Question about Toshiba 65H82 65" Rear Projection Television
Where to buy Signal Module
I have been trying to find a part that is no longer made. The part I need is for a Toshiba 65H82. It's called a signal/Conv Board PD0639D, the part # is 23787712 Any help would be appreciated
  • MikeSchulz Dec 11, 2008
    Sears does carry it and I also found it at Partstore.com. The company that is repairing my TV claims it cannot be found online and the TV can't be repaired.
    Got to love the internet!
    Genius:
  • 1,199 Answers
Go to www.sears.com parts dept.....have make and model ready!
I think this will fix ya!
Posted on Dec 11, 2008
Toshiba 65h82 has sound but no picture, what are likely causes?
Most likely you have a high voltage failure. This TV has 3 CRTs that are driven by high voltage. If one tube fails it shuts them all down. If the HV circuit has failed it may be time for a new TV
Feb 17, 2015 | Toshiba Televison & Video
I have a Toshiba 65H82 television with the wavy line problem. I have read the solutions on this site. It talks about the "hyper board." The list of boards in the service manual does not list a...
Hyper board is located under metal shield mounted on signal board in tv, buy repair kit from HERE and replace capacitors in hyper board to solve wavy picture problem in Toshiba 65H82
Thanks.
Mar 29, 2011 | Televison & Video
On start up the picture is very fuzzy, accompanied by vertical lines. After 5 plus minutes the picture improves and line mostly disappear. Not getting better and taking more time to clear. Ideas?
Yes, the model indicated has what is called a "HYPER BOARD"; this is a very common failure in most of their sets.
This board processes all signal from all inputs and what fails are there are a number of tiny surface mounted capacitors on the board that from heat and age dry out and fail- a cap that is down in value when hot will try to recover.
The board is no longer available from Toshiba, the only way to correct it is either send it out for rebuild/repair to a company like PTS Electronics or some shops will attempt the repair of the board in the set.
The last time I did this PTS wanted about two hundred dollars for the rebuild/repair.
The problem is even if rebuilt in four or five years the caps will dry out and fail again.
As the caps go down in value it will take longer and longer for the lines to go away.
I have seen about thirty of these sets with this problem.
Please feel free to comment here or if you have questions post a comment here.
I am here to help.
Regards, SD TECH
Nov 16, 2010 | Toshiba 65H82 65" Rear Projection...
RE: Toshiba 32AV502R 32
NO,Ur tv have problems.The Main Tuner Signal is dead,have burn electronics componnents.Still under warrenty call for service.Not Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Mar 17, 2010 | Toshiba 32AV502R LCD TV
I have a 57 in toshiba rear projection, picture just started jumping and went out, if you put it on another imput for gaming the picture is there but is rounded and is jumpy could you tell me what is wrong...
Possibly not repairable, because many problems are related to a board called the "hyper" board, which is mostly no longer available.-- Most picture problems other than convergence or a bad tube, which doesn't sound like yours.
Mar 08, 2010 | Toshiba 65H82 65" Rear Projection...
The picture is very fuzzy for the first 5-10 minutes of turning the tv on - after that the picture clears up.
These sets had some problems with what is called the Hyper Board. It processes all signal inside the set from all the inputs.
Usually if it is the problem there will be lines and or noise in the picture for several minutes. AS time goes on the period for it to clear up will get longer and longer.
What causes this is this board has a number of surface mounted filter caps that dry out and go bad--caps that are going tend to operate better after they get warm--there are numerous notes about this on the Toshiba Technical site.
The boards are usually soldered in and NO LONGER AVAILABLE FROM TOSHIBA--only two choices--someone needs to remove the board and replace about 10 surface mounted caps--most caps in sets are soldered on the bottom of the board (mounted on top and each has two leads that go thru the board) but these are tiny and have little tabs and are soldered to the TOP of the board.
Replacing them is not a job for a do it yourself person unless you have a lot of skill. The other option is there is a company called PTS Electronics (you can find them via the internet) who will if the board is shipped to them repair/rebuild the board for this problem--it is not cheap--I checked a site in the LA area and it costs about 220 plus S&H.
I have had three people here I helped with this problem who had the time and skill and did it themselves. Total parts cost for them was under 30 dollars. All three either were good at soldering or knew someone who with direction could do it.
Sooner or later the problem will take longer and longer to go away and at some point it will not go away as enough of the caps totally fail.
Let me know if you need help or have ANY questions----I am here to help people.
If this has helped you rate this solution as I do this here for FREE.
sd tech
Nov 28, 2009 | Toshiba 65H82 65" Rear Projection...
Toshiba 50H82 has wavy lines in screen for about
this is a very common problem in a lot of Toshiba sets of this type----bad caps(filter capacitors) on the "Hyper" board---it processes all signals in the set---it will start out where it clears up after warmup and as time goes by it will take longer and longer to clear up----the board is no longer available and the only way to repair is remove the one in the set and send it out for rebuild---most of the time this costs 3-4 hundred parts and labor(not worth doing)
Aug 07, 2009 | Toshiba 65H82 65" Rear Projection...
Line are off 65h82 tv
Thanks for Toshiba service phone number.
Jun 18, 2009 | Toshiba 65H82 65" Rear Projection...
Turn signals wont turn off
This could be a loose connection, or the signal timer relay has gone out.
Jul 27, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Toshiba 65H82 65" Rear Projection Television Logo
59 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
