Question about Panasonic MC-V7395 Vacuum
Order drive belt
Can't find the part number for a drive belt for the Panasonic MC-V7395 Vacuum Cleaner. Can someone help.
Panasonic belt # MC-V2708 is the correct belt for model MC-V7395.
Posted on Oct 03, 2009
  • turtlesue Oct 03, 2009
    Oops. Sorry. The correct psrt number is MC-V270B not MC-V2708 as I previously posted.
What can I do to fix Panasonic vacuum MC-V7395 that will not stay locked in upright position?
Most vacuums have plastic tabs and a plastic mechanism of some sort to that will engage those tabs to make it stay upright.
I am suggesting either the tabs are worn down, or are broken off, or maybe the locking mechanism is broken.
These parts are most often not replaceable, unless you can find an identical machine with these still good on it, and swap whatever parts are necessary to fix it.
Machine is a "throwaway " model.
When it breaks, you are expected to buy a new one.
God bless your efforts.
May 02, 2016 | Panasonic Vacuums
Panasonic Vacuum MC-V7395 to replace the foot release pedal do I have to remove the belt and other things to get to it?
On most of the uprights I have worked on, the top cover has to be removed to get access to the release mechanism at the rear.
Apr 26, 2016 | Panasonic MC-V7395 Vacuum
Panasonic Replace Belt MC-5127
The Panasonic MC-5100 Series takes this belt here:
Panasonic MC-5127 Replacement Belts
Dec 20, 2009 | Vacuums
Vacum overheats and starts smoking after 4 minutes of vacuming
Clean vacuum internally, if the problem persists replace the motor.
Jul 19, 2009 | Panasonic MC-V7395 Vacuum
Panasonic MC-E468 vacuum cleaner loss of suction
HI If the cleaner is loosing suction make sure to check all inspection tubes and the dirt channel hoses after the spinning brush. Also check the main hose for any clogging. One of the worst faults of this model is clogging hoses. Hope that helps you.
Feb 27, 2009 | Panasonic MC-E583 Bagged Upright Vacuum
Belt drive
http://www.partstore.com/Model/Matsushita/Panasonic/MCV7395.aspx?SearchTerm=True
Dec 11, 2008 | Panasonic MC-V7395 Vacuum
Part numbers for washers and end caps of vacuum agitator brush
The part numbers for the washers and caps can only be found if you know the agitator brush number.
Mar 28, 2008 | Panasonic MC-V5745 Bagged Upright Vacuum
Panasonic vacuum cleaner MC E554
Wish you had listed your model number, they are all different you know, that wire you refer to I have seen on some models and it is only a belt guide. Should be a slot that it fits into.
Feb 23, 2008 | Vacuums
How to change belt on Panasonic MC-E464 vacuum cleaner
Remove the bottom plate, the belt goes fron the brush rol to the motor shaft or pulley.
Feb 22, 2008 | Vacuums
Panasonic MC-V7395 Belt overheating/snapping
I have the same problem. I keep thinking I have fixed it, but then another belt breaks. I only have the issue when the roller is disengaged. (on bare floor setting). I did find that the unit was slipping back into engaged slowly, because the disengage mechanizim was not kathing prperly,. Tightened up a screw, and now appears to hold, but somehow the belt still get broken - I beleave it is an issue that the belt is not staying away from the drive when it is disengaged.
Jan 05, 2008 | Panasonic MC-V7395 Vacuum
Panasonic MC-V7395 Vacuum Logo
231 people viewed this question
Top Panasonic Vacuums Experts
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
