Question about Panasonic HDC-DX1 DVD Camcorder
I have the SD-1. It stops recording on my 8gb after only 43 min
The camera works great until you add a bigger SDHC card other than the 4gb. Once you add say a 8gb. starts to blink RED on time remaining and just stops at approximately 43 minutes. You then have to press record again to record the entire 8gb SDHC card.
Is there a firmware update for the larger cards? I've also tried to reformat the 8gb in the camera and get the same response.
Any help on this would be greatly appreciated. eric cosh
  • denniscosh Dec 15, 2008
    I finally figured out the answer to this problem with the help of Panasonic and other  SD1 users.
    Here is the basic problem.  The SD1 was only designed to record at the highest setting HD for 43 minutes  continuous, regardless of how large your SDHC card is. There are several solutions to this.
    One is to record on either the HN or HE mode. This of course gives you less MBPS and the quality isn't as good, but most amateurs will never notice the difference.  This way you can record for the full length of your SDHC cards.
    My advise is that if you're recording something really important, i.e. a Catholic wedding, record right up to the time of the actual ceremony and then hit pause, then record again and now you should have enough time (approx 43 minutes) to get you to the Communion at which point you can shot it down and either replace your cards, or if you're recording with at least a 8gb care, just hit record again and that will take you to the end of the Ceremony.
    eric
  • Panasonic Master
  • 4,806 Answers
Try formatting the card while its in the camcorder, this might sort the problem for you, also look in the camera's menu to see if its restricted to a certain amount of used memory at once, basically return the camera to factory settings.
I find a lot of camera's don't like certain SD cards anyway even if the camera says it supports them, Sandisc are making just about the best SD cards at the moment
kind regards
Posted on Dec 11, 2008
  • Lee Hodgson
    Lee Hodgson Dec 11, 2008
    Sorry i see you have already formatted the card while in the camera, do the factory reset and try again, if the problem still persists then the camera doesn't support 8GB, go to panasonics support website to see if they have released a firmware update that supports 8GB, if they haven't your stuck with 4GB for the moment
  • Lee Hodgson
    Hi there, her is the info you need
    Cards that you can use with this unit Panasonic HDC-DX1
    Motion pictures cannot be recorded on an SD card with this unit.
    For the purposes of these operating instructions, SD Memory Card and SDHC Memory Card are
    referred to as the “SD card”.
    This unit supports SD Memory Cards formatted in FAT12 system and FAT16 system based on SD
    Memory Card Specifications and SDHC Memory Cards formatted in FAT32 system.
    If you wish to use Memory Cards that are 4 GB, SDHC Memory Cards only can be used.
    4 GB (or more) Memory Cards that do not have the SDHC logo are not based on SD Memory Card
    Specifications.
    Use this unit to format SD cards. If an SD card is formatted on other products (such as a computer),
    the time spent for recording may become longer and you may not be able to use the SD card. (l 85)
    (Do not format it on a PC etc.)
    A MultiMediaCard cannot be used on this unit.
    Card type SD Memory Card SDHC Memory Card
    Capacity 8 MB, 16 MB, 32 MB, 64 MB,
    128 MB, 256 MB, 512 MB,
    1 GB, 2 GB
    4 GB
    kind regards
    Sergeant:
  • 306 Answers
The SD1 comes with a 4GB SDHC card. However, I don't know if it will use the 8GB cards. Reports on the SD150 say it will use the higher capacity cards but stops recording at 4GB. One would think that Panasonic designed the SD1 to match up with the 32GB limit on SDHC...but who knows?
With an 8GB SD card allowing only 80 minutes of 13Mbps AVCHD, I doubt one could record all day. But, it would probably suffice for most vacation videos. I suspect that we will see many people opt for the 6 Mbps because it will give very good resolution and long record times. That would basically double the record time for an 8GB card to 160 minutes.
  • Panasonic Master
  • 19,396 Answers
This camera is not supposed to support more than 4GB, and no firmware is available for 8GB
  • Ginko
    Ginko Dec 11, 2008
    It is not a matter of formatting, on this camera specs is written that the model supports up to two GB, that means that on certain cameras , up to 4 GB are supported, SD cards over 4 GB use a different technology, and will not work on this camera, no firmware upgrade to support bigger SD cards had ever been released.
My Camera is not reading my SD card and is a brand new one "Card Error" message ?
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Mar 25, 2011 | Cameras
Bought a new sony sd/sdhc memory card 8gb and it will not format/load for my camera--what do I need to do?
Feb 23, 2011 | Samsung Digimax D53 Digital Camera
I can't seem to format my C875 easyshare with a 4gb kodak memory card. Help!
Feb 19, 2011 | Kodak EasyShare C875 Digital Camera
Cannot format 8gb sandisk sd card
Feb 04, 2011 | HP Photosmart 735 Digital Camera
My camera won't work with the SD card.
Feb 04, 2011 | Cameras
Tried to format new memory card for Ricoh Caplio R2. Camera just shuts down, no error messages etc. Card is an SD HC high speed 8 GB one.
Jan 27, 2011 | Ricoh Caplio R2 Digital Camera
I have an Exilim EX Z500 digital cam, the recent Micro SD that inserted to it have only 256MB that's too short.. so I bought a 4GB Micro SD card.. but why can't my EX Z500 accept a 4GB?
The problem is that your camera will only read SD cards, not SDHC cards, I checked its specification. You found your 256Mb card too small and bought a replacement, not noticing that it was SDHC. The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD. Cards over 8Gb have to be SDHC. 4Gb cards can be either SD or SDHC, but are almost always SDHC because they're cheaper. I'm willing to bet that the 4Gb card you got is actually SDHC because 4Gb SD cards are so rare that I've even seen a guru on this site claim they don't exist. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it.
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it. (If it does, it probably means that they made a 4Gb card, but there were some error locations and so they disabled half of it and packaged it as a cheap-brand 2Gb.)
Jan 21, 2011 | Casio Exilim EX-Z500 Digital Camera
Sd card not recognizable
I read the following spec for your camera: Recording Media Internal Flash Memory 64MB Video/Image
SD/SDHC Up To 32GB Video/Image
So, I think that an 8 GB SD card should work.
Try another capacity and brand to make it work.
Jul 12, 2010 | Kingston 4GB Secure Digital High Capacity...
Inserting either a 4Gb or 8Gb SD card results in a "Memory Card Error".
The S4 accepts SD and MMC cards. SD cards max out at 2Gb. The 4Gb and 8Gb cards are actually SDHC (Secure Digital High Capacity) cards, not SD cards, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
Dec 27, 2009 | Pentax Optio S4 Digital Camera
I have a vivitar video recorder model no 840 xhd. can you tell me what memory card to get for it. the hand book says I need a standard SD card upto 32GB.but most card have other numbers or letters after...
It can use MMC cards or SD cards or SDHC cards up to 8GB in size.
SD cards top out at 2GB. 4GB and larger cards are technically SDHC (Secure Digital High Capacity) cards.
Dec 17, 2009 | Vivitar DVR 840XHD Digital Video Recorder
Panasonic HDC-DX1 DVD Camcorder Logo
447 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
