Question about Hitachi CP-S240 Multimedia Projector
Using the computer monitor and the projector at the same time?
How do I use my desktop computer monitor and the projector at the same time? I have a CP-S240 projector and i would like to project my image on the screen in my classroom as well as continuing to see the information on my destktop monitor. Are there any certain cords i need and if so can you send me a link so i can see as to which kind they are and if i have them or not.
Brian Pohl
I kind of have a solution for you. I know you need a splitter cable. You might want to go to Radio Shack or your local geek store or the manufacturer of the desktop and see what they have as far as accessories.
Get yourself a laptop and run the projector from that, All you have to do then is hold down the FN key while pressing (depending on the make and model) F3 or F7. I use two differant laptops and those are the keys I use. I hope that I helped.
Posted on Dec 11, 2008
Projector does not recognize computer
Hi Becki.
Projectors will usually be identified on your computer as additional or optional screens/monitors. Depending on your setup (laptop/desktop) you may have some alt keyboard buttons with icons for single/multi screens. You will also likely have monitor control panels or non-windows equivalents. In Windows, for instance, right-clicking the desktop will usually bring up a monitor properties page. There you may be able to then select if the projector is a mirror of your desktop, an extension, projector only, or computer only.
if the computer says it sees the monitor, then you'll likely need to toggle whatever sort of menus the projector has to select the input port. Looking through the manual ( ) , suffice to say that there are multiple ways to connect and, with that, plenty of ways to have your cable be hooked up and ignored nonetheless.
Hoping this helps!
Nov 30, 2015 | Hitachi CP-X251 LCD Projector
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
How do i switch to external monitor
Virtually all IBM and Lenovo ThinkPad and ThinkCenter laptops allow you to hook up an additional monitor or projector to the computer. When you add an external monitor or projector to your notebook, you can choose to view the display on the computer, on the external device, or on both the laptop and the external monitor or projector at the same time. Toggling between viewing devices is as simple as pressing a couple of keys on the keyboard.
Shut down the laptop. Plug the VGA monitor cable from the external monitor or projector into the blue VGA port on the back of the computer. Turn on the external monitor or projector first, and then the Lenovo laptop. Allow the notebook to boot into Windows normally. Press the "Fn" and "F7" keys at the same time to switch the display from the laptop to the external monitor or projector. Press the "Fn" and "F7" keys again to enable the display on both the laptop and the external display device. Press the "Fn" and "F7" keys again to display screen contents only on the laptop LCD. choose support you need enable tv out on thinkpad
Feb 13, 2013 | IBM Lenovo 3000 N200 PC Desktop
My Windows XP is connected to my Epson Powerlite S3, but the screen is blue with the words Source: Computer (Auto) No Signal on it. When I click "Help" on the projector, it takes me to a screen...
'No signal' and 'unsupported signal' messages mean 1 of 2 things, either the VGA output is off(laptop) or the display resolution is set too high(laptop and desktop). Assuming the VGA cable you are using is good, try this:
Desktop: hook the computer back up too your computer monitor & set the computer to the basic VGA resolution. For windows XP, right click a blank area on the desktop, click 'properties' on the dropdown menu, click settings. Write down the numbers in the 'screen resolution' and 'color quality' boxes!
Drag the 'screen resolution' all the way down to then 'less' side. Then change the 'color quality' to the lowest setting. Click apply, then answer yes (the display will look UGLY - don't worry!!) Now connect your computer back to your projector. If it works, then the resolution you use on your desktop monitor is not supported on your projector. Experiment with different resolutions to see which one looks best on your projector. You will need to change the settings each time you switch monitor to projector.
Laptop: by default the VGA connector on your laptop is off. To turn it on, look for a blue symbol on one of your function (F1, F2, F3...) keys. It looks like an old TV with a line on both sides 'O' (F4 on HP) Press & hold the blue button (on the lower left of the keyboard, usually to the left of control ) and tap the bleu button you just found. Let go & give you're a computer a few seconds to change over. If the laptop screen goes blank, you found the correct button! The display image should now be visible. Repeat this 1 to 2 times to change it back to laptop display.
If you did not see the display on the projector, 2 other issues are possible. First, verify that the VGA output on the laptop is working - connect the laptop to a regular computer monitor & change the display resolution to the lowest settings (see desktop above), then try it again on the projector. If you cannot get an image on a computer monitor, your laptop settings may need to be adjusted in the same dialogue box as the settings. Monitor #1 is the laptop display, Monitor #2 is the external output.
Happy viewing :)
Jun 12, 2011 | Epson PowerLite S3 Multimedia Projector
I'm supposed to use computer desktop for my classroom presentation, the plan is I'm going to use my LCD monitor to view my presentation while my students will look at screen shown from the projector. To...
The least expensive way is to use a VGA splitter It looks like a Y. Plug in the one end to your computer then the other two ends will go to your projector and monitor. The one end will be a MALE and the other two ends will be FEMALE. You will still need to 2 other VGA cables to connect the Y to your projector and monitor. When you purchase a Y they are not long at all.
Jun 17, 2010 | Acer PD100 Multimedia Projector
How do you connect the computor screen to a video projector
Dear sir,
If you are using Laptop directly connect the RGB1 to Laptop and select the input source as RGB1 in Projector. And if you are using Desktop First connect the CPU to Projector and from projector output to Your Monitor.
Thanking you,
Sep 19, 2009 | Audio Players & Recorders
The monitor connected to a docking station will not resize after using laptop with an InFocus projector
The inFocus projectors typically force a lower screen resolution - you have to go back and reset the monitor to it's proper resolution. Only takes a few seconds - go onto a blank area of your desktop, right click, select properties, settings, then adjust the resolution. Hope that helps - I've had the same thing happen when using a projector, and have never been able to have the screen automagically "readjust" after using the projector...
May 19, 2009 | Dell 2007FPW UltraSharp 2007FP 20.1-inch...
My computer monitor loses resolution
try running your graphics card in separate screen mode im thinking you may have it in clone mode and is running both displays at the same res, or if the projector can handle it try running the projector at higher res
Dec 15, 2008 | InFocus LP70+ Multimedia Projector
I need the infocus LP 500 projector driver thanks Hector
Here is the InFocus Site pertaining to your projector.
There usually aren't drivers for projectors, When you connect a projector to your computer Windows,
(assuming that is what you are using) see's it as another monitor. Start the computer with the projector plugged in to the second graphics port. Right click the desktop/properties go to settings tab. On the second monitor adjust the resolution to whatever the native res is on the projector is. That should do it.
Post back with more details if you need more.
Sep 27, 2008 | InFocus LightPort (NP-LP98-HT) for PC
Cannot project movies in powerpoint
I have encountered this same problem once in the office when i was trying to do the same thing.
The solution:
*Assuming you have windows xp*
1) make sure the projector and the laptop are connected (FN+F8), do a right click anywhere in your desktop then go to settings by default Monitor 1 would be your Lattitude D620 and Monitor 2 should be your projector, to make sure of that click on the 'identify' it should show a 1 in your laptop and a 2 on the projector
2) now select monitor 2 and select 'use this device as my primary monitor' check mark, by doing this your videos should play in your monitor but they will be a blank/black screen on the laptop (basically we are reverting the order).
Apr 20, 2008 | Dell Latitude D620 Notebook
Hitachi CP-S240 Multimedia Projector Logo
342 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
