Question about GE WPRB9220D Top Load Washer
No Hot water on GE washer
I can not run a hot cycle. When I try to run a hot cycle I get hot water for about 15 seconds and then it stops. I have checked the hoses and filters. If I turn off the cold water and try it I get hot water for about 15 seconds and then it stops, I can stop and start it again with the same reuslts. If I have the hot and cold water on the hot will run for about 15 seconds and then I get just cold water.
jsrock516
  • 5911 Answers
SOURCE: GE Washing Machine
Sounds like you have a bad fill valve on the cold water side. If your hoses are not clogged, then remove the hose and check the cold water inlet going into the machine for clogs. There is a screen that can trap mineral deposits and/or rust. If you have well water or hard water, they can become clogged easily. Sometimes you can clean them out and they will work just fine. Most of the time, however, you will need to replace the fill valve. Make sure you unplug the machine and turn the water off. The valves are electronically controlled. I hope this helps.
Posted on Apr 29, 2007
aborcass
  • 2651 Answers
SOURCE: Kenmore washer: no cold water
easy way for me to determine problem is reverse the hoses on the machine still no cold??? should be no hot now!! in which case you have a bad water valve no cleaning need to replace
Posted on Mar 02, 2008
docjohn174
  • 943 Answers
SOURCE: Hot water cycle flow problem
hi thanks for the question their is a screen in the water valve to catch any dirt you can try and remove the screen in the water valve and try again if it works ok . it usually works thanks the appliance doc
Posted on Sep 24, 2008
IrishDruid
  • 2712 Answers
SOURCE: Washer will won't run cold water cycle
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
  • Hope that helps! Should you have any further questions, please feel free to post them here.
    P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
    Posted on Oct 12, 2008
    SOURCE: Samsung WF-B1254/XAC Cold water in Hot setting
    take it back for a new one
    Posted on Nov 01, 2008
    Model NFW7200TW Washer wont fill with water
    Are you sure you have both hot and cold water connected? Try turning the water valve on, if you don't have hot water make sure you choose cold cycle. That's the first place I'd start.
    Dec 02, 2015 | Amana Washing Machines
    Dryer is running, but rotating very slowly. it generates heat, but makes a very loud noise. it's a GE Adora Dryer
    Instructions
    1. Wait approximately 90 seconds for the light to turn off if the "Start/Reset" indicator light flashes. Press the "Start/Reset" button to restart the wash cycle.
    2. Close the dishwasher door and move the latch to the locked position if you hear a beep once every 30 seconds when the dishwasher should be operating. The dishwasher will not operate if the door is open.
    3. Turn on the hot water faucet and feel the water to check if it is hot. Wait for the water to warm up before running the dishwasher if the water is not hot. Check that you have proper water pressure and wait for the pressure to return to normal if it is low. Your dishes may not come out clean if the water is not the correct temperature or if you have low water pressure.
    4. Move the dishes on the racks so that they do not block the detergent dispenser or washer arms on the bottom of the machine. The dishes will not come out clean if they block the detergent dispenser or the washer arms.
    5. Load the proper amount of detergent in the dishwasher if you find spots or film form on your glasses. If you have hard water, use a rinsing product such as Jet-Dry in the dishwasher to clean the spots or film. If the problem persists, wash smaller loads of dishes.
    6. Add only automatic dishwasher detergent to the dishwasher if you find excessive suds in the tub after running a cycle. Measure out the proper amount of detergent.
    7. Press the "Heated Dry," "Hot Start," "Hot Wash" and "Added Heat" buttons, if you find that your dishes are not fully dry after a wash cycle completes.
    8. Press and hold the "Heated Dry" button on the dishwasher for approximately three seconds if the control pad does not respond to button presses. This is the child lock that prevents unwanted use of the dishwasher.
    Feb 24, 2011 | GE Dryers
    Fisher and paykel nautilus. Cycle stalls with 15 mins to go. On any setting.
    OK, when you say it sounds like a record skipping does that mean its washing then not washing? what cycle are you using ? sorry to ask these questions but sounds like an unusual fault.is the water hot? could be control module or pressure switch fault. please reply and we can hopefully track down this fault.
    May 22, 2010 | Fisher and Paykel 24 in. DS603H SS...
    Anyone anygood troubleshooting a Whirlpool Washer?
    Thats a problem. Did you have the washer laid on it's side when moving? Timer switch would be first look. Hot water not working,but cold is? Mmmm.. Water inlet is pretty simple no real mechanical parts except intake valve for each inlet. Valve could be plugged or stuck closed on hot intake. Temp switch could be bad and that would cause the water intake to shut.I guess, but not usually a problem unless old machine. Make sure the fuse in control panel is intact. Underside of washer is a relay switch called wigwag. If it is bad nothing will cycle, easy fix 10 minutes and $15 in most cases. But check out before jumping to solve. All ways check cheapest parts first. Lid switch would also cause the no start and spin cycle problems.
    Mar 09, 2010 | Washing Machines
    Error message only prior to the rinse cycle,not filling correctl
    The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
    Jun 15, 2009 | GE Dryers
    No hot water
    If you are satisfied that the hot water supply is o/k, then you need a new hot valve fitting.
    Plz leave feedback.
    Thanks.
    Dec 11, 2008 | GE WPRB9220D Top Load Washer
    Maytag Front Load Intellisense 6.5kg
    washer may not be detecting water temp but water flow ..if you never use hot water may try hooking cold water to a Y-connector and then hooking to both hot and cold inlet valves ..however it is also possible washer is detecting inlet temps in which case you're out of luck ..i suspect the latter
    Sep 01, 2008 | Washing Machines
    Ge profile whsb8000bocc
    Washer is most likely trying to fill with cold rinse water and the inlet screen is blocked or the cold water solenoid is bad. If you set washer to wash cold only it will not fill or fill very slowly. When you set it to warm or hot you are getting almost all hot. Clean inlet screen or replace inlet water valve.
    May 12, 2008 | GE Profile WPSR3120WWW
    GE WPRB9220D Top Load Washer Logo
    304 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
