Question about Sansui VRDVD4005 DVD Player/VCR
Dvd/vhs combo progressive scan vrdvd4001ac
The component works when you slide a vhs tape, however, the tracking is not working? I go into the menu, and it doesn't work out there either. I thought this player had auto tracking. We played a few VHS videos and all the same. The controller has a feature that shows TRCK/Video, so I assume that its for fixing the tracking. Please help. Thank you.
  • 520 Answers
SOURCE: Video no audio
It may be a hook up problem as this unit has seperate jacks for dvd player. Try using the the out jacks labeled dvd/vcr (or vcr/dvd) on back of unit.
Posted on May 13, 2008
shaggyrat
  • 1224 Answers
SOURCE: NETFLIX DVD will not play ...
sounds like a region code block on your dvd player this is a risk unlocking region codes for player search internet explore region code for your model follow directions this is a use at own risk code
your dvd is region coded and your dvd player combo is region coded which code i dont know if live in united states the code for this region is one
Posted on May 17, 2008
SOURCE: Problems with Sansui VRDVD4005 DVD Player / VCR Combo.
the only problem i have is the remote reciever works only part time. I bought aa new remote control but didn't help.what do you think the problem is.
Posted on May 11, 2009
  • 520 Answers
SOURCE: I have a sansui combo
I believe it's available on a Sears sponsered website called managemylife.com. I hope this helps you. Look under "Dubbing".
Posted on May 18, 2010
dvdcdlaser
  • 1285 Answers
SOURCE: My DVD recorder will not recognize any of the DVDs
yes, that is the solution... try to get the DVD that is 4x (Maxell, Dynex) most are all up to 16x now... unless you can find a firmware update for Sansui (I tried already for you, but you can with out a doubt try too)
Posted on Nov 20, 2010
Flat screen power adapter
There are no such things as 8 track movies or tapes. You either have Beta , VHS or 8mm cartridge and those machines are hard to find these days in working order. The only other cartridge is U matic bu they are no way near a 8 track size tape.
Mar 01, 2014 | Audio Players & Recorders
My quasar started given me problems when you tape a program and try to watch it . the tv screen flutters and the sound will not come in clear. You cannot watch a rented movie because it does the same...
Hi, try getting a VHS Head Cleaner; if that don't work? try ajusting the tracking system on the remote. Modern VHS Cassette Players, and or recorders, usally have (Auto Tracking) built-in. Thanks paul7of9
Dec 31, 2009 | Quasar VHQ401 VHS VCR
Picture bounces up and down
All new VCR's are auto tracking however, you should be able to manually track it using your remote, or there are a few reasons that the auto track can fail, the tape may have worn or ragged edges which means that the control head cannot get a clean reading, the control head may itself need cleaning or the tape path requires adjustments, adjusting the guides really needs to be done by a technician as a reference tape is used, or that the heads are low and a good video signal cannot be obtained to gain a reference point....Phil
Dec 15, 2008 | Sylvania 6240VE VHS/S-VHS playback VCR
Sound but no picture
first you will need to take a tooth pic and lightly clean the creases in the head , then use a cotton tip with cleaning fluid on it and wipe the head down , then if it gets to where you can see it again you may also have to adjust the tape pull pins for the tracking
if those don't work then the head is bad or there is a bad component
electech
Nov 26, 2008 | Samsung VR5559 VHS VCR
Vhs tapes recorded to DVD+R's
try forwarding the tape to the end and then rewind to the start again, this can help to seat the tape correctly on the spindle . the audio track part of the tape is in a specific region on the tape so misalignment may be the issue with those cassettes.
also try to press the tracking up and down when playing the video
May 12, 2017 | Televison & Video
Video tape is stuck in recorder
My tape was stuck too. Easy to retrieve, here's how...
Unscrew the five screws. (Two in the front sides, three in the back)
Slide the lid back, then lift it off.
You'll see the "track" where the VHS tapes move forward, then down. Place a finger on each side of the track, and gently glide the tape back up and then forward, manually ejecting the tape.
Slide the lid back on.
***** in the screws.
(Now if only the other issues this device seems to have were that easy!)
Jul 04, 2008 | RCA DRC8335
Blue Screen
Could be dirty heads if you have a dry head cleaner tape try it (Maxell and RCA make ok tapes to try for ~:30-1min) ALSO:
There is a delay in the time you adjust the tracking and
the results being visable on the screen on this unit,
I suspect the tracking is adjusted off center. It takes some getting used to the way this deck's tracking adjustment works as the VHS video is upconverted to be captured onto the dvd and that is what you see, the upconverted video, fed out to your TV, analog or digital, this unit upconverts everthing to digital even analog channels, there needs to be a noise/blue screen off feature in the menu like my old hitachi VHS deck and my JVC ~$60 deck has now. On analog TV or old tapes it comes in handy for adjusting the tracking/antenna.
Feb 08, 2008 | RCA DRC8335
VHS has audio but no video
we cannot get the vcr portion to work only the dvd player4.gif works what are we doing wrong?
Have the same problem? Click Here
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru
Rating: 88%, 431 votes
On some of the DVD/VCR combo units, the VCR output is only available through the RF jack (channel 3), standard video1.gif (yellow) RCA jack and S-VIDEO jack. If you are using the Component jacks, the DVD side will work but the VCR will not. This is because the quality of video recorded on VHS tapes is so much lower than component quality video.
Thank you for rating this solution.
Nov 26, 2007 | Televison & Video
Sansui VRDVD4005 DVD Player/VCR Logo
140 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
