Question about HP Pavilion dv9000z Notebook
I want to use an external monitor
I have an hp dv9000 i would like to use my external monitor. i pluged it into the portbut i dont get any responce from the monitor. any ideas?
  • jenna1980 Dec 11, 2008
    Thank you so much!!! :)
    Sergeant:
  • 236 Answers
You have to tell the laptop to use that port. It is usually the Function Key and one of the FKeys. Look for a blue (the usual color for functions) monitor symbol.
Press it 1 time = signal to only the ext port
2 times = both the laptop screen and the ext port
3 times = back to the laptop screen only
Posted on Dec 11, 2008
How do I connect my laptop to a Monitor
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 06, 2012 | HP Pavilion dv9000 Series Laptop DVD Drive...
How to connect a Monitor to laptop
Sep 06, 2012 | HP Computers & Internet
Connecting laptop to projector
You can switch to anexternal monitor or data projector by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCD screenplus the external monitor or back to LCD screen only by pressing the Fn keyplus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
Jun 05, 2012 | HP Pavilion dv6200 Notebook
My HP Pavilion dv9000 Laptop powers up but screen stays black. Keyboard lights up and you can here the computer running.
Connect it to an external monitor to see if it shows video.If it does the display panel needs to be replaced.If it doesn't show video the video card is most likely malfunctioning.The HP dv series are bad about having video problems due to heat and depleted thermal grease.Hopefully it will show video on the external monitor.
Jan 26, 2011 | HP Pavilion dv9000z Notebook
My hp pavillion dv9000 turns on but the screen stays black like it isnt getting any power to it
Connect your laptop up to an external monitor. If you get a picture on the external monitor then you know that your Chip is fine. At that point You will need to replace the screen.
Dec 23, 2009 | HP Computers & Internet
Hp dv9000 switches on to show coloured lines on screen.
Hello
My first guess is that the screen circuitry has gone bad - although fixable. Use an external monitor to verify this. If the external monitor is fine then the screen circuitry is bad, if the external screen shows the same problem then the video chip or associated circuitry has gone bad. My company fixes these all the time.
Jul 28, 2009 | HP L1702 17" LCD Monitor
Screen problem HP DV9000
Please perform system restore on your pc. Restore to factory default and remember to backup your documents.
rate this
Jun 04, 2009 | HP Pavilion dv9000z Notebook
Can you replace a video drive on my laptop
I assume you mean video card instead of video drive. The nvidia GPU ( Graphics Processing Unit ) is built into your m/board. The only way to upgrade from say 256mb to 512mb is a m/board replacement. If you have a GPU failure ie failed graphics out put forstly test to see if the output to external monitor works - do that by pluging and external monitor into the vga port located on the l/h side up near the power on button - if there is no putput or it has coloured vertical lines your graphics chip is failing. the only rectification is m/board replacement.
Hp has just recently trashed a huge number of defective m/boards in the pavilion dv2000/dv6000/dv9000 & presario v3000 v6000 range and had them remanufactured to correct this GPU failure
May 18, 2009 | HP Pavilion dv9000z Notebook
HP dv9000
 Hello jarkk, I believe your problem is with your backlight inverter. the hard drive should be installed for this process of checking it on an external monitor. with the hard drive removed it will not boot to the operating system. with the drive in, use the external monitor. if the monitor works when plugged into the external monitor plug, this will eliminate a bad video card. if the screen is still black on the laptop screen, replace your backlight inverter. the last case cenario is to make sure your backlights are not burnt out.
Sep 11, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000z Notebook Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
