Hi! i have an old Panasonic 32" tv ( around 8 years old ) it's the big one!. My problem is: the board on the back of the tv ( where we plug S video and component cable and other plug. Do not work anymore. 2 nd I think it go like this because of the board: but now my TV send me a picture of a 36" screen on a 32" screen that' s very bad to play xbox 360 game when i cannot see all information ! because it' s out of my screen !! Can you help me ? Im not able to found a On site technicien to go in my house at monteal ! And the TV is about 60 pound ! and I dont have any car ! do you know what I can do ? or who can provide me service ? Thanks
  • Anonymous Dec 11, 2008
    Connection are ok I test all of them ! I will need a new board Im pretty sure ! but now in Monteal Where and who the hell can help me to change this ! lol Thanks a lot for the hint by the way this is very appreciated
  • 116 Answers
Most likely the actual connectors have worn out on the tv, one signal line may poorly connected. Does the picture change if ou hook something up and jiggle the connection? If so see if you canfind a replacement board or set of sockets. Hope this helps. It is most likely a bad connection.
Posted on Dec 11, 2008
Sony Bravia LCD KLV-32U300A Symptoms: ~ powering up problem, whenever try to turn on click twice and power goes completely off no standby indicator as well. i have to discharge the stored current in the...
I know its a 32 inch TVand its probably about 2 years old, give or take. If you got a warranty on it, I suggest calling whoever you got it from (BestBuy,Amazon, etc) and seeing what they can do for you to get it fixed for free. Otherwise call Sony abotu getting a real tech out to either fix or swap parts on the TV at your house, or where to send it for repair. Depending on what it costs, you are probably better off buying a new 32inch LCD TV for about $400.
It seems you have isolated it down to the power supply though. If you are confident enough, you can get a replacement on ebay for abotu $100.
Just depends on what you value more: time or money.
May 21, 2011 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
55" approx 5 months old.
The tv have a problems,with the board that call the Tuner signal board.This is the board,where the incomming broadcasting cable wire plug into this board.This a new tv,take it back where u bought it.Exchange it for a new tv replacement.
Mar 22, 2011 | Element ELC-HS321 32 in. LCD TV
My Sony WEGA kv-32" TV
The "D" board is the main circuit board assembly containing most of the set's power and deflection circuitry. It's the board that typically causes most of the problems because there's so much on it. Unfortunately, this board is no longer available from Sony as a part, and must be repaired to the component level. Many shops don't want to (or can't) get into that depth of repair, so they quote a high price on board replacement. There is no single part you could order to repair this board yourself, I'm afraid. There are some companies in the business of repairing boards, but you're still looking at $200 to $300. With the price of a 32-inch LCD set now around $300 to $400, there's no point in trying to fix a TV when it's just a few dollars more for replacement.
Jan 01, 2011 | Sony FD Trinitron WEGA KV-32HS500 32" TV
LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
Jul 02, 2010 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Cannot remove input label from Panasonic Viera's screen
Are u using HDMI/1 hook up HD box and signal?The HDMI/1 port still work?Do u use the device in the HDMI/1 port lately dose it work?Replaced the HDMI cable,Unplug the tv about an hour,plug it back in,reset it back to factory setting again.See if this work,not than ur HDMI/1 is shorted.
Mar 23, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
I have a Panasonic 32" tube television that is only 6 years old (Model CT-32D31) that we bought from Sears. We suddenly have nothing but a horizontal white line across the screen, which "grows" into a...
Sounds like 'bad' or 'dry' capacitors in the vertical deflection circuit. Please note that leaving the white line on the screen too long can burn in the screen, which is permanent damage.
Jan 31, 2018 | Panasonic CT-32D31 32" TV
The TV will not power on at all
Is the set completely dead? if so you should see no indicator lights and hear no "click' when the power button is pressed. If so than the only thing wrong with the set ic the main Fuse (6.3A 250VAC) has blown.
Sep 19, 2009 | Panasonic CT-32HC14 32" TV
Our Panasonic tv is about 8 years old and will cut off by itself and a few minutes later it will come back on. Some days it is worse than other days. Please advise what we need to do. Thanks, T. Gibson...
The first thing you can do is try plugging it somewhere else. Sometimes its the wall outlet. Unplug it and check to see if the plugs don't wiggle. Sometimes the metal plate on the plugs has broken loose. While it is plugged in move the cord to see if it does it. When all that don't determine the problem. You can open the TV, and check for loose connection, and cracked solder joints. Look aroun the flyback area because thats where most cracks develop because of its weight. I really don't recommend opening the TV because you could make the problem worse if you are not carefull. Also the tube can have lethal charge even if not plugged in, and some TV this charged remain for up to three days. Good luck.
Jun 27, 2009 | Panasonic CT-32D12D 32" TV
Panasonic 32'' TV wont power on
I just received the same model from a neighbour because it too wouldn't power on after suddenly quitting. The T.V. rrepair shops quoted $160.00 to $250.00 to fix the power supply/transformer. All I did was rremove the back and check if the circuit board was actually receiving power from the corsd - it wasn't. I then replaced the plug, plugged it back in and the set works prefectly now. This is a commonm problem with panasonic and certainly does not require the services of a technician, not the exorbatant costs quoted to repair. Simply cut off the plug and replace with a sturdy self sealing/connecting one available at any hardware store for less than $1.00.
Feb 24, 2009 | Panasonic Televison & Video
No picture no sound nothing
We had a TV repairman look at our 3 year old (Oct 2004) Panasonic CT-32HXC14J FLAT SCREEN TV. It suddenly stopped working and appeared to have no power getting to it. It was a high voltage supply or transformer that was bad and has to be replaced - estimated cost is around $400. In a year we will also need to spend around $125 for a digital converter box. We went for the repair since that is still cheaper than a $1,000 plus equivalent size LCD or plasma.
Our old tube tv was still working after 15+ years. They aren't making them like they used to. Way to go Panasonic.
Nov 09, 2007 | Panasonic CT-32HXC14 32" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
