Question about Verbatim DataLifePlus Hi-Speed CD-RW Storage Media
Lightining Hit My brand new computer got zapped by lightining, I bought a new motherboard, and a new CPU BUT it still will not boot up.  can it be fixed or toss it?
  • 19,396 Answers
When the computer gets zapped, virtually any part can be damaged, including RAM, disk drives, connectors on cabinet (eg USB), PCI cards, etc.
Usually the CPU stays safe, as the motherboard blows before CPU.
When you get this kind of damage is always better taking the computer to a repair shop, instead of DIY, as there is need to test all parts.
Ensure that you assembled Motherboard, CPU , and heath-sink properly.
Try first starting the computer with a minimal set of devices plugged to the motherboard, with only PSU, RAM (1 module), Video card if needed and CPU/Fan.
If there is no power at all then it is likely a bad PSU, if it starts but not screen, it is either a bad RAM or the motherboard had not been assembled properly, or had been damaged during assemblage.
Posted on Dec 11, 2008
Cougar was hit by lightining and now when you get to 3000 rpms it disconnects the transmission
With a scanner you can drive the car and watch the data to see what is missing for transmission shifting. But struck by lighting tells me that POSSIBLY the diodes in the computer have been compromised . or a internal mechanical fault inside the transmission . THEORY the car revs to 3000 and goes into neutral this means the shift has occurred by the next gear is not holding by pressure (that solenoid is not working) or a internal leak or the band servo has applied but the band does not hold
May 05, 2014 | 1999 Mercury Cougar
Lightining sign on dash mean
If the red light dims severely or goes out when you try to start it you have a flat battery, highly likely if that red symbol has been on while the motor has been running because the alternator hasn't been charging. It could mean you have a broken drive belt but that would also mean no power steering, AC or coolant pump drive so that would have been obvious fairly quickly.
Jun 02, 2012 | 2006 Jeep Grand Cherokee
Product key for iris lightining cma
seems you need a usb converter from your little blue to usb there are many of those arround
Apr 20, 2012 | Iris Software, LLC Lightning 2000i
Jet streams whirpool not working after heavy lightining storm. lights in the tub do work, but do not turn off Unit about 6 years old model TO3C 1348
you have been hit by power surge. most likely the problem is in the control box that controls the pump. Need to call local plumber or service company to take a look at the system.
Verify that all circuit breakers are on and stay on after being reset before calling service tech.
US Parts Center
Aug 21, 2011 | Kohler Home
Just bought a new cpu and the F1703 monitor won't work. Just floats a screen about the settings around and never boots up. Can't change the settings on the monitor using the monitor menus either. We've had...
try another monitor first if that doesn't work put the old cpu back in and check it may need motherboard firmware to read the cpu upgrade chip check specs on motherboard
Jun 17, 2010 | Famous Brand F1703 Monitor
Looking for an dvd decoder
If you mean that you want to make backup copies of the DVD-Vidoes that you own then DVD Decrypter from Lightining still Rocks even with newer types of encryption.
You can even remove the Region Code as well as the CSS
Jun 12, 2010 | Computers & Internet
Emachine won't come on
I would check the power supply box,If it is bad,you can get a replacement for under $50 and save the whole computer.
Please rate this a fixya.
May 07, 2009 | Computers & Internet
Need new instructions/directions
Look at the clock and find the manufacturer. Look to see if they have a website. They may have it posted there.
May 03, 2009 | Toys
Computer does not boot (new Machine)
Swap the power supply since you got two systems?
Feb 23, 2008 | Pine Technology XFX NFORCE LT 680I SLI...
DFL-200 WAN won't connect
might be the WAN port failure because of the lightining>so only possiblities is replace it
Oct 30, 2007 | D-Link NetDefend DFL-200 Firewall
Verbatim DataLifePlus Hi-Speed CD-RW Storage Media Logo
42 people viewed this question
Top Verbatim Electronics - Others Experts
Are you a Verbatim Electronics - Other Expert? Answer questions, earn points and help others
