Question about HP Photosmart 375 InkJet Printer
Printer says "please insert card" when I try to print
This has not occurred before. The cable connections to computer are okay.
    Problem Solver:
  • 9 Answers
Is it because you haven't put your card in properly?
If not turn printer off and reinstall again in laptop/PC and take out everything in Printer and put back in
Posted on Dec 11, 2008
Memory card error
view & print button is used for viewing the content in the memory card if it is inserted in your printer. If you are giving job from computer and it is not getting printed try the following steps.
1. check the cable between computer and printer.
2. check the printer queue ( see a printer icon on the right bottom of the screen near time). if it is there double click and check whether any document is pending in the queue. if so cancel all pending job and restart the computer and try printing again.
Oct 10, 2013 | HP Photosmart D7160 InkJet Printer
Offline printing from computer
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Oct 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Can't remove memory card from printer
hi
  • Ensure the MP970 is connected to a working electrical outlet. Turn the printer on by pressing and releasing the power button located on the upper left hand side of the control panel.
  • Step 2 Select the memory card you wish to use. Insert the memory card into an appropriate adapter if it requires one. Open the Card Slot Cover, located on the right hand side of the printer, by pulling the door out and toward the center of the printer.
  • Step 3 Insert the memory card into the appropriate card slot with the label side facing up. Confirm the Access Lamp is lighted. Close the card slot cover.
  • Step 4 Check the "Select and Print" option on the display screen. Select the "Okay" option.
  • Step 5 Load your preferred print media into the printer. Confirm Paper Source, Paper Size and Media type. Select the "Okay" option. Select the "Next" option. Select the "Okay" option to access the images on your memory card.
  • Step 6 Press the Left or Right Arrow buttons to select the image you wish to print. Press the + or – button to determine the number of copies of this image you wish to print. Select the "Okay" option.
  • Step 7 Confirm your print instructions. Select the Print option to being printing your photos.
  • Jul 06, 2010 | Canon PIXMA MP130 All-In-One InkJet...
    We have giant company & having CANON LBP 2900.Whenever i am going give print it,s not printed .message shown ready to print but error occuring please help
    try checking the printer if it is installed properly, by going to the printers and faxes folder, right click lbp2900 and check its properties, verify if the port used is correct. check printer if it is online and also the usb connection. if everything is ok, try replacing the usb cable. if after replacing the cable and the printer still doesn't print, uninstall it and remove the connection. Restart the computer and begin installation, do not connect the printer unless the system prompt you to do so. Run test print after the installation.
    Jun 22, 2010 | Canon LASER SHOT LBP-2900 Printer
    Can't download to computer from memory card
    there should be 2 to 4 inserting ports in the printer for memory card, so you have to just insert the memory card in right port and there is also some type of jecks for memory cards to insert them in card readers.
    Apr 13, 2009 | Computers & Internet
    Hi! I'm getting the following message on my computer screen: Error Number : 306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your...
    Do the following:
    Try a different usb cable.
    Plug the cable into a different USB port.
    Try disconnecting printer power cable for ten minutes.
    Unplug computer power cord for ten minutes and restart.
    Reinstall printer drivers.
    If that all did not work, test the printer on a different computer, to find out if it is faulty or not.
    Sep 19, 2008 | Canon Office Equipment & Supplies
    Printer keeps saying insert memory card
    The message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product. For more information please check the link bellow: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01436439&cc=us&lc=en&dlc=en&product=3194498 Good Luck
    Aug 21, 2008 | HP Photosmart C6280 Printer
    Canon i850
    Hello  btfsplk,
    Me is Vikram Kumar Thumu from India-Hyderabad. I have seen your message and issue on this issue. I would like to provide my suggestions on this issue.
    Generally, this issue could happen if the Port selected that is Printer Properties  is not same as the Port connected to the Computer or Notebook, if this is the case the Printer starts Printing Blank pages from Computer . The issue could also happen if the Printer software is corrupted.
    To resolve the issue I recommend you to check and try out below options:
    1. try to restart the Print Spooler.
    2. Make sure that you selected the correct port in the Ports tab of the Printer Properties.
    Example: If your Printer uses USB cable to connect the Computer, then make sure that it is USB001 or USB002 is selected in the Ports tab of Printer properties.
    Note:  Make sure that Printer is connected to the USB ports of Computer at Rear End and not in front end. Since, front end USB ports in Desktop Computer are meant for USB flash Drive or other USB devices and not for connecting Printers.
    Well, I need much more information of your computer so that I can help you further steps of troubleshooting.
    So please let me know below information:
    1. Version of Operating System that you are using on your Computer.
    2. Please let me know the Printer Model number and Serial number along with Manufacturer.
    3. Did you receive any other error messages on this issue?
    4. Please let me know cable type ( USB/Parallel) that you are using to connect Printer to the Computer.
    Please mail the information at thumuvikram@rediffmail.com, I'll be glad to help you with further information on this issue.
    Bye .
    Oct 15, 2007 | Canon i850 InkJet Photo Printer
    Printer time out error!!????
    is your printer connected with a serial cable, if so, you may have to install the printer and software again, but if you are connected via usb and this is the given error then there is a connection fault as, you may already know that LPT1 is not a usb connection but serial cable.
    Apr 29, 2007 | Canon S400 InkJet Printer
    HP Photosmart 375 InkJet Printer Logo
    282 people viewed this question
    Seeker5211
    Seeker5211
