My pc will not access my new wireless router
My Linksys wrt54 dont work with my router. My naugbour have set something up for me, but now it only work by cable.
Please help.
Nancy
  • richpower1 May 15, 2009
    I paid to have help setting this router up secure. Now it is not secure. I need help refixing it, since I already paid, or a total refund for the router.
    Already have case numer.
    THAMKS,
    Gary Tebay
  • 340 Answers
Hi there, and welcome to FixYa.
You have got yourself a very friendly neighbor, but give him/here coffee, not access to your network.
- what you have to do, is to find the reset button on the back of the router, press and hold for about 5 seconds with power on, and you have reset it to factory standard.
DO SET THE ADMIN password as the first thing you do, so that your neighbor can’t access your router anymore.
Give your network a network name so that you can find yours if there is more around you. Network name are called SSID, short for service set identifier
Now, go to Wireless -> Wireless connection, to set the Encryption security settings.
Set security mode to WEP,
Set the Transmit key to your choice, if you know that you wireless card has 4 keys as well, I would use key 4.
Set WEP encryption to: 128 bit 26 hex digits.
Go down to key 4, and find a combination of numbers and the letters a, b and c.
(ex. 414243444546474849404a4b4c) = 26 hex digits.
Save settings.
Now, before you leave, WRITE DOWN your SSID, your new password and key 4 with your settings, as you need to set your wireless card with the same settings.
Start -> settings -> network and right click your wireless connection and click properties.
At the top, choose Wireless network, find your network, (your SSID) choose properties and set these settings as you wrote down from the router.
Now, remove the cable and logo on wireless…..
/Teis
If this helped you, do vote.
Posted on Dec 11, 2008
Wireless router is not working
Go to Here for Linksys EasyLink Advisor (LELA). With this software you can monitor the routers status and troubleshoot.
Most trouble shooting involves disconnecting the power to the cable modem and the wrt54 router for about 10-20 seconds. Then plug in the modem until it lights, then plug in the router. The Advisor will then get a new address.
It also shows a graphic picture of your whole system.
I have a wrt54 and use this whenever I have a problem. I fix it then turn it off.
Hope this helps.
Good Luck
Feb 19, 2010 | Linksys Wireless-G WRT54GS Router...
Cannot access the internet through the router. Seems like the router and the modem are not communicating. When I bypass the router there is no problem.
make sure the router does not have the same ip address as the modem. change the last on the router xxx.xxx.xxx.001 to xxx.xxx.xxx.002
Jan 09, 2010 | Linksys Wireless-G WRT54G Router
Linksys WRT54 GC failed auto port forwarding
check in your pana sonic ipadreses then test in your network can you able ping of ip of cam?
If you can get ping and if you save ip forwarding port 80 to cam ip then check in camera that the settings of "access via interent is enabled" then you cana cces it with cam ip with 80 http port.
Jul 27, 2009 | Linksys WRT54GC Wireless Router
Ipod touch 2nd gen
Can you please tell us more specifically what the main problem is? To my understanding, it is a wireless connectivity problem with your iPod Touch. It's just a simple to check. Go to Wireless Network Settings or Wi-Fi settings of your iPod. Make sure it can see or detect the signal from your 2Wire. You'll just need to manually connect to it and enternet WEP key or Network key which you can find at the bottom or side of your 2Wire modem. That's the 10-digit code. If you have it entered, check the TCP/IP settings of your iPod, make sure the IP Address is set to Automatic or DHCP as well as the DNS Servers. That should fix it.
Jul 25, 2009 | 2wire 1800HG Router (RG1800HG00)
Bridge or Repeter mode.
It is possible but you will need to flash the router with custom firmware.
Here is how:
http://www.dd-wrt.com/wiki/index.php/Installation
This is only possible if you have two wrt54-g routers that are of one of these types:
WRT54-G ver 1
WRT54-G ver 2
WRT54-GL
(there is a sticker on the bottom that can tell you what version it is)
This is the article that I followed and it workes great.
http://www.dd-wrt.com/wiki/index.php/Wireless_Bridge
Apr 29, 2009 | Linksys Wireless-G WRT54G Router
Wireless router connection problems
Assuming "cannot connect to linksys router directly" means you cannot connect to a Wireless Lan managed by Linksys router,
1) try to connect new computer to LinkSys Router using a Lan cable, add new PC to your network.
2) recover protocol (WEP or WPA) and Key of WLAN (Passphrase or Key: TKIP or AES) either from other PC on same network either from your Router.
3) If you missed actual key you must connect to router and reset it to a new key to be eventually used for every connected device.
Call for detail on this possibility
Dec 29, 2008 | Linksys Access Point WAP54GP Wireless-G...
Lost internet connection via cable modem-router-tower
Alright, start with the basic Gateway IP. http://192.168.0.1 That is what i use to access my router's (yeah, we run just a few more computers than normal people) Anyways, If that doesnt work, then the router has been changed beyond a normal spectrum of Ip configurations. Next step is to recontact Linksys and Let them know directly that the IP Address for accessing the router is not working. Meaning you have no Access to the router at all. Almost all routers use the same base access router ip setup. Its rare to find different unless you are like a few people, who find they need to run at least 2 or more routers on the same internet connection because of too many computers.
Otherwise, follow this link:
http://lifehacker.com/software/feature/special-how-to-access-a-home-server-behind-a-routerfirewall-127276.php
Oct 29, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
544 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
