Question about Bissell Vacuums
Bissell powerforce bagless upright vacuum 6582
My vaccuum is sucking up dirt but its coming back into the hose instead of the canister the hose isnt clogged its not the hose its the part where the hose sits in the hole that its shooting back to instead of the canister help pleaase ive got kids and theres crumbs everywhere!
  • 107 Answers
Check your filter. Sounds like it is not receiving enough suction to pull up the debris. If your filters are clean and there are no clogs, disconnect hose from back by the tank and see if you have suction straight out of the whole.
Posted on Dec 11, 2008
It is spitting dirt out instead of picking it up.
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright
Vacuum not working
heatman101
Feb 06, 2011 | Bissell 6594 PowerForce Bagless Upright...
My bissell power force bagless model 6594-w vaccuum is not sucking up when vaccuuming but if i use the hose it works
Remove the bottom plate that covers the brush assembly and check the air passage that goes out where the vacuum is jointed between the vertical parts and the sweeper head. Look for any clog in that area. A bent hook on the end of a piece of coat hanger wire is a good tool for cleaning clogs. Hope this helps!
Dec 10, 2010 | Bissell 6594 PowerForce Bagless Upright...
The roller will not move around...does that mean I need a new belt for my bissell 6582
Yes that is what that means. It is really simple to do. Here is a link to the belts you need and the manual which has instructions:
Bissell PowerForce Belts and Manual
Dec 12, 2009 | Bissell 6594 PowerForce Bagless Upright...
How to change belt on Bissell 6582 vacuum
Here is a link to the belts you need and to a manual you can view with instructions.
Hope it helps!
Nov 27, 2009 | Bissell 6594 PowerForce Bagless Upright...
I recently cleaned all the filters in my Bissell powerforce, now instead of suction I get all blown back instead.
take all the filters out put the dirt cup back in then try it again.3 filters 1 on the bottom of the dirt cup and one above the dirt cup and one in front at the bottom behind the little door.if thats not it at the bottom on the right side you will see a clear hose thats your intake hose,one screw holds it on,take it out and bend a coat hanger so the tip is rounded ,then work it down into the clear hose ,you should be able to push the clog out through the bottom
Apr 28, 2009 | Bissell 6594 PowerForce Bagless Upright...
Dirt Devil Upright Bagless Vibe Vacuum no longer sucks
Sounds like there's a clog in the long hose that connects to the dirt canister. Remove the hose completely and check for clogs. There is a blue plastic piece that the hose is attached to. You can remove it by taking out the two screws in the back, and the four screws behind the dirt canister. Once those are removed, the hose comes away from the vacuum with the blue plastic piece attached. That should allow you to check for clogs. If necessary, take the hose outside or a place that is well lit, so you can visually verify the absence of clogs.
Mar 09, 2009 | Dirt Devil M087700SV Bagless Upright...
Bissell bagless
I had the same problem, called Bissell over 10 times! They send me 3 plastic inserts for the dirt chamber, not the problem. I solved it by throwing the Bissell away and buying a Eureka bagged vacuum, no more problems.
Oct 21, 2008 | Bissell 6594 PowerForce Bagless Upright...
Bissell PowerForce Bagless Vacuum (6582)
You just have to twist hard the first time for some reason. If you hold the container with your right hand you actually have to twist the bottom half CLOCKWISE when viewed from above.
Oct 11, 2008 | Bissell 6594 PowerForce Bagless Upright...
Vacuums Logo
228 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
