Question about Dacor Preference SGM466 Gas Cooktop
SGM464EM cook top valve rplacement
I need to replace the 4 gas valves of a SGM 464 EM Dacor cook top. I don't know if to gain access to the inside of the top I would need to dismount the four burner bases or can I gain access from the bottom.
  • eflicki Dec 11, 2008
    Hi Larryyb...wow !!!!! that was a fast answer....
    I al located in South America and ussualy I fix things myself. I have already ordered and have at hand all 4 gas valves, but don´t seem to be able to see the way how to get inside. The burners have notches that I suspect would allow me to access the inside and lift the entire top off, but don´t see how. I would like to send you some photos of the burner base......and maybe from this I could learn something from you.Please send me your e-mail. Mine is eflicki@yahoo.com.
    Thanking you in advance for your assistance
    Enrique
    Sergeant:
    Champion:
  • 291 Answers
You have to go in from the top ,,, take off burner, knobs and the screws holding top and raise to get to valves / larry
Posted on Dec 11, 2008
  • Larry Youngblood
    Larry Youngblood Dec 11, 2008
    sent email to receive the pictures to help / larry
Gas ignitor keeps trying to ignite after stove is off.
Hi and welcome to FixYa. I am Kelly. On your cook-top the gas igniters are cycled on and off by a ceramic and copper switch on the front of each of the gas valves. Some of them are in wired Series ...i.e any burner on will cycle all igniters on the cook top and some of them are in Parallel where individual burners are controlled by each gas burner control knob. Inside these tiny ceramic switches there is a flat thin strip of copper that as the gas valve is rotated a cam of the switch actuates pushes the copper strip against the fixed contact. Those little strips over time either break or get bent and stay against the fixed contact. Hence you have and igniter on when the burner control is off. The only fix is to find out which little ceramic switch on the front of the gas valve is stuck. You do it with an Ohm meter POWER off. They all should read open with the burner controls off. The one that reads continuity across the 2 wires is the bad switch.
Thanks for Choosing FixYa.
Kelly
Sep 13, 2010 | GE Cooktops
I have leaky valves on my cook top. Do they need
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Jun 04, 2010 | DCS CP-486GD 48 in. Gas Cooktop
Kenmore gas stove top switch harness replacement instructions
for the 4 burner if u not use coz of no igniter,use matches or lighter every time to use,if not turn the burner remove the knob & try to use hammer slowly at the top of the gas valve mostly the problem is stockcup,use oil b4 u try to turn.for the harness wire call the contact service center to buy a harness wire to replace the parts,but it so easily to replace the wire try to open the unit to see the wire size,color then gi to hardware to buy a wire same as in ur unit.tnx gerbee
Jan 27, 2009 | Dacor Preference SGM466 Gas Cooktop
I have a Dacor 48" ERD dual fuel range set for LP and need to convert it to NG. Dacor says "NO can do" I know it is not rocket science. Parts people such as appliancepartspros.com first say I need about 5...
If Dacor does not supply a conversion kit you may have big trouble changing it to natural. In addition to the burner valves you must change the orifices, the regulator, and venturi tubes. This would be quite a challenge. Good luck!
Jan 07, 2009 | Dacor Preference SGM365SS Gas Cooktop
Jenn Air gas cooktop
pop me an email at b4829@yahoo.com and reference your cook top you can rate me later
Mar 29, 2008 | Cooktops
Propane to Natural Gas Conversion
on the regulator there is a 1/2" nut, made of aluminum. loosen the nut, thur it around and screw it back in, there is a "NAT" on one side, and a "LP" on the other side, make sure the "LP" is facing out if you are using propane, and "NAT", if you are using Natural Gas. Very simple, all you need is a 1/2" wrench, or a small adjustable wrench,
Jan 06, 2008 | Dacor Preference SGM365SS Gas Cooktop
Dacor Cooktop gas conversion
Where did you purchase the kit? Can you name the store with number or list the website? Also the part number information. Thanks
Sep 19, 2007 | Dacor Preference SGM365SS Gas Cooktop
Dacor Preference SGM466 Gas Cooktop Logo
440 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Mike
Mike
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
