it starts off ok but 5 mins in to the cycle (any cycle)all the lights start flashing and it just makes a sloshing noise but the drum is still.... .it an indesit wia111
Check the drain pump they haave a catch sleeve inside the drain line before the drain pump. Remove the lower front panel to access the pump and remove the large hose from the drum. Inside the hose is the sleeve, take out the sleeve and clean it.
Indesit W123, Error code 8, 8 flashes. Not responding to normal reset proc. Filling then emptying...
(More)
Indesit W123, Error code 8, 8 flashes. Not responding to normal reset proc. Filling then emptying without starting cycle. It was working fine until the rubber filler pipe inside slipped off due to rough treatment, trying to force a large duvet in. Wet got on various parts and caused the house electrics to go off. Dried out now but still not working properly. What does the 8 flashes code indicate? What can be done to reset it or whatever? Thanks, Bob ***
The washing machine I have is not functioning well. When I turn it on, the power light keeps working...
(More)
The washing machine I have is not functioning well. When I turn it on, the power light keeps working on and off and it turns with no real work. What can I do?
