Question about Dell Dimension 4300 PC Desktop
I opened my case for my computer to fix a loose piece and i pulled out my ethernetlink10/100 pci and i was wondering if u could describe where to plug it back in, there is a cord i dont know where to plug in
    Sergeant:
  • 207 Answers
Person dude,
On your computer there should be an opening that looks like a wide phone jack, this is called an RJ45 connector. The line for your ethernet should plug into that.
hope this helps you
Dave
Posted on Dec 11, 2008
  • 3,940 Answers
The PCI Network adapter normally goes in the PCI slot closest to the video card (The video card and NIC can share IRQ 11)
  • 148 Answers
If you mean the ethernet cable that plugs into the back of the computer, please look at the photo below.  i opened my case for - 490d71a.jpg
the similar but slightly smaller modem socket may be also present, but don't worry as the ethernet cable won't fit as the sock is smaller.
Desk top dell has a black screen
If your dealing with a black screen on a dell desktop it could mean a couple things. First make sure your monitor is connected to the back of the computer. Second make sure its connected to the right video card because there may be 2 of them. The one at the top is the on board video and a lot of people add a better one in a pci slot towards the bottom. In event that is not the case and the monitor is turned on it could be a faulty video card, bad driver, or the video card needs reseated.
1. turn off computer Sometimes when moving desktops pci cards are jarred and need reseated.
2. Open the case at the back by removing the two screws holding on the side panel
3. then remove the screw that is holding the pci video card, pull out the card
4.then reseat
5.rescrew
6. restart
if this doesn't fix the issue then buy a video card that is compatibly to your motherboard and replace it
if it is an onboard video card buy a pci or pci-e or a video card that is compatible for your computer
Jan 27, 2014 | Dell Vostro 1710 Laptop
I have no clue how to describe my problem.
If a tech opens the case, you're not going to lose your warranty, even if you do it. It sounds like the plastic container that you plug your power supply into has either broken around the outside or has come lose. If usually fits between both pieces of the case, so you have to open it to put it back in place.
Mar 17, 2013 | ASUS Computers & Internet
Install audio card for asus essention cg5270bp003 pc desktop
http://www.evertek.com/viewpart.asp?auto=58002&cpc=NEWARR
Three views shown.
http://www.revolutionpc.net/store/Asus-Essentio-Ultimate-Desktop-Computer.html
Scroll down to the photos towards the bottom.
Looking at the Front of the computer, the LEFT Side panel removes.
Remove the Philips head screw located towards the Top, on the Side Panel's edge, and the Bottom screw on the Side Panel's edge.
Pull back on the raised fingergrip, formed out of the back of the Side Panel.
The panel pulls back so far, then is tilted out, and removed.
-> FOLLOW Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer.
Computer on a table, computer Unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
You may also wish to remove all cables from the computer, and lay it on it's side for easier access to the motherboard.
http://www.ebay.com/itm/OEM-ASUS-ESSENTIO-CG5270-P5QL-VM-MOTHERBOARD-61-MIB8Q3-01-US-TESTED-/170893854322?pt=Motherboards&hash=item27ca114672
Look at the right side of the motherboard, and the two long White PCI slots.
Above them is a long Blue PCI-Express x16 slot. This is used for a graphics card.
Above it is a small White slot. This is a PCI-Express x1 slot.
If a PCI slot is open you can use it for a Sound Card.
If not, and the white PCI-Express x1 slot is open, you can use it.
Examples of Sound Cards used in a PCI slot, and a PCI-Express x1 slot;
1) PCI;
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4459743&CatId=2771
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2941927&CatId=2771
On the back of the computer case framework is a small 'door', that holds the expansion cards in place.
The Thumbscrew is loosened, and this allows the door to swing open.
Find the appropriate expansion slot cover, that matches up to the slot your wish to use, and remove it.
Note that the expansion slot covers, do Not line up inline with an expansion slot on the motherboard.
(Expansion Slot; i.e., PCI, or PCI-Express x16, or PCI-Express x1 )
The expansion slot on the motherboard, is usually one space over from the expansion slot cover on the back.
[Don't believe that is worded correctly, but you will see what I mean with the Side Panel off, and looking at the motherboard ]
Yes. It's a lot of fun(?) trying to keep the expansion slot covers in place, expansion cards in place, and trying to close that 'door' properly.
[Look close. The bracket for the expansion card, (In this case a Sound Card), fits in little depressions in the metal framework of the computer case; or the brackets half-moon hole, will fit over a small peg, in the computer case framework ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 09, 2012 | ASUS Essentio CG5270BP003 PC Desktop
I kicked my emichine computer and it broke. First the screen went slightly fuzzy and when i turned it off and turned it back on and it wouldnt show what the cpu was thinking on the screen.What could be...
I would check the components inside the case...sounds like something wiggled loose while you were kicking it. Open the case...first check that all the cards (pci/video/RAM) are properly seated in their slots. Next make sure the hard drive plugs havn't wiggled loose. Post back if it still doesn't work
Jul 18, 2010 | E-Machines eMachines Desktop PC
I was wondering if the Asus p5ne-sli motherboard is compatible with Ati 5770 video card ??
THIS IS THE PCI EXPRESS 2.0 CARD AND I REQUEST YOU TO OPEN YOUR CASE AND SEE WHETHER IT IS HAVING THE PCI EXPRESS SLOT OR NOT.
Mar 23, 2010 | Evga GeForce GTS 250,, PCI Express Video...
Can the case of the IBM 350 computer be opened without the latch?
No, the case cannot be opened without using the release latch (Button)
What I believe has transpired, is a situation that I ran into a few years ago, with a computer case that used a similar setup.
I'm afraid my solution won't sound very professional at first glance.
What transpired on the case in question that I was working on, is that the slide button for the latch had come loose, from the latch mechanism.
Come loose due to someone trying to forcibly open the case. They also bent 'Fingers' of the case, that holds the sliding latch mechanism in place.
I found the metal mechanism was made up of two parts, and a spring held the sliding part of the latch in the locked position.
Apparently someone had tried to access the case with the latch, and had no luck. Then they tried to use some sort of leverage device to force the case open, bending one of the two parts of the latch, and part of the case itself. ('Fingers')
The case has small metal 'Fingers' that hold the non-sliding part of the metal latch in place, and also the sliding part.
(Picture a small U shape, stamped into a flat piece of metal. The U shape is actually cut through the metal, with the top, or flat part not cut out.
Now bend the bottom of the U, out of the flat piece.
They sort of resemble 'Fingers')
These 'Fingers' are wrapped around the non-sliding part of the metal latch, and sliding part.
The keep the latch in place.
When bent out, they don't let the Sliding part of the latch, slide over all the way.
All the way, to release a hook at the end of the sliding part of the latch, out of a corresponding small rectangular hole in the computer case.
I had to use finesse, and a flat tip screwdriver. I had to insert the flat tip into the top edge of the panel, and slightly bend it out. (The top edge of the panel above the latch mechanism)
Then with the gap large enough, I slid the flat tip screwdriver down into the case, and proceeded to bend the 'Fingers' out further. When I bent two fingers on top far enough out, the latch mechanism was then loose enough to drop partially out.
I could then open the case. Once I saw how the makeup of the mechanism was made, I then proceeded to straighten the case back to where it was.
Straightened the parts of the metal latch, and reinstalled it into the cover panel, and re-bent the Fingers back into position.
Then I attached the spring, and adjusted the sliding latch to make sure it worked okay.
Sorry I was so lengthy, but after you have fixed your problem, I believe you'll find it is very hard to describe this latch, and how to fix a bent one.
I wish I could have just stated, 'Insert this tool here at this spot, and give it a click to the right'.
Nope.
Regards,
joecoolvette
Nov 21, 2009 | Video Game Consoles & Games
I have install the windows xp in my C797VU model. but while installing the sound driver a message appears that"no sound device is found"
You could have a loose sound card. Somehow the card may have been jostled and is be firmly seated in the PCI slot. The easiest way to determine the nature of the problem without opening the computer case is to do the following:
Goto Control Panle>Go to Sound, Speech and Audio Devices,>Sound and Audio Devices Click it Once...When the Properties Window Pops Up..Click on the Hardware Tab> You will see all your installed Devices including sound card. (If you don't see it--it may not be installed)
If you see it highlight and click on it...You will discover if the card is installed and or operating properly. If you must go inside the computer case..It will just be a simple matter of pulling the card out and reinserting firmly in the PCI Slot
Apr 05, 2009 | Microsoft Computers & Internet
Brother tripped over speaker cord
open up tthe speaker case and resoulder the leads/unless the wires pulled loose from the speaker face on the back of the speakers that should fix the problem,if the wires are pulled loose from the speaker face then reattach them with a drop of craze glue and a small drop of silicone sealer which should do the trick!
Jun 02, 2008 | Logitech Z-2300 2.1 Computer Speaker...
How to open the case of the speakers?
since u hav removed the mesh and the 4 screws that hold the case of the speaker .As you said that the speaker has no opening points , most companies manufacture the speaker by sandwiching two parts together. In order to open the case of the speaker , you will have to see for a joint line on the edges . it indicates the attachment between the two parts of the speaker . If you find an opening at the back of the speaker as you have mentioned , try to remove the two joints of the speaker by pulling gently at the opposite ends .
Jun 20, 2007 | Altec Lansing 221 Computer Speakers
Dell Dimension 4300 PC Desktop Logo
55 people viewed this question
Alun Cox
