After shut circuit breaker off to replace an outlet on same circuit. Now Icebox model 85000 will not turn on. The screen energizes but then I don't even get led on front of unit. Who does a person ask for help?? Just let me know what it might be and I'll take the thing apart. I've gotten good 6 years out of the unit but should go for longer than that.
I had the same problem with my FS04 unit (under the cabinet, flip screen). Amber light was on and humming sound comming from speakers. Motherboard had to be repaired by ICEBOX dealer that sold me my unit.
Their website is www.lordantech.com
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
