How can I reach Ohms? - Computers & Internet
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    You can't reach Ohms just like that, can i hepl you?
    Novelist:
    Champion:
  • 233 Answers
His number is U812.
Posted on Dec 26, 2008
I defrosted my Samsung coils and when turning it on and there is ice building up already. Should this happen?
May need new defrost heater. If so, that heater will read infinite ohms. A good heater will read 50 to 200 ohms. Change small inexpensive clip-on thermostat at same time. But don't worry about a little ice build-up if your temps are okay. Excessive ice build-up will be shown by your hearing a crunchy sound when you reach into the freezer to press your hand against its thin rear wall.
Oct 18, 2014 | Samsung RS2556 Side by Side Refrigerator
How to hook the 3490 to get 4 ohms
Hello
The output impedence of the amp is 8 Ohms. It can also be connected to a 4 Ohms speaker, but the reted output will be higher than specifed, and the sound quality will be reduced. You cant get an putput impedece to this amp by no means, as its' output is desigend to match 8 Ohms/channel. If you have only spekers with 4ohms impedence, connect two of the in serieal connection, so that, they together will reach a resultant impedence of 4Ohms. Similarly connect an other two spekers in series to the other channel too. OK.
Dec 24, 2011 | Harman Kardon Audio Players & Recorders
AEG Favorit 40300 dishwasher - Works fine until it reaches ''drying'' cycles when it trips the house earth leakage switch. Measurements between mains plug and earth is less than 100K ohms but after an...
I have the very same problem...did you get he problem solved? Could you please email me if you got it fixed? my email is: c.e.mostert@gmail.com
Thank You!
Mar 09, 2010 | Dishwashers
Hi can you tell me the firing order for 87 gpx 750. Regards Paul
The firing order on your bike is 1,3,4,2. These bikes use what is called a wasted spark system. They fire whenever the piston reaches top dead centre.
That is to say they fire on top dead centre compression as well as top dead centre rock-over( exhaust/inlet ). Each coil has two leads on them.
The left coil goes to number 1 & 4 cylinders.
The right coil goes to number 2 & 3 cylinders.
The GPX 750(like most road bikes) have a resistor type spark plug cap on them that was prone to cause problems.
To test the coils/caps, use a multi-meter to test their secondary resistance.
To do this set the meter to kilo-ohms(1000 ohms), place one meter probe in one plug cap & the other probe in the other plug cap( i.e. 1&4, 2&3 )
The meter should read 10kilo-ohms to 15 kilo-ohms.
If it reads higher than that try un-screwing each cap & test the coils with the caps removed by probing the leads. If the coils(without caps)read about 5 to
10 kilo-ohms, check the caps.
The caps should read 5 kilo-ohms each.
It is very common to find these open-circuited.
Replace any open circuit caps.
I hope this has been of some help.
Otherwise if you can be a little more spacific with your problem I will try to help further.
Regards Andrew Porrelli
Jan 28, 2010 | 1987 kawasaki GPX 750 R
Oven fails to reach correct operating temperature. Set at 400 = actual 300 temp. Temp probe is clean.
Clean and working correctly are 2 different things.
Unplug the range. Remove the temp sensor. Use a meter set for ohms and read 1050 to 1150 ohms at room temperature.
If it reads OK replace the electronic control. If it reads bad replace the temp sensor.
Jan 04, 2010 | GE Kitchen Ranges
Oven will not reach set tempeture. I set it for 350, but after 2 hrs it had only reached a tempeture of 230.
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Sensor location
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Dec 13, 2009 | Ovens
F3 code appears after oven reaches temperature. Have tried replacing oven temperature sensor. Any suggestions?
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
Dec 05, 2009 | Amana ACS3350 Gas Kitchen Range
My kitchenaide gas range "beeps" when the temo is reached - say 350 but it actually takes almost 30 minutes for the oven to actually get to that temp. Why does it beep when the temp was actually +/- 275?
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
Additional Information_ The oven control will sound a beep, if there are issues with the resistance transfer between the control and oven sensor. The sensor is located, inside of the oven, on the back side of the inside wall. It will look like a 5 inch probe. You will need to remove the sensor from the back of the unit. be sure to unscrew the screws that hold the housing on the inside of the oven back wall. once they are removed, the sensor can be extracted for testing. Use the sensor contacts for testing.
Nov 17, 2009 | KitchenAid KESC307 Electric Kitchen Range
F7:EO error comes up and oven shuts off - does not reach it's oven temp......
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
Nov 03, 2009 | KitchenAid Kitchen Ranges
F3 code
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
((If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.))
Nov 03, 2009 | Ovens
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
