Question about HP Officejet 6310 All-In-One InkJet Printer
Running a report
I'm trying to run a report on the fax's I sent
I have HP 6310 all in one
    Problem Solver:
  • 10 Answers
Press "Setup" button, then "2. Print Report", then "6. Fax Log", then Ok.
Posted on Aug 27, 2009
I recieved a fax a few months back that i cannot find it , does the the hp 6310 all in one have a memmory log so i can access the document again?
You can give it a try, hopefully the printer should be able to print the fax log if it hasn't erased it.
Press Setup Button on printer front panel
Scroll to Print Report - Press OK
Scroll to Fax Log - Press OK
Check the fax that you had received on the date and press ok or it may print the fax log present in the printer.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 19, 2011 | HP Officejet 6310 All-In-One InkJet...
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
A report for sent faxes
Look on page 31 to set Fax Call Report Time, set it to "send fax only" for Tx confirmation report.
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/bpl11457/bpl11457.pdf
Sep 23, 2009 | HP LaserJet 3330 All-In-One Printer
How do I print a fax report on an HP Officejet 6310 All-In-One?
visit the following link to obtain the manual for your All-in-One. Hope this helps!
http://www.retrevo.com/support/HP-6310-Multifunction-Printers-manual/id/260dj484/t/2/
Sep 06, 2009 | HP OfficeJet 6310 All-in-One Printer...
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
When I attempt to print on 6310, it goes to fax mode
go to control panel >printers andfaxes and see which printer is set as he default printer....it is the fax rgt now.....rgt click on the pirnter icon and change it to the default printer.....should work....
Jun 24, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp officejet 6310 all-in-one send fax configure
1. Press Setup on the front panel of the All-in-One.
2. Press 2 to enter in to Print Report.
3. Press 1 to enter in to Fax Confirmation.
4. Press 1 to turn on Fax confirmation
5. Press 2 to enter in to Image on Fax Send Report
6. Press 1 to turn on Image on Fax Send Report
Jun 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Cannot receive faxes
1-are you sure it is in the correct jack? there are two in the back of the printer
2-when you did the install it should have done a fax line check
Sep 20, 2008 | HP Officejet 6310 All-In-One InkJet...
Faxing a word document
hi, i would like to know if you have an HP officejet 6300 fax icon???if you have try to print the document using the fax icon DO NOT used the normal HP officejet series icon.if you did used the fax icon it will display the FAX dialog box,input the necessary information needed.just follow the window..
i believe you can now send the fax..
send me feedback for further troubleshooting....
Aug 04, 2008 | HP Officejet 6310 All-In-One InkJet...
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
71 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
