Question about Olympus Camedia Stylus 300 Digital Camera
Broken camera I dropped my digital olympus on a tile floor. Since then, when I open the lense cover, the lense doesn't pop out, and the camera doesn't turn on to take pictures. I can still push quick view and can move pictures I've already taken around, but I just am unable to make the camera work since.
  • topzea Jun 27, 2008
    A month ago I took some pictures with my Olympus camedia C-50 zoom camera, some hours later when i opened it automatically zoomed in and i couldn't zoom out, can't change the mode or do any other thing else, I tried maybe i can format it but couldn't. what should I do, is it a mecanical problem or a software problem?
    Stephen(topzea@dbzmail.com)
  • Anonymous Aug 12, 2008
    When I open the lense cover, the lense doesn't pop out, and the camera doesn't turn on to take pictures.
    I can still push quick view and can move pictures I've already taken around, but I just am unable to make the camera work since.when I open the lense cover, the lense doesn't pop out, and the camera doesn't turn on to take pictures.
    Novelist:
  • 107 Answers
It is likely that your lens assembly was knocked out of alignment when you dropped the camera. When things do not line up inside the lens the whole unit cannot move in and out. This malfunction requires disassembly to fix, so you will have to get it to a professional for repair. There are providers online who can repair your camera, and also check with your manufacturer to see if they can service the camera at a reasonable rate. David Millier Advance Camera Repair
Posted on Mar 06, 2007
Can battery compartment be repaired when tabs are broken off which hold lid down?
possibly...if it is the body where the tabs are broken off the manufacturer (Olympus) might be able to replace the body shell. I'd check with them.
Aug 16, 2014 | Olympus SP-600UZ 12MP 15x OPT Zoom Digital...
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Sony DSC-T200 Dropped on floor - grinding noise
joy,
thank you for using fixya.
the zoom and focus assembly is at fault, the grinding noise and shacking is a result of s de-railed plastic gear.
if the camera is still under warranty have it serviced, take note that if the gear is broken and not de-railed, mounts may be broken also.
here is an example of the assembly.
hope this helps.
regards,
voodoo
Apr 29, 2009 | Sony Cybershot DSC-T200 Digital Camera
I droped olympus fe360 camera and the lense will not go back in i can hear it but no action !
The problem you are describing is a problem with something in the lens assembly. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $68.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Apr 13, 2009 | Olympus FE-360 Digital Camera
Camera won't power on. Lense won't retract.
Pls check the batteries are they supplying full power to camera are they aged or old try replacing them with good power batts and Memory card try re formatting it on a PC card reader
lense is coming out at full length or there is a grinding noise or abnormal behavior in it pls check may be u dropped ur camera or any other incident broken its lense gear.
pls check and reply me for more help
Feb 27, 2009 | Olympus FE-220 Digital Camera
OLYMPUS STYLUS 740 ALL WEATHER
If it works, use it as long as you can.
Fixing snap-shooters is generally not worth it,
since digital cameras evolve rapidly and lose
value even faster with age.
Martin
Nov 09, 2008 | Olympus Stylus 700 / 700 Digital Camera
Got a problem with the lense
I had the same problem with mine after it had been dropped on the ground.  I undid the two screws at the bottom which holds the sliding lens cover on and took the cover off.  Check the small black lever inside.  It might be broken.  I replaced the part from an older model and but the cover back on.  I works fine now.  I hope this helps
Feb 04, 2008 | Olympus MJU 400 Digital Camera
Black line across display screen
Beyond repair I would imagine - these thing cannot usuaslly be repaired in these circumstances.
Oct 31, 2007 | Olympus Camedia C-50 Zoom Digital Camera
Camera fell on floor and lens popped out
http://www.lensbabies.com/index.php?r=GSLBGeneral&gclid=CJSbjPWUrI0CFQqgYgodlz7D1Q chek site you will find diagram
Jul 16, 2007 | Olympus C-3000 Zoom Digital Camera
Retractable Lense Does Not Open
This thread might be relevant to your problem: http://www.fixya.com/problems-solutions/t114846,p220455/Olympus-Digital-Cameras.aspx Comment on what you saw in there when you opened it up, compared to the other user. Good luck
Jun 21, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
Olympus Camedia Stylus 300 Digital Camera Logo
106 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you an Olympus Camera Expert? Answer questions, earn points and help others
