Question about Toshiba Satellite 1800-S253 Notebook
System malfuntioning i have a problem with my laptop,i plug in a flash drive to the system and the system went off i have been trying to fix it ma self but it is not responding please help
Status code 416B-0000-3080-0508-8007-2F76 appears when updating
The first thing I would try is to go to system, storage then select hard drive, press left bumper, right bumper, then X, do this twice and then yes to update. This deletes the old update and tries to replace it with the new update. If this fails there is an alternative method - You first need a flash drive/memory stick that has got FAT32 file system (just in case you don't how to find out this info) with drive inserted to laptop/pc go into windows explorer and right click on the memory stick and go to properties you can then view the system type i.e. NTFS, FAT32.
Once sorted go to the Xbox Support website then select Xbox360 - System - System Update then select How To Get A New Xbox 360 Update last option to pick is Copy To A USB Flash Drive.
Save the file to your laptop/PC, once completed unzip the file and copy the folder to the flash drive how it was unzipped, plug the flash drive into the Xbox and switch it off. Once the 360 starts back up it looks at the flash drive and installs the new update. Once completed you can remove the flash drive and carry on playing!!
Apr 01, 2014 | Microsoft Xbox 360 Console
I didn't find a port in ma laptop in which i can plug n play b'coz it didn't plug in into usb ports
These are the minimum system requirements of the flash drive you bought.
• Computer with a USB port • Latest version of Windows XP, Windows Vista® , Windows 7 • Mac® OS X 10.4, 10.5, 10.6 • Minimum free disk space: 600MB recommended
Any way back to the question, there is a protective plastic clip for the gold contacts have you tried removing it before using, it might be the reason you cant stick it to any USB port. Any way don't lost the cap so it can lessen dirt on the gold contacts.
Hopefully this information helps.
Thank you for using FixYa.
Aug 15, 2011 | LaCie CooKey USB flash drive - 16 GB USB...
I have a TDK 4 gb pendrive .... i formated my pendrive... ma flash lock is missing and ma storage has been reduced to 2gb.... i want to increase ma storage how do i do that..???
FAT32 file system supports only up to 2GB of space, and more likely you have formated the drive as FAT32. When you plug the flash drive in the USB, right click on drive letter associated with the flash drive, select Format and on the next screen under File System select NTFS.
Nov 14, 2010 | TDK (CD-RW74HSFXS5) Storage Media
Battery indicator has 3 amber flashes followed by 1 green flash
that is the exsact problem i'm having with a costumers dell.
When i fix it i'll let you how to solve it.
I did get it working for 5-10min but it went of again,
I HAD SWOPPED THE RAM FROM THE DIMM A PORT TO DIMM B PORT / REMOVERD THE WIRELESS CARD / CD DRIVE / HARD DRIVE & BATTARY then plugged in the charger ,stud it on it's side & powered it up & it worked fine
SO TRY THAT.
Jun 16, 2010 | Dell Inspiron 1000 Notebook
Flashing messages
have the system tested for trouble codes, go to any kragen auto or autozone parts store. and ask them to run a trouble code test, it is free. t5hen post the codes here3 for me to look at and try and provide a solution to your problems.
Mar 20, 2009 | 2003 Chevrolet Impala
DVD SUPERMULTI DRIVE
i thnk u should go to urs latop dealer n ask him wat to do....
becaz if u still trying to eject it ma cause some damage to to DVD drives......
Jun 17, 2008 | Toshiba Satellite P105-S6104 Notebook
Orange and green light flash
The flashing battery light is an indication that the system is attempting to charge the battery. The orange light indicates a problem charging one of the battery cells. This usually means that the battery either needs to be recalibrated or replaced. To recalibrate the battery just use the system until the battery is dead, then recharge and repeat the process twice, after which time the battery should be recalibrated. If this doesn’t fix the flashing orange light then the battery may need to be replaced.
hope this helps
Jan 07, 2008 | Dell Latitude D600 Notebook
Usb problems
Due to current (amperage) limits of batteries, most laptops have VERY small current caps on USB ports. Some desktops can have 1-2 amps per USB port, but laptops are often limited to 300 to 500 milliamps. This is sufficient for most memory sticks/pen drives, but many USB devices need much more power than that. For example, external USB-HDD cases for 2.5 inch hard drives will need 100-200 mA ABOVE the rating of the HDD, which is usually 500-750 mA. Few laptops can provide that much current, or will initially provide enough to spin up, but get errors or fail to mount due to lack of power. If your USB device has a secondary power jack, use it with a 5 volt AC power supply with the correct jack polarity and current rating. You can also try a "double harness" USB cable, which plugs into the laptop with TWO USB jacks, and into the USB HDD case with one (the third) jack. This allows TWO USB ports to "double" the available current for the USB device. Best to get the specs on your laptop, see what your USB current limits are, before doing this. If each port is limited to 300 mA and your HDD is 500 mA, you will be OK, but if the HDD is 750 mA, the total of 600 mA is not going to spin up the drive.
Dec 03, 2007 | Computers & Internet
Keeps flashing clean Kenmore dishwasher 665.17019401 need a new owners manual
i was trying to install my kenmore elite 665 dishwasher but i cant find the plug do they come with one? or were do i hook it up?
Sep 22, 2007 | Dishwashers
Toshiba Satellite 1800-S253 Notebook Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
