Question about HP LaserJet 4700 Printer
Error 49 What are the DIMM and EIO device ?
    Sergeant:
  • 236 Answers
DIMM and EIO errors are memory related.
It may be that you are trying to print too big of a document for the printer. I usually see that error when printing images.
Posted on Dec 11, 2008
Laserjet 2605 49 error
Error 49 is a firmware error. Try following these steps:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 10, 2014 | HP LaserJet 2605dn Printer
How solve error 49 on 4730mfp
it's a long one !
Dec 18, 2012 | HP LaserJet 4730mfp All-In-One Printer
4730mfp error 49. turn of and on, but not resolved
Dec 18, 2012 | HP LaserJet 4730x MFP All-In-One Printer
49 error
49 error means firmware error..
solution:
3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certain print job, try upgrading the printer driver and / or firmware.)
5. Remove all EIO devices from the printer (Jet Direct cards, hard drives, etc.). If 49 errors goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing.
6. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error.
7. Remember to reconnect all cables that connect the printer to the network or computer.
8. If the error persists, replace the firmware DIMM.
9. If error persists, replace the formatter.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 11, 2012 | HP LaserJet 3055 All-In-One Printer
HP color laserjet error code 49, we turn off the printer when it asks us to but still has an error on it. No clue what is wrong
From the HP Website
ERROR 49.XXXX
A critical firmware error has occurred that caused the processor on the formatter to abort the operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some instances, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or specific software programs. Remove all EIO devices and firmware DIMM if installed. Restart printer. If error is gone replace each EIO device until error appears. Replace device which triggers error. May also be formatter. Firmware updates are available for some machines at http://hp.com and clicking on the drivers and software tab. Also try printing from a different application. If that works go back to the first application and try printing a different file to determine if the problem is file related. You may need to reseat the memory DIMM's or replace the firmware DIMM or formatter board.
Jul 15, 2011 | Office Equipment & Supplies
HP Color LaserJet 3800 dtn printer. Error message says 49.4C06 Service Error
49.XXXXX ERROR A critical firmware error has occurred.
If the message persists with different programs and print jobs, turn the printer off.
Remove all memory DIMMs or thirdparty DIMMs from the printer. (Do not remove the firmware DIMM in the lower slot J1).
Remove the printer EIO card.
Turn the printer on.
If the error does not persist, install each DIMM and EIO device one at a time.
Turn the printer off and then on again after installing each device.
Replace DIMMs and EIO devices as necessary.
If the error persists, replace the formatter and calibrate the printer.
Jun 16, 2011 | Office Equipment & Supplies
Error code 49.FF01 can't turn on or off
A firmware error occurred ( This error is usually caused by a bad formatter board)
SOLUTION
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
Feb 22, 2011 | HP LaserJet 4250tn Printer
Error message 49 on my HP CP 2025 (printer shuts itself off and truns itself back on to see error message 49)
Firmware error:
Nov 22, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
Error 49 at Faxing
Try the follwing or contact me at walid_sayed@hotmail.com
49.XXXXX ERROR
alternates with
To continue turn off then on
A critical firmware error has occurred. 1. Turn the printer off and then on.
2. Try printing a job from a different
program. If the job prints, try printing a
different file from the original program. If
the message appears only with a certain
program or print job, contact the
3. If the message persists with different
programs and print jobs, disconnect all
of the printer cables that connect to the
network or the computer.
4. Turn the printer off.
5. Remove all memory DIMMs or thirdparty
slot J1).
6. Remove the printer EIO card.
7. Turn the printer on.
8. If the error does not persist, install each
9. Replace DIMMs and EIO devices as
necessary.
10. Reconnect all of the printer cables.
11. If the error persists, replace the firmware
DIMM.
12. Replace the formatter and calibrate the
Mar 18, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
49 error turn off then on problem:
pls perform these steps
slot J1).
3 turn the printer on
4 If the error does not persist, install each
5 Replace DIMMs and EIO devices as
necessary.
11. If the error persists, replace the firmware dimm
& calibrate the printer
ur problem will be resolve
Dec 18, 2009 | HP LaserJet 2700n Printer
HP LaserJet 4700 Printer Logo
240 people viewed this question
Ben Johnson
