Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
I have a double picture on my 6 year old Hitachi Projection tv.
How do I get the front screen off to clean the mirror the tv .It is a 65 in magic focus .I have did the magic fouse thing ,but it leaves a yellow line left on the top while it is going threw its thing ,and that is just how far the tv is off and the double picture is. I got the speaker cover off it snaped off .but how do I get the screen off .
  • 10,594 Answers
Required info are available in service manual with details and schematics.
You can buy service manual from Manual Zone for your Hitachi 51F500 TV.
Thank you.
Posted on Dec 11, 2008
I have a 65 inch Hitachi projection TV and all of a sudden lines apperaed on the screen that runs across the upper part of screen. I tried using the"Magic Focus" setting to get rid of these lines...
The tv Magic Focus button don't solved these R,G,B colors lines mis alignments problems.Mean ur tv have a convergence pictures problems,it is dead.Ur tv now have any colors lines like R,G,B mis alignments,have a colors shadows picture or a 3D pictures look alike?Yes,mean ur tv convergence board it is dead to causes all of these pictures problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 24, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
51 Hitachi rear projection 6 years old, can't get it to focus, Has sound. Can only get the picture to come in abpout 80%. Around the perimeter, sports scores and subtitels are not readable. Used the fucus...
Flash Focus magic button no longer work.The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures problems.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost $300-350 for parts and labors.
Oct 13, 2010 | Hitachi 51F500 51" Rear Projection...
65SWX20B 65 in. Rear Projection Television: how do i clean my Hitachi 65SWX20B 65 in. Rear Pro...
Remove the upper back cover of the television and clean the back of the screen, the mirror which reflects the image onto the screen, the focusing lenses (do not loosen or remove the wingnuts).
May 05, 2010 | Hitachi 65SWX20B 65" Rear Projection...
My 6 year old 65xwx20b tv convergence problem
Good Day,
This is a common problem with this TV, but there is an upgrade to correct the CONVERVGENCE circuit problem.
If you want to repair this concern yourself: Contact: B&D ENTERPRISES,
1-800-458-6053, www.bdent.com and ask for KIT10 for your Hitachi TV.
If you want some else to do the repair for you call an Authorized Service Center.
Needs convergence IC's
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Good Luck,BIG IRISH.
Nov 23, 2009 | Hitachi Director's Series 65XWX20B 65"...
Hitachi projection tv.7years old.can i clean or change the bulb,w
Remove the front screen
Carefully Remove it
Pull the bottom off
Then remove the screws on the bottom of the screen
when you have them off lift the screen assembly up
be careful of the wire going to the panel
you can move the screen to the side and gain acces with out unplugging the wire but again be careful
clean the mirror and the projection bulbs
with glass cleaner and spray only on to the rag not the mirror or projection bulbs
Put it all back together and your picture should be bright as before
Feb 09, 2009 | Televison & Video
Darker picture
Clean the lenes inside of the TV and the mirror and screen (a little dust build up on these three things adds up quick!) also if you smoke that can build up too! these tvs have too be cleaned inside
Nov 28, 2008 | Hitachi 57F500 57" Rear Projection...
Cleanng the projection mirror
remove the speaker grill, you will see the screws holding the front screen, remove the screws and the connectors going to it and slide the screen up and off.
Sep 18, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Double focused, red and green, bow in picture top and bottom
hi
You have a convergence problem
If the set has auto focus and will not complete its cycle.
The Auto focus module is bad, (expensive)
If it completes and the problem is still there.
Then check for bad conv. drivers (stk****) or cold solder joint on one or more of the 3 drivers pins.
Guy9
Jul 08, 2008 | Hitachi 65S700 65" Rear Projection HDTV
Projection tv
Yes you can safely clean tv, just remove front speaker panel and you should see screws holding up front prot. screen. Becareful not to snap screws. You can take screen out and there is a mirror that you can clean and 3 lenses.
Apr 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
129 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
