Question about Whirlpool GS6NBEXR Side by Side Refrigerator
ODOR COMING FROM OUTSIDE REFRIGERATOR
Lost all of my food in the freezer during Hurricane Ike. I believe some popsicles melted and ran down through the vent. There is a strong, sickly sweet smell coming from the outside of the refrigerator. It is not all of the time but when it happens, you can't stand to stay in the kitchen. Is there a way to get to a drip pan or something to fix this problem. HELP!!
    New Friend:
I have recently suffered the same situation do to the latest hurricane. unfortunatly my whirlpool gold model gs6shexmq00 has the filter in the way. after pulling the screws and the filter somewhat out of the way, tubes restrict the filter from actually getting all the way out of the way to remove the tray. (if it can be removed at all, i dont know i didnt get that far) do i continue ripping this thing apart, taking apart tubes from the filter and so on? Side note: there is no water in this tray, there is a completely black disgusting residue with mold on growing on tom. having youngins in the house i need to rid of this asap. please help thanks in advance.
Posted on Dec 18, 2012
  • Whirlpool Master
  • 5,568 Answers
Most refrigerators have a catch basin under the cabinet that is accessible after removal of the trim at the bottom.  This trim grill can have a half-dozen different fasteners on it although most have plastic extensions that are inserted into matching holes in the sheet metal that forms the base of the unit.
Try (gently) lifting the bottom lip of the grill while pulling it outward; if this frees the bottom edge, then angle the grill outward at the bottom and pulling it downward to free the upper edge. On some units there may also be a knob-like section that when turned releases the grill.
You didn't mention brand and model but with these, you should be able to find a downloadable manual on line that would detail how to remove the grill.
Once the grill is out of the way, most catch basins simply are lifted up and pulled out for cleaning and emptying.
To fully rid the fridge of odors, it may be necessary to pour hot (not boiling) water down any drains you see in each compartment several times to flush them.  Obviously, the catch basin should be in place when doing this and they can be quite shallow.
Good luck-
Posted on Dec 11, 2008
2 Suggested Answers
futureloginn
  • 734 Answers
SOURCE: BAD SMELL FROM OUTSIDE OF REFRIGERATOR
there is sum short circuit in refrigerator wiring, or in the compressor.
Thanks
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
Freezer not freezing food
try turning off the whole of the freezer off then clean it and clear all the food out then switch back on then put it on cold as normal then click super or too make the process faster button to make the freezer colder
Please vote if works thanks :)
Jul 22, 2009 | Maytag MSD2756G Side by Side Refrigerator
Odor from outside of Refrigerator
pull out the fridge and remove the back panel, and clean that area. Make sure no food is stuck under the fridge also. A rotten piece of fruit or other food, once under there, will smell until it totally decomposes. We have seen this before. Hope this helps!
Feb 13, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Thanks
Dec 11, 2008 | Whirlpool GS6NBEXR Side by Side...
System was off
Hello. Did you try running the water through the door until it becomes room temperature? This will completely flush out the water resouvior in the fresh food section. When it comes to the ice tasting bad, a lot of the time it is from something that has gone bad in or behind the crisper drawers. Take the drawers out and check. You may be thinking how can something in the frig compartment effect the ice? The frig is cooled by the freezer by a opening in the top and bottom of the center divider. Hopefully this helps.
Dec 03, 2008 | Estate TS25AFXK Side by Side Refrigerator
Freezer section not cold enough/fridge ok
sounds as if you might have a compressor related sealed system problem, youll have 5 year war on such an issue from the manufacture
Oct 29, 2008 | Maytag MSD2758GEW
Odor coming fromback panel
you can also use bleach let it sit there for a couple of days so it will kill bacteria and odor the smell is all the meat and blood that drain down to the pan
Oct 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I lost power for several days during Hurricane Ike. When the power came back on, I cleaned out the ice maker bucket and let it make new ice. It makes ice and the light comes on when you press the...
when you repl the filter it has to be purged to bleed all the air out just keep askig for wtr until you purge all the ait out dispence at least 15 large glases of wtr
Oct 14, 2008 | Whirlpool Refrigerators
Refrigerator odor
hi there,
the bad odour could be from the compressor, evaporator or heat exchanger. can you supply the complete model # please?
thanks.
Sep 25, 2008 | Whirlpool Refrigerators
Samasung RS2577Sl
It might be that your fridge went into something called 'demo mode' that shuts the compressor down so as not to waste electricity on the showroom floor. The freezer and fridge sides both start to warm up, but the temperatures shown on the outside of the door never change, so you don't know you have a problem until you open the fridge or freezer and find you have a melted mess. My Samsung is 7 years old and we run into this problem frequently when our power is on and off, like just recently with hurricane Ike. Per the Samsung website, the cure for 'demo mode' is to unplug the fridge for 1 minute then plug it back in. They also suggested pressing Power Freeze and Freezer Temp together for 8 seconds until you hear a chime to cancel demo mode. Good luck. I really dislike this machine.
Jun 29, 2008 | Samsung RS2578BB Side by Side Refrigerator
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
139 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
