How to get DTV box to wk without a cable leading to Antenna!!!!
My daughter has a TV (the kind with the built in VHS) and it is fairly new about 3 years old, but we do not have a "cable" that you would plug into the back to receive antenna signals. I basically used it in her play room just for the VHS and attached a portable DVD player for her movies since there is no cable ready cords or anything in that room but now I find out my Digital Converter Box won't work without this! What can we do. I have been told a lot of people are screwed because many many houses do not automatically have this cable coming out of their wall (unless you have satellite or cable installed or your house is newer). I don't know how to remedy this....is it not going to work on that TV at all? Also, since her TV was bought in 2004 or 2005 is it possible it is digital ready and we won't need that converter box?
    Genius:
  • 1,199 Answers
All you need is a cheap adapter ...you can find at radio sgack...just tell them what you told me and they will fix you up!
this should fix your problem
Posted on Dec 11, 2008
No longer have cable service-will I be able to watch some channels without buying a dtv box?
Hello
The short answer is yes, you can watch over the air DTV programming on your tv without buying another DTV tuner. There is one built in to the tv. You will need some sort of antenna and then
you will have to scan the channels. But the tv is NICE and you will do just fine.
Nov 24, 2010 | LG 42PQ30 42 in. Plasma TV
I have a new vhs dvd player recorder that will not record.
please note in your vhs dvd manual it tells which dvd (maxell, tdk etc.)are compatible with the recorder
okay do you have a cable/satellite box connected to tv/monitor? yes or no
yes- is the the tv on ch 3? cable connected to cable box in, cable box out connected to dvd in,(on dvd set up menu make sure broadcast is cable) dvd out connect to tv... ? please note some dvd recorder will not record HBO (you can record on vhs tape)
no connect antenna to dvd in, dvd out goes to tv.....
hope this help...
May 20, 2010 | Quasar VHQ400 VHS VCR
Have digital TV have 3 yr old sony VHS VCR DVD player combo
A DTV converter box will take digital broadcast signals from the antenna and convert them to a format compatible with the VCR. You will be able to record programs received through the DTV box on your VCR if you could record analog over-the-air programs before the digital changeover. You can use either the RF output or the component output from the DTV box to input to the VCR.
Jun 30, 2009 | Quasar VHQ400 VHS VCR
After the DTV switch, should I be placing the cable cord into the dtv output to receive all the DTV channels? Protron PLTV 3250 is the set I have and it doesn't seem to get the DTV channels like my other...
Your question is confusing. If you have cable, you don't need a DTV converter box.
If your cable company has switched to digital cable, they will provide you a box, and the cable should go from the wall into the box, then into your TV.
If you don't have cable but instead rely on an antenna, then the wire will go from the antenna into the DTV box, then from the DTV box into the back of the TV. If you're using a regular coaxial cable to go from the DTV box into the television, the TV should be set to channel 3. If you're using the red-yellow-white RCA wires between the DTV box and the television, the TV must be tuned to "Aux," "Line In," "Input Select," or whatever it's labeled on your particular set.
Jun 12, 2009 | Protron PLTV-3750 Television
Can I receive a digital signal and if so, how?
I'm pretty sure this TV already has an NTSC/ATSC/QAM tuner in there, and should need no converter box whatsover... I say this because I own one...
Mar 09, 2009 | Insignia NS-27 TV TV
Need adator for DTV converter box.
The converter box needs an antenna, but not the one built into the TV. In fact, you should get an antenna designed for the new DTV broadcasts to get the best reception. There are a number of styles and they start at under $10.
To connect the converter box to the TV, you have a couple of options. You can use the channel 3 or 4 output from the box and connect the cable to the TV external antenna jack with the appropriate adapter. Or, since this TV also works as a monitor, you could use the converter box video and audio outputs instead. If the TV has a single A/V input jack instead of separate audio and video jacks (the usual case), Radio Shack and other vendors sell the adapter cable you'll need. One might have been supplied with the TV.
Feb 10, 2009 | Coby Televison & Video
How to convert the J53 BW to receive digital broadcast signals
Certainly you can use your TV!
The converter box needs an antenna so it can tune the channels, but it doesn't have to be the antenna that's built into the TV. In fact, you'll get better reception if you use an antenna designed for the new DTV broadcasts. Several types are available at stores where they sell TVs, and they start at under $10.
Then you'll need to connect the converter box output to the TV so you can tune it in on channel 3 or 4. I'm not familiar with your Jensen set, but I've never seen a TV without some kind of connector for an external antenna. The most common type on small TV's is a jack similar to an earphone jack. Radio Shack sells an adapter that plugs in and allows you to connect the cable from the converter box. Take the set with you if necessary so you can find what you need.
Feb 08, 2009 | Jensen J53-BWR 5 in. Portable Television
DTV hookup for an RCA XL-100
Try the $40 RCA DTV Tuner/Converter from Wal-Mart. Connect your existing VHF/UHF antenna (if you don't have one, Wal-Mart sells them too) to the antenna input on the back of the converter and the converter to the antenna input on the back of the TV. If it has only twin lead antenna inputs instead of the standard coaxial type, you'll need a simple twin-lead/coaxial connector, which is about $5. Tune to VHF channel 3 or 4 (set your converter switch correspondingly), turn on the conveter box and follow the onscreen instructions. If you see static, use the automatic or manual fine tune control until you see a clear picture of the menu screen.
Jan 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
DTV Box
Dtv Ready Only Means That It Has A Cable Outlet On The Back They Are Gonna Need The Digital Box If They Wanna Continue Getting Antenna Stations.
Jan 07, 2009 | iLO 3200 32 in. LCD Television
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
