Question about HP Cameras
When you turn on the camera the lens will not open? What's wrong?
I took it to the repair shop, Thanks!
Posted on Dec 12, 2008
When i turn the camera on, the lens telescopes out. then it makes a noise like it's still trying to open and then the lens goes back in and the camera turns off. what's wrong
The gear is worn or has sand or grit on the teeth causing it to not open up without resistance.
I would contact Polaroid directly regarding this issue to see if it is repairable economically:
http://www.polaroid.com/contact
Aug 06, 2010 | Polaroid m737t Digital Camera
My camera lens won't go in and makes a funny noise everytime you try to turn it on. what's wrong?
my camera fell and tried to get the lens inn and now makes a funny noise and does not open
Jun 25, 2010 | Olympus FE-20 Digital Camera
I turn the camera on and the lens wont open. i
Hi dear, It looks like low battery,Try to recharge your battery.
Jan 17, 2010 | Fuji FinePix A400 Digital Camera
Lens stuck open on Lumix DSC-TZ5
This is a common problem when something goes wrong with the lens system.
This can be as a result of numerous problems.
Try to pull the lens as turning on and also gently twisting it in and out...just may make the lens go back on track.
Sep 21, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Toshiba PDR-3300 Lens cover message
Hi Judy, thanks for coming to FixYa.
Sorry no one has gotten to you sooner. Your manual mentions this and this is what it says to do:
Turn the camera on and move the lens cover switch to the open. Then your camera should operate normally. Let me know if that helps.
Rob
Feb 16, 2009 | Toshiba PDR-3330 Digital Camera
Camera won't turn on, just beeps
first check the battery... charge or replace it... else reset the camera or repair
Sep 05, 2008 | Olympus Camedia D-510 Zoom Digital Camera
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Lens
OK I know whats wrong with this one, because my cmaera did the same thing. The outside shutter in the lens opens, right? Well, the inside shutter is stuck. Its staying shut. Take the camera apart(or if you dont feel comfortable doing it yourself, take it to a expert)and tap the side gently, it should fix itslef like that. If not, its the same problme, but you'll have to take it in somewhere.
Jun 01, 2007 | Sony Cyber-Shot DSC-W7 Digital Camera
Turn on the camera, cover lens is closed even though i already pull it down
if you open up your casing you will find that almost dead center on the front PCB, just to the right of the battery at the top of the empty battery area there is a box. possibly with some plastic fragment that is broken off. if you touch inside this box w/ something conductive it will think the lens is open. You can either fix this area or permanently solder it so it thinks it is always open. You can still turn it off using the button on the side of the camera
Sep 07, 2006 | Sony DSC-T7 Digital Camera
Cameras Logo
20 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
