Hooked up my speakers to my computer it is a hp windows 2000 but all they do is click have bought 2 different speakers thinkin that this was the problem but does it with both of them
  • 43 Answers
Update your speaker or sound drivers.
Posted on Dec 16, 2008
Why aren't my speakers producing sound?
click start control panel hardware and sound manage audio devices playback you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of of the playback list also right click on the speaker select properties you should see a few tabs general levels enhancement and advanced you might find you need to select a different option possibly stereo or dvd or studio quality windows7
hope it helps
Mar 02, 2012 | Audio Players & Recorders
Hooked it up to my receiver which works perfectly for other devices. Cycled through every setting on the receiver...none work. I just have the red and white hooked into the back properly. I am pretty tech...
The modern computers are set up like an amp with different speaker sets. Windows allows for this under normal circumstances, but when you plug in this turntable the computer fails to find the correct speakers.
- Goto the windows start button - Control panel - Sound - Playback - you will see a number of speaker options and at least one meter that is moving up and down with the sound which you can't hear at the moment. You can do one of two options to fix this.
1) Easiest option, but may cause trouble should you change or add to your physical speakers in the future. - Double click on the speaker with the moving meter, and disable it. A new speaker is then chosen, and if that isn't the right one then do the same thing until the right speaker combo is selected.
2) The best option, as it won't cause future conflict problems. - Ignore the speaker with the working meter. Go to another speaker and double click on it. - Click advanced Tab - Click Test - If you don't hear anything, then move onto the next speaker. If you do hear a sound, then this is the right speaker configuration for your computer. You may have more than one sound card, and likely more than one input. - Once you find the correct speaker, then go back to the main speaker window and single click the speaker to highlight it. - Near the bottom of the window is a pull down menu to make that speaker your default. Do this, and all sound will work.
I can't help you with the amp question, as my ION recorder doesn't have the red/white output jacks for the stereo amp. The only thing I can suggest is it might be the setting on your amp where you choose your input mode.
Dec 26, 2010 | ION Audio Vinyl Recording Turntable
Problem hooking up bose speakers
mcdevito75 here, The HP speakers that came with your computer work fine, the bose speakers work fine on your other computer, the plug on the Bose speakers is a little shorter than the HP speakers, and only the right Boss speaker is working, HMM, Check the Bose speakers, both of them for a volume control 1 of them may need adjustment on this particular computer. If that"s not it, I would speak to a Radio Shack, Staples etc.
Jul 04, 2010 | Bose Companion 2 Series II Multimedia...
Can dell speakers work with a hp computer xp windows
Speakers are speakers. The label on them makes absolutely no difference. Use them wherever you need to.
Jun 18, 2010 | Dell AX210 2 Speakers
I have bought my hp compaq 610 laptop one months ago but my laptop speaker is not working but with headphone it is working what should i do?
Do you hear any sound? If it is faint, try stopping and restarting the audio services. (for Windows Vista and 7) Click the Start button and type Run, click on Run. (alt press and hold the Windows key and then type r)
Type services.msc in the window. Then scroll through the list and select and click Stop for all audio services. Then repeat this but click Start for each one. Click Apply and then OK.
If you do not hear any sound, open the device manager and see if there is an exclamation point or an x (usually in a triangle) at the audio device lines. Start > Control Panel > Hardware and Sound. Right click on the line and choose Properties and try updating the driver. Check Windows Update and HP Update for any available driver.
I hope this helps.
(if these don't work, the wire from the motherboard to the speakers may be damaged/disconnected in the laptop case.)
May 03, 2010 | HP Compaq Computer Speakers
Can i hook up my quickcam for notebooks to my mac?
Check here for MAC compatible cameras.
Manufacturer/Model Driver version Platforms Meets requirements
3com Home Connect 6.6.4 Windows 2000, Me, 98 Yes
Apple iSight (Firewire) Firmware 1.0 Mac OS X (Pantder) Yes
BTC PC 380 Intel 3.20.1001.0 Windows XP Yes
Creative WebCam Go Plus 1.0 Windows XP, Me, 98 Yes
Creative WebCam (WDM) Windows Yes
D-Link USB WebCam(DSB-C100) 0921 Windows XP, 2000, Me, 98Mac 9.2 and 9.1 Yes*
IBM Ultraport Camera 2 Most Current Windows 2000 Yes
Intel Deluxe PC Camera 1.0 Windows XP, 2000 Yes
Intel Easy PC Camera 1.0 Windows XP, 2000, Me, 98 Yes
Intel PC Camera CS 110 Windows X Yes
Irez Kritter USB 1.02b4 Windows 2000, Me, 98,Mac 9.1 Yes*
Irez StealtdFire 1.2 Mac 9.2, 9.1, 9.0.4 Yes
Logitech ClickSmart510 Windows Yes
Logitech QuickCam traveler 6.0.1 Windows 2000 Yes
Logitech QuickCam Web 6.0.1 Windows 2000 Yes
Logitech QuickCam Express 6.0.1 Windows 2000 Yes*
Logitech QuickCam Pro 3000 6.0.1 Windows XP, 2000, Me, Mac 9.2 and 9.1 Yes
Logitech QuickCam VC Windows - 4.1.5 Macintosh - 2.1.2
Windows 2000, Mac OSX, 9.2, 9.1, 9.0 Yes
Logitech QuickCam Zoom Windows XP Yes
Orange Micro iBOT Pro Firewire 4.10.22 Windows 2000, Mac OS X and 9.2 Yes
Veo Stingray Windows XP, Me, 2000, 98 Yes
Copy this site and paste it in your web browser address bar and hit ENTER todownload the MAC drivers macam version 0.9.2 (current version)
for Logitech Quick Cam.
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype ( )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger ( )
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Mar 15, 2010 | HP Webcam for Notebooks
Speakers not working with windows 7& no drivers available
u say it's new...then take it back to the shop and ask them to fix it...dont screwup by doing something that u are not sure is the solution...else u will loose ur warantee...
Dec 21, 2009 | Inland ProSound 2000 Computer Speakers
Hp officejet all in one
I assume from your message that you mean you can't print a document from your computer or send and receive faxes. Chances are, you'll have to reinstall the printer, just the same way as when you first bought it and hooked it up to your PC. Also, the operating system on your computer is going to make a difference. For example, if you originally hooked the printer up to a Windows XP computer and now you're hooking it up to a Windows Vista computer, you'll need to install different print drivers.
I don't know if you have the original manuals or disks that came with the printer. If not, a good place to start would be to download the manual from That'll at least get you started:
Manuals page
It would be really helpful if you were to post what steps you took to connect your printer to your PC once you got the printer out of storage. Also, how long had it been in storage, are you hooking it up to the same PC or a different PC than before you put it in storage, and are you hooking it up to the PC differently now than before (printer cable vs. USB cable, for example)?
Sep 24, 2008 | HP Officejet 5610 All-In-One InkJet...
Compaq presario speaker hook ups
a brand new HP 360 comes with no manual $1000 in a box.
that is because its at HP for free , you are not at HP but at fixya.
why be here? we are NOT HP.
the manuals are all there, one model might have like 30 manuals.
depends on what you are doing, they even covery up to 8 windows versions used, not in 1 manual but 8. (or 4)
speakers 101:
so KBL: are those external speakers? you never said that.
what is your service tag full model number it is not 2500
i get no hits at REAL HP for that number.
ZE 5000 NX9010 Series???? how can it be both #?????
hp has like 10,000 models of PC for 35 years
we can NOT GUESS them ever here, the service tag must be presented by you or all answers will be wrong.
for sure.
the speaker jacks on PC can be 2 channel, 3.1. 5.1, 7.1 and up.
we have no idea what you have there, at all. period
I get 1 hit, NX9010 at HP.
so if that is the model prefix (missing P/n on tag shown)
do know this that one model like this can have 5 different motherboards used, even for sound.
some have low end sound chips other higher end. more jacks.
seen. no photos for your jacks by you pressented.
so connect the speakers to the green jack.
speakers out. 2 channels.
this Laptop NX9010 came with zero external speakers
so you previous owner added them.
no JBL part numbers stated of the 1000s made.
the nx9010 front most 3.5mm phone jack is green
and is for head phones,
to use speakers they must be amlified speaker
you buy those and it has 2 speakers, a cross jumper from one to the other, and from the main speaker (has volume knob)
there is one cable from it to the PC green jack 3.5mm
then the main speaker needs its power pack connected with power on, this turns on the magic Amplifier inside.
this makes the speaker work on any pace made from 1990s to
off the green jack only.
then set the speaker to 1/2 volume
and then at the PC raise volume till happy.
that is it for 2 channel technology audio.
some PC have more fancy setup.
but here is your book free to read for 14 years
most of this PC are dead now, the CFFL lamps long ago burned out and screen dead forever.
read page 50.
all the other books this pC are here. every one.
Nov 22, 2017 | HP Compaq Presario 2500 HP Pavilion ZE...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
