Question about Prestige Remote Start
Do these work with pus button ignitio
I ordered the Audiovox prestige APS620 and then realized that my car has a push button ignition. Will this remote starter work with this car?
  • kruegerklan5 Feb 23, 2009
    remote start problem Lexus 350, intermitent sucess, then when it does start and I get in w/key FOB in hand, step on the brake the car shuts down.
    Sergeant:
  • 233 Answers
Yes, the remote start can still operate your car, but I suggest not installing it yourself.. Take it to a reputable shop in your area! Push button start cars are different than regular key ignitions, so if you have no experience with remote starts, dont try it.
Posted on Dec 19, 2008
Battery key fob
Turn the ignition key on , open the hood, disconnect the battery for two minutes, reconnect and try .
Dec 14, 2013 | Prestige Remote Start
Prestige APS787C wont start car
Try reprogramming the remotes: Turn ignition on, press and release programming/Valet button on antenna three times. You should here a short chirp, press the lock button on one remote. You should here a long chirp. Press the lock button on the other remote, you should here a long chirp. Turn ignition off. Test system.
Feb 11, 2013 | Prestige Remote Start
I lost remotes,how do i bypass alarm?
Locate the valet/override switch. You may have a push button LED or, it may be located under the drivers side of dash. Turn igniton on press and release push to manually override alarm. Turn ignition off then, back on. Press and hold push button for approximately 5 seconds to put alarm in valet.
Jul 18, 2012 | Car APS25CH Prestige 2 Button Remote...
I have a prestige remote Audio box starter remote alarm on a 2002 Toyota Camry.I unplugged the sensor and the car still doesn't start.can you help me i am out of the state need to get home.
Locate the valet switch( black push button), turn ignition on, press and release valet switch. the valet switch is plugged onto the main control unit. You can find the main control unit by tracing the harness that you unplugged from the shock sensor. The valet switch is plugged into a two pin plug and has a blue end. Trace the wire to the valet switch.
Jul 10, 2011 | Prestige Remote Start
2002 Lincoln Towncar, Audiovox asp901, customer lost her keys and had new ones cut and reprogrammed. Now the remote start will not work. The pats light flashes and it wont start with the remote. I need to...
The PATS bypass module should have disconnected during the new key programming. First, you need two programmed keys present. Put the first key in the ignition, turn ignition on, wait for security light to go out. Remove key, immediately put second key in the ignition and turn ignition on. Wait for the security light to go out, remote start vehicle with controller, immediately remove key. Let the vehicle start and run for approximately 10 seconds. Apply brake to shutdown, wait approximately 10 seconds. Remote start to test. If vehicle does not start, repeat process.
Sep 15, 2010 | Audiovox APS901 Car Prestige Remote Start
I have a Prestige Model APS-55TW remote start, when i hit the remote start the car sounds like it wants to start but not turning over? the car will start by turning the key what could be the issue?
try putting the key in the ignition and turn it to on (dont start) try using remote start button if it works you may need a anti theft module or spair ign. key.
Jan 15, 2010 | APS787 Prestige Remote Start and Security...
Would you recomend the Audiovox Prestige APS901N for my '06 Chrysler T & C mini van?
IF RANGE IS NOT IMPORTANT I SUGGEST A AUDIOVOX AS9076N . ITS AN ADD ON REMOTE START WHERE YOU WOULD PRESS
LOCK
THEN UNLOCK
THEN LOCK AGAIN ON YOUR FACTORY REMOTE AND THIS WOULD START THE CAR.
I BELIEVE THE IGNITION KEY HAS BUILT IN KEYLESS ENTRY BUTTON ON IT ALREADY. SO WHY CARRY ANOTHER REMOTE?
MOST OF AUDIOVOX MIDRANGE SYSTEMS HAVE THIS OPTION FOR ADD ON REMOTE START SYSTEMS WHERE YOU CAN USE THERE REMOTE OR TIE IT IN WITH YOUR EXSISTING REMOTE.
OTHER UNITS WILL HAVE DOUBLE LOCK OPTION TO START CAR. OR TRIPLE LOCK OPERATION.
Dec 24, 2009 | Prestige Remote Start
Want to buy a prestige aps998 remote and cant find it
You have to contact Audiovox by web or phone to order the dot matrix remote. It cost $85 + shipping. I'm lookin for a way to order online myself.
Sep 24, 2009 | Prestige 2 Button Remote Security System...
Sound
it sounds like the chips have been eliminated, if so......
1) turn ignition "on" and then "off"
2) within 10 seconds push the valet buttons three times
3) you should get 1 siren chip indicating the chirps are now "on".......if, you get 2 chirps then you just eliminated the chirps.
May 22, 2009 | APS787 Prestige Remote Start and Security...
Prestige aps-57 remote start...car won't start
Hello hope this can help you. First check the starter wire, it is tan/lt blue located at the ignition harness. usualy during installation of the remote start system this wire is cut leaving you with two ends. one wire is coming from the ignition switch the other is going to the starter. the brain of the alarm hooks into both of these wires. if the repair man cut the wires from the brain and spliced them together he has just put the system back to OEM status leaving the alarm no way to engage the starter. I believe that may be where the problem lies but if not then I would say check your immobilizer bypass module the repair man mave have diconected that.
Thank you,
Luis
Dec 01, 2008 | Prestige Remote Start
Prestige Remote Start Logo
124 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Iron
Iron
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
