Question about Sony CHC-CL1 CD Shelf System
Cd player wont respond
I have a sony chc-cl1 , basically turn on the system and press eject on any of the cd buttons , there is no noise , then the display says open , but the drawer isnt open , it does that on all of the cd eject buttons , it wont play discs either , any ideas thanks , Dave
Did you fix it? I have the same problem but can't find any solutions.
Posted on Nov 22, 2011
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
Sony CHC-CL5MD cd player is stuck and the cd's wont open. is there a reset button?
you need to replace loading belt, and possibly you need to grease/lube sliding mechanism also - "But this is the last you will to do" Because it is pain in a***s to do that properly. I recently repairing my CHC-CL5MD and spend two or three days to assamble it back properly. Because if you miss gears positions, you will stuck with it for long. So i recomend for replacing loading belt. You will need a belt with 45 mm in diameter.
Maybe here is someone who has LCD screen for CHC-CL5MD? I screwed up with it when cleaning screen inside from dust. screwed up with LCD flat cable - it is so fragile.
Sep 16, 2010 | Sony Televison & Video
Cd compartment wont open and it is locked dvp sr200p sony
Ensure the child lock feature is disabled. Try Power resetting the Player.
Turn Off the player and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation.
If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons.
If the issue still persists, service might be required.
Jul 26, 2010 | Sony DVP-SR200P DVD Player
Tivoli Audio Music System: CD wont eject
We've had the Tivoli Music System for 3 years. A CD became stuck in the player when I pressed the EJECT button before turning the player on. We tried turning it off and back on, unplugging it for a minute, removing the batteries and unplugging, etc. Nothing worked. I finally turned the player upside down in my lap, then turned on the CD player, and it said LOADING! Progress!!! I turned it right-side up and hit EJECT, and it worked like new. The CD loading mechanism had become bound up and simply needed a different "attitude" adjustment. Don't give up too early in attempting to fix these players on your own.
Feb 17, 2010 | Tivoli Audio® Music System Shelf System
Cd drawers on sony CHC-CL1 wont open
possible loading belt, is worn and slipping,will require you open unit to repair,let me know if you need help with disassembly
Jul 12, 2009 | Sony Audio Players & Recorders
Sony chc cl 5 md - cd changer doesn't open
I had a similar problem with my sony cd changer. Took it apart it turned out to be the drive belt a 3 pound part. Got a new slightly smaller one and works well. Very easy to replace.
Jun 24, 2009 | Sony CHC-CL1 CD Shelf System
PRESET RADIO STATIONS
Click Sony Support to download user manual of CHC-CL1 to know about setting radio preset function.
Mar 18, 2009 | Sony CHC-CL1 CD Shelf System
Help I am locked out ! Sony DAV S 550
Hold down the eject button for about 10 seconds
Sep 02, 2007 | Fisher DVD-SL30 DVD Player
Sony CHC-CL1 CD Shelf System Logo
330 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
