroughly and if still in doubt put the question to the Nikon Technical Support Team.
May 26, 2007 | Nikon Coolpix 4500 Digital Camera
Samsung BlackJack II Smartphone Logo
96 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
