Question about Compaq Audio card Sound Card
No sound audio and device properties VOLUME TAB no audio device hardware tab samsung cdrw/dvd sm 3088 teac CD-56E Why my DVD and CD is not in Sounds and Audio Devices Properties VOLUME TAB ? can you help
  • Yusef Yagbes
    Yusef Yagbes Dec 24, 2008
    My problem was no sound in dell dimension;I received a suggestion for compaq.what is the appropriate rating for this answer?
    President:
  • 2,692 Answers
An audio device is a piece of software that came with the setup disk for you mother board/computer. Here si the website to download anything that you are missing. You will need the model number of your computer.
http://www.compaq.com/cpq-country/cpq_support.htm
Posted on Dec 21, 2008
SAMSUNG N150-i have check sound/audio devices in the control panel and made sure volume is set right..selection...problems with volume...icon showing 100% but still no sound,help please!
If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it.
If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume. You can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets they are usually at the side of the laptop.
You will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit.
dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
Feb 18, 2013 | Samsung N150 (36725723009) Netbook
Sound problem with windows 7 32bit intel MB dg31pr
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your setting are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
click start control panel hardware and sound manage audio devices playback you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of of the playback list also right click on the speaker select properties you should see a few tabs general levels enhancement and advanced you might find you need to select a different option possibly stereo or dvd or studio quality windows7
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further changes to your sound setting by right clicking on the speaker icon in the taskbar(bottom of screen)
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
Realtek AC
Sep 14, 2011 | Intel DG31PR Motherboard
I have Windows 7 Home Premium. Whan I attempt to play a DVD movie I'm not getting any audio, only the picture
1. you may need updated drivers for your External device.2.
2. You may run the device with the drivers for the previos version of Windows ( such as Vista and or XP.
3.Check the "mixer" bottom right to see if you have the device muted.
4. check also to see if you have the sound card associated with the dvd device.
5. check the "Device manager to see if there is a conflict or if drive are to be update. Device manager located in the "control panel" under "Hardware and sound"
6. check also the properties of the sound card also located in the control panel > under "Manage sound devices" do a test of the sound card if you hear sound your sound card is OK.You next step is to associate the sound card to the device. the USB go directly to the CPU buss so it should be to direct to sound unless there is a disconnect.
Jul 23, 2011 | Gear Head 8XDVDEXT DVD External Slim...
Problem(s): No sound from CD/DVD player, webpages like YouTube, etc. On board sounds still work. Volume, Audio, and Voice tabs under Sounds and Audio Devices are grayed out (unselectable). I've tried...
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select no _ for your specific area
hope this helps
Dec 13, 2010 | MSI KM4AM-L VIA KM400A CHIPSET ULTRA...
I have a new HP - Pavilion dv7-3112sa Refurbished Laptop. The Disk drive is not playing DVDs or CD ROMs. It will play audio CDs fine but when I put in a DVD or CD ROM it just buzzes but does nothing.
It sounds like the drive may be bad. You may want to try getting any updates that may be available from the manufacturer. Also if it does not work you could try reinstalling the drive.
To do this go to start > right click on my computer or computer > select properties > click on the hardware tab > then select device manager > within the device manager look for DVD/CD-ROM drives > click the plus symbol on left > double click the cd dvd drive > this will open the dvd properties within here click the Driver tab on the top of screen > then click uninstall button. > Once uninstall ed restart computer. When the computer is loading back up it will reinstall the dvd drivers.
If this does not resolve the issue contact the PC manufacturer.
Oct 21, 2010 | Computers & Internet
Yes sound problem pls helo me now
From the Taskbar located at the bottom of your computer click once on the "Volume" icon.
Uncheck the "Mute" box. If this does not resolve the issue, proceed to step 3.
Right click on the "Volume" icon.
Select "Open Volume Control."
Uncheck all of the boxes next to "Mute" in the Master Volume, Wave, SW Synth (short for synthesizer), CD Volume, Mic Volume, Line Volume and PC Beep selections. If this does not resolve your sound issue, proceed to step 6.
Right click on the "Volume Control" icon.
5
Select "Sounds and Audio Devices Properties."
Under the "Volume" tab, slide the "Device Volume" indicator to High.
6
Under the "Speaker Settings," click on "Speaker Volume."
Slide the "Left" and "Right" volume indicators to "High."
7
Click "OK." If this does not fix your sound issue, proceed to step 8.
8
Go to the "Hardware" tab and select the "Driver" tab.
9
Make sure you are connected to the Internet and then, Click on "Update Driver."
10
After the driver has been updated, Click "OK."
11
Exit.
Thanks.
Oct 10, 2010 | Computers & Internet
I have the Netbook and just bought an external DVD so I can watch movies on my flight to England.... Movies play fine, but there is no sound!
Control Panel -> System -> Hardware tab -> Device Manager
Click [+] next to DVD/CD-ROM drives, double-click the drive in question.
In Properties tab, make sure the box is ticked next to
Enable Digital CD-Audio for this Device
Hopefully you'll have sound after this.
Apr 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
Audio CD sound Prob
Various conditions may cause this problem. To troubleshoot, check the following:Microsoft Volume Control or your mixer program mute options and volume sliders.
Connect headphones to the stereo phone jack on your CD-ROM drive’s front panel; adjust the volume control settings on the drive. If there is sound from your headphones, check the CD audio cable connection from the CD-ROM drive to the audio card.
Ensure the speakers are properly connected to the audio card’s output connector.
Joystick port is not working
The audio card joystick port conflicts with another joystick port in the system. Disable the audio card joystick port, and use the system’s joystick port.
The joystick drivers, MSJSTICK.DRV and VJOYD.VXD, may not be installed. Uninstall the joystick, then reinstall to load the drivers. The drivers should come with the driver CD or floppy diskette with your sound card.
Computer hangs or restarts during installation
A hardware conflict may cause the computer to hang or restart during the installation procedure. Check the following to resolve the conflict:
A hardware conflict with another device in your system.
Previously installed sound card hardware or software needs to be removed.
The audio card is not seated in the slot properly.
PCI bus mastering devices may be interfering with the operation of the audio card. Temporarily remove non-essential PCI bus mastering devices.
Resolving hardware conflicts
Hardware conflicts occur when two or more devices contend for the same resources. Conflicts between your audio card and another device may occur regarding the I/O address, IRQ line, or DMA channel:
Right-click the My Computer icon on your desktop, and select Properties. The System Properties dialog appears.
Click the Device Manager tab. In the Device Manager, a plus sign(+) represents an expandable list of items. A minus sign (-) represents an expanded list. A circled exclamation mark denotes a conflict.
Double-click Sound, video, game controllers. A list of multimedia devices appears.
Select your audio card.
Choose the Propertis button.
Click the Resources tab.
Uncheck the Use automatic settings option.
Change "Settings based on:" if alternate settings are available.
Determine the conflict by reviewing the "Conflicting device list".
Select the conflicting item in the "Resource Settings" list.
Click the Change Settings button.
Use the mouse to select a new setting.
Select OK to close each of the properties windows, and restart your computer.
Audio card is not automatically detected
To manually configure your audio card for Windows 95/98:
Click "Start" on the taskbar, and select Settings from the Start menu.
Select Control Panel. The Control Panel group appears.
Double-click the Add New Hardware icon. The Add New Hardware Wizard dialog appears.
Select Next to continue.
Choose Yes to have Windows search for new hardware, then select Next
Select Finish, and follow the prompts to complete the new hardware installation.
CD does not automatically run when you insert it in the drive
To enable the "Audio insert notification" feature:
Click the Device Manager tab. A list of devices appears.
Double-click CD-ROM, and select your CD-ROM drive.
Choose the Properties button. The CD-ROM drive properties dialog appears.
Choose the Settings tab.
Click the "Auto insert notification" option to enable.
Select OK until all Properties dialogs are closed, and restart Windows for the changes to take effect.
No sound is heard from speakers
Verify the following:
Check the Microsoft Volume Control or the Audio Mixer Program mute options and volume sliders.
Check the volume control and power connection of the speakers, if they are amplified. (Refer to the speakers documentation for detailed information).
Ensure a hardware conflict does not exist between your audio card and another device in your system.
PCI bus mastering devices may be interfering with the operation of the audio card. Temporarily remove non-essential PCI bus mastering devices. If the device is a display card, upgrade the display card drivers, or set the card to the default Windows VGA mode.
If you are experiencing no sound only during audio CD playback, see "No sound is heard from audio (music) CDs" above.
Static sounds are heard in wave files
Check to see if the static sounds are heard in all wave files. If the difficulty occurs only with certain games, refer to the software manufacturer’s documentation. To troubleshoot static sounds heard in all wave files:
Try different resource settings for the audio card, or set the card to use low DMA.
Move the audio card to another PCI slot. Feedback from the power supply or another device may be responsible.
Oct 19, 2008 | Computers & Internet
Creative Labs CT4870 - sound from DVD drive, not from internal or CD drive
Go to my computer. Right click on your CD-ROM. Choose "Properties". Choose the hardware tab. Again hit the properties button and again the properties tab. Click on "Enable digital CD Audio for this CD-ROM device" and make sure there is a check mark in the box.
Click OK, then APPLY, then OK, and try play your audio CDs again.
You can use this so you don't need audio cables.
Jan 06, 2008 | Creative Labs CT4870 / CT4780 Sound Card
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
