Question about Rancilio Silvia Espresso Machine
No water coming out of coffee dipense head on one side
Epoca de2gr-replaced solenoid & valve. You can hear solenoid energizing, but not the valve "click". Thus no water. Switch the wires from the other valve, just to see if it would work and it didn't.
    President:
  • 1,618 Answers
The metering jet and or filter on the back of the group is clogged.
Posted on Mar 09, 2009
Rancilio coffee machine .no water coming out of the group head . steam coming of the group head
Hi Ewah,
If you are getting steam from the group and no water when you turn on the water button - then you may have a group blockage.
The fix depends on the type of machine you have.
If it is a commercial type - then call in a qualified coffee technician.
If it is a domestic type like rancilio sylvia, the you could try to descale - maybe too late, but worth a go.JURA descaling tablets
If when descaling, no water is coming from the group try leaving the steam tap open when asking for water.That way you may get the descaler liquid moving inside the boiler and it may clear the solenoid valve blockage.
If no joy with that you may need to replace solenoid valve.
230V 9W PARKER SOLENOID
Domestic machines need regular descaling to avoid group blockages.
Mar 18, 2017 | Rancilio Coffee Makers & Espresso Machines
What happens when my new rancilio epoca coffee machine the water doesn't flush out.. It's a 2 group, the left one works, but the right one it's like water dripping only
Solenoid valve OR dirty and blocked shower screen OR dirty and blocked jet OR crap in the line to the R/H group..
Simple fix if you are in Brisbane.
May 25, 2014 | Coffee Makers & Espresso Machines
Hi! I have a Rancilio epoca DE 2 group machine and the antivacuum valve spurts water as the machine is heating up. ow can I fix this? Please advise
Your boiler is flooding because the water level probe is not behaving properly. The machine thinks it needs water.
Jan 09, 2011 | Rancilio Epoca ST-1 Espresso Machine
There is no water coming out of the water dispenser. I changed the filter and check the water line coming from the pipe, there is water coming thru the water line. when I push the water dispenser lever I...
Well, there is no "motor" for the water dispenser, only a solenoid valve. However, there could still be a problem with the solenoid even if you do hear it when its energized. Hearing it make a noise does not mean its working properly.
Aug 13, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
At the end of initial pressure-up after first turning my Epoca on in the morning, the pressure goes past 'normal' until it blows the escape valve. What is wrong? Thanks. Matt
The vent valve is stuck in the open position, leave the steam wand open, while the machine is heating until you hear it hissing, then close steam wand and machine should heat up properly. Replace the vent valve as soon as possible.
Mar 01, 2010 | Rancilio Epoca ST-1 Espresso Machine
I have a Whirlpool Side-by-side Model # ED25DQ 25.2 My ice maker quit working. It is not letting the water come in. The arm is still rising and falling to let the ice out into the bin. What can I do to fix...
1) Check that the water filter is not plugged.
2) Listen if you hear the water solenoid energize as the fingers rotate around and come to a stop. If not, then you could have a bad water valve. If you do, check that something is not blocking the water flow through the valve.
The fill switch on the ice maker may be bad as well, which would prevent you hearing the water solenoid from energizing. It is located inside of the front cover of the ice maker.
Let me know what you find and I will help further.
Dec 12, 2009 | Kenmore 22.6 cu. ft. Side-By-Side...
Can't get water out of the group head. Can hear the pump but no water and then error light comes on
The coffee group is equiped with a jet and jet filer which is probaly blocked from dirt or scale. Need to be removed and clean up. Consider that the coffe solenoid valve and shower are clean from any dry coffee Please remebr to vote for this answer thanks
Oct 31, 2009 | Astra Mega I Automatic
Water doesn't come out from showerhead once the button is pressed - can hear the water pump going, the top of machine is warm so boiler is functioning.
Does water flow without the portafilter in place, if yes then check grind, if no then remove screw,filter and diffuser and press brew button, if water flows clean filter, if no water then the micro jet in the group head is blocked or the solenoid is clogged.
Oct 06, 2009 | Rancilio Epoca ST-1 Espresso Machine
No ice in the icemaker
there may be some problem with water inlet solenoid valve. the coil or valve could be faulty
Mar 10, 2009 | Refrigerators
Rancilio Silvia Espresso Machine Logo
307 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
