Question about Sony CDX-R3000 CD Player
It is playing well but buttons are not working
Recently I got problem with my Sony CDX-R3000 S-MOSFET. While operting volume control it got stuck at high volume. From that time on wards no buttons are working. Can any body suggest what can be done.
4 Suggested Answers
SOURCE: CDX-S2000 Volume, Source, and Mode buttons not working????
Hey jshaff, try taking off the detachable front, and you will see a reset button, press and hold in for 10 secs, this should solve your problem. if it doesn't work first time keep trying. you must have power to the head unit for this to work. you will hear the cd make a noise and that should be that, try and let me know.
Posted on Oct 04, 2008
  • 13 Answers
SOURCE: sony cdx-m610 BIG PROBLEM
yal ever fix them? its the ribbon cable between the face and the circuit board inside the unit the ribbbon cable is very cheap on ebay just google for example cdx-m610 ribbon cable now for the repair close ur face before u take out ur radio assuming u guys still have ur remote to do so theres 3 screws on the bottom of the face when u go to carefully pop the front panel off after pullin them hold ur deck facing down (this will keep ur reset and open buttons from fallin out then theres 4 screws holding in the face's circuit board roll the board out of the face very very carefully pry open the little black lock holding the cable in the connector then open ur radio up pull out the cd player assy same thing with that connector then ull notice the cable goes thru a tension roller pull each end of the cable to unroll it hold it there while removing the cable and sliding in the new one then slowly let go of the roller reattach the cable ends and put everything back together with the face remember its easiest to hold the deck face down those 2 buttons will stay in place hook the top of the face's cover first then put the deck back in ur ride and enjoy these ol sonys r worth a $20 fix specially if they still work good hope this helps yal
Posted on May 06, 2009
  • 5 Answers
SOURCE: MY Sony CDX-R3000 will only play CD's. It will not
Try and reset it . disconnect battery under the hood for like 5 min and see what happens ..I had that radio and sometimes its just tempermental . take cd out and try it ? Sre any buttons stuck ? If that doesnt work then hopefully u like your cds at the volume they are at . Good luck
Posted on Oct 08, 2009
SOURCE: Sony CDX-S2210 buttons are jammed
Hi Sameersach,
Have you found a solution for your problem? I have the same player and I got the same problem...please, let me know if you found a solution. Thanks!
Posted on May 10, 2010
Sony cdx-gt610ui buttons won't work
Guys,
I have a CDX GT610, the issue is that is not possible to change stations, even if I try with the push buttons to record the stations, it remains on the same station (number 3 in my case), besides the volume gets high if I want increase the volume, any suggestion about it??? please let me know
Best Regards,
Marco Hernandez
Feb 26, 2013 | Sony CDX-M630 CD Player
Sony cdx-r3000 how do you turn off the demo mode?
Press the MENU button, then select "DEMO".
May 31, 2012 | Sony CDX-R3000 CD Player
Plays cd but face plate controls do not work
check connection between face and unit make sure it is clean and not corroded
Apr 22, 2010 | Sony CDX-R3000 CD Player
MY Sony CDX-R3000 will only play CD's. It will not allow me to adjust volume, skip songs, or play the radio
Oct 07, 2009 | Sony CDX-R3000 CD Player
Sony CDX M730 won't operate manually, remote doesn't work either
my sony wnt flip down so i can change cds its stuck
Feb 16, 2009 | Sony CDX-M730 CD Player
Clock set
try turning the radio off and hold down one the buttons until it blinks then adjust
Dec 29, 2008 | Sony CDX-R3000 CD Player
Sony cdx r3300 Won't play...simply scrolls a message
_half fixed, use the remote -@least can get more life outa the unit!
Nov 11, 2008 | Sony CDX-R3300 CD Player
How to set time on sony CDX-GT50W
press and hold the volume control dial. when a menu appears press the volume control button until clock adj appears. then press seek to change from hours to minutes. to adjust the hours and minutes just rotate the volume control dial
Apr 22, 2008 | Sony Xplod CD Player w/MP3 Playback...
Sony CDX-R3000 CD Player Logo
43 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
