Question about Lanzar VIBE266 Car Audio Amplifier
Amp LED flashes on but right back off
I have a lanzar vibe 286 4000 watt amp. i have a 4ga. wiring kit. It was working when i first hooked up now it wont even turn on, i tried my old amp and it does the same thing. i sold my old amp and it works fine with the guy who bought it. I dont know what this could mean so if anyone has an idea i would appreciate it..??? could i just need a new cd player???
Your amp will end up catching on fire... the ground on the inside (JUMPER) disconnected from my laznar, and it fried one of the transistors, open up your amp and check the components, if one is lose resolder it. DO NOT OPEN IF YOU HAVE A WARRANTY STILL!!!
--TKBreuer
Posted on Nov 11, 2008
  • 156 Answers
This sounds like a problem with the power input to the amplifier; it's possible, but unlikely, that your CD player is causing it. Before you can do any real troubleshooting, you need a voltmeter. When your CD player is turned on, you should get a voltmeter reading of around 12 volts at the amplifier's remote terminal and B+ (power) terminal. If your main power wire doesn't show voltage, check for a loose or corroded connection at the battery or fuseholder, and try replacing the fuse (even if it looks okay). If there's no voltage on the remote wire, it may be pinched or shorted between the CD player and the amplifier, or the CD player may be faulty. If you get a good voltage reading on both wires, but the amp won't turn on, then you have a problem in the amplifier.
Posted on Mar 07, 2007
Will a Lanzar Vibe 286 4000 watt amp push a power acoustik fubr 12 700 rms 1800 max ....
Yes it should do the job. You will need to wire the sub in series and make sure you have a 4ohm load on the amp. It should be right at around 700 watts RMS @ 12-13 volts.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
May 18, 2012 | Lanzar VIBE266 Car Audio Amplifier
How do i reset my 4000 watt lanzar vibe 286 from being in protect mode
You can only reset it by disconnecting power to it. If it is in protect you may want to check your speakers and speaker wires for shorts and/or grounds. If they check out all right you may have internal problems in the amp.
Oct 28, 2011 | Lanzar VIBE286 Car Audio Amplifier
Lanzar vibe 256 battery wiring in my room, how?
try looking it up on you tube ive seen a introductory on how its done ..just type in how to hook up an amp in my living room i dont think you will need a battery..lol
Feb 23, 2010 | Lanzar VIBE256 Car Audio Amplifier
Lanzar 800 watt amp protect mode stays on
protect mode usaully means that something has disrupted the power of feed lines to the subwoofer/speakers possibly fuse is blown in amp or amp is blown in which we hope not. see if you have a warrenty if blown and send back or bring it to where you purchased it from.
Aug 01, 2009 | Lanzar VIBE266 Car Audio Amplifier
I have a lanzar vibe 255 can u help me?
Double check your connections. Use volt meter to co firm proper voltage. A test light can still light up with low vol
.A thumbs up would be greatly appreciated if this answer is helpful to you.
Jun 28, 2009 | Lanzar Vibe 255 Car Audio Amplifier
Lanzar vibe 230 400 watts amp
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jan 27, 2008 | Lanzar Vibe 235 Car Audio Amplifier
Lanzar Vibe 1200D protection light
You will need to show it to a service technician as it seems the output section has blown so it remains in protect mode. One reason (could be) that the input to the amp was high and may have been clipping for some time before the amp decided it could take it no more
Jan 14, 2008 | Lanzar Vibe 1200D Car Audio Amplifier
Audio bahn 1205n
sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
Nov 28, 2007 | Lanzar 2H 1000W MOSFET AMP Car Audio...
My vibe 286 4000 watt lanzar amp wont stay on..
Check your speaker load. It probably should be 4 ohms per channel. Also, if you are bridging then you must double your ohms load. It may be that your old amp could tolerate a lower impedence (ohms load) than the new amp. Do this now so you don't fry your amp. Good luck.
Mar 03, 2007 | Lanzar VIBE266 Car Audio Amplifier
Lanzar VIBE266 Car Audio Amplifier Logo
99 people viewed this question
Top Lanzar Car Audio & Video Experts
Mike Duncan
Mike Duncan
Morne Olivier
Joe Alexander
Joe Alexander
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
