Question about Rinnai Unvented Gas Zone Heater. 99% fuel efficient: Blower with Thermostat
Little spark to start my unvented 8 year old Rinnai. Use match.
It lights but have to prop a stick to hold the pilot lightopen. Could it be the thermal couple?
Bobbye
  • 53 Answers
Yes - most likely thermocouple, or if the pilot has an orange tip, it will not heat the thermocouple enough to keep the valve energised. Try a blast with canned air or contact cleaner down the tube, not 100psi air compressor.
If that doesn't help, time to ring a gasfitter.
Posted on Jul 17, 2009
Pilot light on furnace went out. how to i re-ignite?
I have experience with coleman furnaces installed in mobile homes. There is a red switch on the gas valve. Some models require you to slide the red switch to the top and hold. Holding is allowing gas to the pilot. You have to stick a long match,grill igniter, to stick through the inspection hole (a little flap or door to see inside the burner area) and hold the match over the pilot while holding the switch upwards at the same time. Others have a pilot selection on the gas valve which you slide the red switch to pilot and push down and hold while liting the pilot. You may need help with holding the door open while doing this. If you can you can use the copper line for the thermocouple to hold the door open for you. Good luck
Jan 15, 2011 | Coleman Heating & Cooling
How do i light the poilt light on a comfortmaker
depending on how old the unit is varies... if you actually have a pilot assembly you will hold down the pilot valve located on the gas valve adn you would turn dial to pilot and push down red button or knob itself the stick a long match in pilot assembly area and lite...once lighted keep holding down for about 15 seconds to get thermocoupler hot adn then rotate dial to on...if it goes out star toperation again and if continues then the copper thermocoupler next to pilot assembly is dirty or bad... if you don't have a pilot assembly and unit is within last 10 years or so you may have a hot surface ignitor in there and it automatically glows on the call for heat and will lite..if your not seeing it its made of porcelein and could have cracked or went out.... some units also have spark ignition and originates from the board and then will go to a spark module ....repost if you have more questions a/c & heat servicer for 18 years...
Jan 08, 2011 | Heating & Cooling
Pilot light wont stay on. How do you adjust pilot flame? Pilot flame doesn't reach temperature sensor.
then the pilot is blocked needs cleaning out or try blowing it out with air , or undone pilot and remove pilot injector and clean it .
Nov 01, 2010 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Describe your Problem i have a quasar vulcan gas heater pilot light is on but wont ignite. can hear it clicking trying to ignite what is the o=problem . this heater maybe about 20 years old
What do you mean by the pilot light is on but won't light. Do you mean that there is gasbut won't light. If so the spark may not be hitting the pilot properly or it may not be getting enough gas. If lighting but continuing to spark the sensor may need cleaning. This can be cleaned with steel wool (not sand paper), probably will need to disassemble the pilot asembly The pilot may also be dirty reducing gas flow. If this is the case dis-assembly will be needed and the pilot cleaned.
Sep 05, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
The pilot doesn't stay on. the flame doesn't extend out as far as it normally does. The model number is Reh-30dt-p.
The pilot light will extinguish when you turn the valve to on for main burner... cause is a bad thermocouppler. it's yhe bulb the poilot light heats up.
Oct 09, 2009 | Rinnai Unvented Gas Zone Heater. 99% fuel...
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
Pilot will not stay on when trying to ignite heater
you need to replace the thermocouple cost about 12.00 thanks from gilles
Mar 14, 2009 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Have an old Rinnai Gas Heater (approximately 30 years old) still working well, but we had to turn off the gas, and now cannot turn it on again. We have two buttons, one below the other, one is red and...
You are half-way right, to light the pilot, light it and push down the red button and hold it for at ----least2-minutes-- till the flame heats up the pin (thermocouple- which fire-thermocouple metal makes electricity which sends it to the gas valve and says ,OK GAS VALVE,I'VE GOT A PILOT FLAME SO OPEN UP THE MAIN GAS VALVE! See where I'm going with this?
Sep 03, 2008 | Rinnai Heating & Cooling
Heater goes off
Possibly A bad thermocoupler. It is the part that looks like a stiff solid copper wire with on end sticking in the flame of the pilot light and is a safety feature if the pilot goes out it starts to cool and the resistance changes back you the module and the module shuts the gas off. I have seen these go intermediately faulty in waterheaters and do just what you described.
Jan 08, 2007 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Rinnai Unvented Gas Zone Heater. 99% fuel efficient: Blower with Thermostat Logo
94 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
