Question about Nikon N60 35mm SLR Camera
My N60 won't power down
I switched camera to off and the LCD display stays on.
When I switch it to "on" the camera does nothing.
  • tmclong Dec 11, 2008
    Yes,
    But the shutter won't work when it is ON now.
  • 148 Answers
On Nikon cameras the ON/OFF button is more of a safety-catch for the shutter that a power button. Does it correctly disable the shutter button when turned to OFF?
Posted on Dec 11, 2008
Canon 450d lcd will not turn on at all, viewfinder says busy, and camera will not take pictures
In menu option C.Fn-12 you can choose to switch the display off (or on) when you switch on the camera. The display stays off even if you switch of and on the camera.
Press the button <DISP> and switch off the camera, while the settings for recording are on the screen. After you switch on the camera, the LCD screen will be switched on again.
Please refer toy your english manual, I had to translate, because I don't have the English version.
Nov 20, 2013 | Canon EOS 450D Digital Camera
Fault finding
The green LED is called the memory acces lamp. When you switch off the camera is will write back the last changes. when you switch the camera on and off, the light ususaly will stay off, because nothing has changed. When you remove the card en put in another the LED will flash again. At least my D7000 with 2 card slots will do so, because someting changed and the system will write that into the memory.
Aug 21, 2013 | Nikon D90 Digital Camera with 18-105mm...
Cannot switch from LCD to viewfinder - Minolta Dimage Z1
Nothing adjustable here, Its more than likely the switch pole which is weither broken or worn. Not a DIY but also not an expensive fix
Thanks for using FIXYA
Sep 21, 2009 | Konica Minolta DiMAGE Z1 Digital Camera
Canon EOS Rebel problem
This is usually caused by a defective shutter release switch - it'll have to go into a repair shop - independent shops will charge about $110 USD - Canon charges about $180
Nov 26, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Display Cannon 630 powershot
Thanks for your reply
Out of frustration I was sitting looking at the camera and thought to try all buttons and see what hapenned. On the righthand side of the camera in the bottom left position is a button marked display. Normally during live display mode, you can either switch the screen on or of by pressing this button (to conserve the batteries). If the camera is powered off and then on again, the screen automatically is in live display screen active mode again. For some reason my display remained off. When I depressed this button once after switching the camera on - voyla! The display worked again in live viewing mode. I do not know whether the screen is supposed to stay in the off mode when powered down in live display off mode even when it is switched off and then back on again or not, but the previous times I did, it was automatically on when powered up again.
So, before repairing your camera, please make sure that it is actually broken - refrain from making a fool of yourself like I did.
Thanks once again for your support
Regards - notsobroken
Feb 12, 2008 | Video Cameras
Nikon N60 35mm camera error code FEE
Check your lens aperture ring setting. It must be set on the highest number I.E. f16,f22,f32..
Jan 16, 2008 | Nikon N60 35mm SLR Camera
Monitor is black, the blue lcd at the switch does not lite when switch is turned on. The internal fuse is ok. I tried to find a schmatic on I could check the power supply, no luck.
I have the same problem. Took it apart for troubleshooting. Found that if I disconnect the ribbon cable between the display driver circuit board and the LCD panel, I can turn on power and it will stay on. I can turn it on and off with the power switch. With the LCD panel cable connected, Power turns on (power light blinks) then apparently a fault with the LCD panel causes the power supply to shutdown. At this point the power switch does nothing. Now the big question is "Can you purchase a LCD panel?" If so, it probably costs more than a new monitor. Hope this was helpful.
Jan 02, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Err message in N60
If your lens is set to F/22 or the smallest available on your lens, this is not a user problem. Take it to your local camera repair shop ( usually $100 to $125 repair to phase or sequence switch ).
Jul 12, 2006 | Nikon N60 35mm SLR Camera
Nikon N60 35mm SLR Camera Logo
54 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
