I have a Toshiba 46HM95 46 in. HDTV Television and I turn it on and I can hear a very light buzzing sound and the screen comes on for five seconds and then goes out and the buzzing goes way and the green light flashes three times and goes out then the red flashes in sets of three. I have removed the rear panel and watched to see what happens and the bulb comes at the same time buzzing startson and light gets brighter. then bulb goes out and so does buzzing. Can some one please help. I have a volt ohm meter if some one can talk me through it.
That buzzing is the high end power trying to turn the lamp on.... the electrical current and shock is what turn your lamp on your tv which is what the buzzing is dont worry thats normal...however your solution is buy a new lamp for your tv but make sure its the right serial number for lamp u cant just buy any lamp. best place to buy one ebay.... as in the lamp still trying to light up its only because the electrical current going into the lamp and then cutting off causing the red light on your tv....so other words all it is is the lamp... CAUTION!!!! those lamps get up to 400 degrees unplug tv to ensure no electrical current.... hope i helped.... JACOB WINKLER
SOURCE: won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
SOURCE: I have a Toshiba 52HMX94 rear projection T.V.,
Your TV requires ballast power supply board that gives you buzzing noise when TV turns ON.
Ballast supply board is available in Part Store and replacement of that board requires expertise.
