Question about PSC PowerScan SR Handheld
I need to change the scan data transmission format
Where can I get the scan coding for the PSC Powerscan PSSR-8000
PCS Powerscan problems
Clean the powerscan screen with solution, it may be dirty.
Apr 03, 2008 | PSC PowerScan RF Base Station
Asked for a Powerscan 8000 manual?
Here you go. It's for the 8300.
http://lib.store.yahoo.net/lib/barcodescannersdiscount/pwsnn300ug.pdf
Here is teh quick reference guide for the charger as well: https://easeofaccess.scanning.datalogic.com/public/marketlit/Send.aspx?file=820002080
and the quick reference guide for the 8300 itself: https://easeofaccess.scanning.datalogic.com/public/marketlit/Send.aspx?file=820001951
and here are the specs for it: http://www.sektor.co.nz/site/sektor/files/ProductPDFs/lc/powerscanpm8300.pdf
Sorry for the misguidance and lack of seriousness in the guides that answered your question previously.
Good luck, let me know if there are any problems
Dec 28, 2009 | PSC PowerScan RF 8000 (psrf8000) Handheld
Can any tell me how to setup a eurovox its the 2007 version ive scanned the channels theyve all came up but skysports, movies and all the other channels you pay for wnt come on. i used to have a starview...
Dont know if it helps or not but this is the method i used to set up the eurovox max when i first got it - it may work for you.
EUROVOX MAX SETUP
This is the method I use for setting up the eurovox max box but I have been told that it works for versions 1 and 2 as well
PLEASE NOTE : IF YOU ARE USING A SPLITTER IN YOUR SETUP THIS MUST B E REMOVED for the initial POWERSCAN as the box needs to scan from a pure signal- this will ensure all channels being found. – scanning throught a splitter can result in the loss of 50+ channels.
Firstly before you start to scan the box you need to:-
PRESS MENU
GO TO CONFIG
GO TO CLEAR DATA – IF IT ASKSYOU FOR THE PIN PRESS 0000
SELECT – ERASE ALL CHANNELS
Then it will ask you are you sure so press OK
Then wait a few seconds then press EXIT and EXIT again
What you need to do now is a POWERSCAN.
The following is a step by sep method of carrying it out!
Press the MENU button
Go to INSTALLATION and arrow right to USER INSTALLATION
Type in your pin (normally 0000)
Press the YELLOW button for POWERSCAN and change the mode to FULL from Normal by arrowing right to reveal FULL
Now press OK, this will begin the BRUTEFORCE POWERSCAN which can take up to 40 minutes,but it is guaranteed to find every single channel on the network in your area.
Once done the box will switch to a random channel to indicate it has finished !
You will now have around 240 or more channels (in some cases regions can receive up to 330 channels!)
You now need to switch to a non free channel and let the box update the codes – this could take a minute or two, it will indicate on the screen “updating please wait” once finished all channels will now be unlocked.
That’s it you’re all done … HOWEVER …. If you find that you get no channels at all there is a further adjustment you can make to ensure you get the 250 plus channels that your area box will be able to receive and again it’s quite simple to do!
First press MENU
Then go to USER INSTALLATION
Type in your pin (0000)
Press YELLOW button to POWERSCAN
Then change the mode to NORMAL
Then arrow down to the SYMBOL RATE and if its on 6.952 then change it to 6.887 (or vice versa!!)
Then press OK and it will carry out a scan like the powerscan of before.
If after you have tried this and you still are channels short then keep the symbol rate at the new figure but adjust the scan to FULL and try again.
Sep 16, 2009 | StarTech.com StarView SV211K 2-port KVM...
I think you most change the config from RS-232, have the bes speed.
try!
Oct 30, 2007 | PSC PowerScan RF Base Station
Can i clone the configuration from another scanner?? please i need to know how to make this....
You can contact them directly at either link: http://www.datalogic.com/ http://www.scanning.datalogic.com/html/contact.htm They may have software for it that does this.
Mar 27, 2007 | PSC PowerScan RF Base Station
Can't scan label..... i've got some labels in 128 code... when i scan more than 2 times the scanner gets blocked.... so the keyboard too
You can contact them directly at either link: http://www.datalogic.com/ http://www.scanning.datalogic.com/html/contact.htm They'll have your answer.
Apr 09, 2007 | PSC PowerScan RF Base Station
PSC PowerScan SR Handheld Logo
204 people viewed this question
Top PSC Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
Electric Dime
Electric Dime
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
