Question about Initial HDTV-322 32 in. LCD Television
Initial 32 HDTV
I have about a 2" black faded line on my tv and it won't go away. I have power cycled it several times. It still doe not go away. I have been letting it run 24/7 for the past week. It still is there. Can someone please help? Thanks, Kurt
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: need direct tv remote code for initial hdtv 322
11603, 11990.
You can get the manual for the remote here on link below if it is a rc65.
http://www.directv.com/learn/pdf/Remote_Controls/DIRECTVRC65forWeb.pdf
Posted on Apr 18, 2010
  • 321 Answers
SOURCE: DVD Player not working 32" Initial HDTV built-in DVD
Hi,i think that is the laser lens is dirty
try to clean it ,with a long q tips an alcool, unplug the set before doing so, it solved the problem usely.
but it can be the laser assembly and he will have to be replace no alignement needs...
hope that will help you
regards A.S.
Posted on May 05, 2010
Sony wega kde-61xbr950
Can be a problem with a misplaced connection, more likely the Ysus card to be replaced.
Aug 30, 2008 | Sony WEGA KDE-50XBR950 50 in. Plasma HDTV
We received a second hand 32" insignia about 2
The display panel is bad and to expensive to fix. You can check the board at the top . This is the T con board . Be sure that the flat cables ans pluggin good.
Mar 21, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
I've had a rca model l32hd31yx12 and recently began to get white vertical lines after a minute they fade but certain screen changes like volume adjustments and the lines come back and fade again same thing...
Sounds like the power supply has filtering issues, in other words bad capacitors. its best to have a tv shop take a look at it. they shouldn't charge you. good luck
Nov 06, 2010 | RCA L32HD31 32 in. LCD HDTV
Brother 420CN printer will not print black ink. Have replaced the cartridge and after several cleaning cycles, it still will not print properly. Test Print shows colors are fine but black ink is hit and...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Dec 20, 2009 | Brother MFC 420CN All-In-One InkJet...
When turned on, no picture, sound or response. LED is OK
I had a similar problem with my HANNSLounge 32", the screen switched on with green light but none of the front panel buttons worked (screen is black apart from showing the input source in the top left).
After powering off numerous times I tried starting up with a blank SD card in the reader and the tv cycled between red green and blue screens and then reset itself. (Some sort of firmware restore?) After which point I had a working screen again! (Will have to see how long it lasts for!)
Feb 12, 2009 | Hannspree HANNslounge 32 in. LCD HDTV 32
My Sharp Aquos
Burnt out pixel line. Usually the panel needs replacing
Jul 13, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture fades to black then reappears and repeats fades to black .
Is the sound ok. Yust the Picture. If both dissapear replace power supply board. That is the main big board with the most heatsinks on it. Main power gos from a switch board to main power supply.
Nov 21, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vertical black line
does this verticl line go all the way form top to bottom or is it about 5-7 in long in the center of the screen and does it some times change in color with the picture.
Aug 11, 2007 | Samsung HC-P4752W 47" Rear Projection...
Initial HDTV-322 32 in. LCD Television Logo
26 people viewed this question
Top Initial Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
