Question about Panasonic MC-V7395 Vacuum
Belt drive Not only do I need a PN for the drive belt on the Panasonic MC-V7395 Vacuum Cleaner, I've noticed that there are problems with the belt breaking. Can someone also explain the proper way to install the belt over and around the motor spindles and any other information that may help. Thank you.
    Problem Solver:
  • 5 Answers
Http://www.partstore.com/Model/Matsushita/Panasonic/MCV7395.aspx?SearchTerm=True
Posted on Feb 22, 2010
What can I do to fix Panasonic vacuum MC-V7395 that will not stay locked in upright position?
Most vacuums have plastic tabs and a plastic mechanism of some sort to that will engage those tabs to make it stay upright.
I am suggesting either the tabs are worn down, or are broken off, or maybe the locking mechanism is broken.
These parts are most often not replaceable, unless you can find an identical machine with these still good on it, and swap whatever parts are necessary to fix it.
Machine is a "throwaway " model.
When it breaks, you are expected to buy a new one.
God bless your efforts.
May 02, 2016 | Panasonic Vacuums
Panasonic Vacuum MC-V7395 to replace the foot release pedal do I have to remove the belt and other things to get to it?
On most of the uprights I have worked on, the top cover has to be removed to get access to the release mechanism at the rear.
Apr 26, 2016 | Panasonic MC-V7395 Vacuum
Panasonic Replace Belt MC-5127
The Panasonic MC-5100 Series takes this belt here:
Panasonic MC-5127 Replacement Belts
Dec 20, 2009 | Vacuums
What belt does the Panasonic MC-V7380 Vacuum take?
Here is a link to the belts you need for your model and the manual which has instructions:
Panasonic MC-V7380 Belts and Manual
Dec 12, 2009 | Panasonic MC-V7380 Vacuum
Vacum overheats and starts smoking after 4 minutes of vacuming
Clean vacuum internally, if the problem persists replace the motor.
Jul 19, 2009 | Panasonic MC-V7395 Vacuum
Panasonic MC-E468 vacuum cleaner loss of suction
HI If the cleaner is loosing suction make sure to check all inspection tubes and the dirt channel hoses after the spinning brush. Also check the main hose for any clogging. One of the worst faults of this model is clogging hoses. Hope that helps you.
Feb 27, 2009 | Panasonic MC-E583 Bagged Upright Vacuum
Order drive belt
Panasonic belt # MC-V2708 is the correct belt for model MC-V7395.
Dec 11, 2008 | Panasonic MC-V7395 Vacuum
How to change belt on Panasonic MC-E464 vacuum cleaner
Remove the bottom plate, the belt goes fron the brush rol to the motor shaft or pulley.
Feb 22, 2008 | Vacuums
Panasonic MC-V7395 Belt overheating/snapping
I have the same problem. I keep thinking I have fixed it, but then another belt breaks. I only have the issue when the roller is disengaged. (on bare floor setting). I did find that the unit was slipping back into engaged slowly, because the disengage mechanizim was not kathing prperly,. Tightened up a screw, and now appears to hold, but somehow the belt still get broken - I beleave it is an issue that the belt is not staying away from the drive when it is disengaged.
Jan 05, 2008 | Panasonic MC-V7395 Vacuum
No suction in vacuum on a Panasonic MC-V7355
the device is a bypass which allows some air flow when there is a blockage. you have a blockage somewhere i suspect hence no suction. check all hoses carefully. take off the base and check the air duct away from the brush roll
May 02, 2007 | Panasonic MC-V7355 Upright Vacuum
Panasonic MC-V7395 Vacuum Logo
264 people viewed this question
Top Panasonic Vacuums Experts
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
