Question about HP Photosmart C4280 Aio Printer
Paper jam alarm and paper only starts to feed
Paper feeds to start print position and stops. printing starts and then paper jam alarm appears.
I had this problem at work several times. Unplug your printer from the back, wait 2 or 3 minutes, plug back in, problem solved! Also, if this doesn't work, (I'm at home now), but I believe that I got that info from the HP troubleshooting website. Good Luck!
Debbie
Posted on Dec 28, 2008
Panasonic KX-P7110 printer won't print from the auto feed tray, shows error when printing is attempted.
Please check the entire length of the paper feed path from input to output for a small piece of paper that is stuck causing a "Paper Jam".
You are lucky that you can still print manually as this usually shuts a printer down until the jam is found and removed!
Good Luck!
Rich Lilja
Jan 06, 2014 | Panasonic KX Office Equipment & Supplies
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
Nov 03, 2011 | Canon PIXMA MP495 InkJet Printer
Stops feeding paper at start of printing and repeatedly states there is a paper jam. why wont it feed and how do I get paper out as it is a sealed unit. initially paper was feeding too far thr so printing...
With out knowing the make and Model of the copier it can be difficult!
Suggest that you clean the rollers that pick up the paper with a clean lint free cloth and water.Ensure that you unplug the machine from the power point first.
Dec 06, 2009 | Office Equipment & Supplies
Epson RX500, Paper Jam - printing couldn't start
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button, applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Jan 06, 2009 | Epson Stylus RX500 All-In-One InkJet...
HP 6200 without telling it to print, feeds and jams continually
I already encounter that problem lately. when you print your documents, the only response of the printer is paper jam. feed and jam.
try this tip if acceptable of your situation now.
only to do is copy your documents by edit button and then select all or highlight all that your going to print and then right to copy
and then, open a new documents page set up if needed.
and then print it without saving your file because that already save.
Dec 05, 2008 | HP Officejet 6200 All-In-One InkJet...
Epson R220 paper feed.
TRY holding all 3 bottons at the same time for 20 sec this will reset the printer
Nov 18, 2008 | Epson Stylus Photo R220 InkJet Printer
Paper jam followed by printing pics
just check to see if there is any obstructions were the paper is going through, unplug printer cables, press power button for 20 seconds without any cables connected, it will refresh printer memory, connect cables back,try photocopy, if nogo, printer fualty
Nov 04, 2008 | Dell 948 All-In-One InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper feed problem
The fault is the paper stop sensor is broken. Have the same problem myself. I don't think there is an easy solution to this as the sensor arm will have to be replaced and I think the m/c would have to be stripped down to do it. Nice to know if anybody has any ideas though.
Nov 09, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP Photosmart C4280 Aio Printer Logo
165 people viewed this question
Seeker5211
Seeker5211
