Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
I have a world book 1tb hd with mionet. connec to network
Mionet is working says im online but the hd is offline, dynex router, widows xp.
  • bencotton Jan 10, 2009
    WD HD on the network, powered up, but MIONet says that it is offline.
Hard drive is hanging up continually have to p[lug in and unplug in order for me to transfer everything off of it!
Posted on Dec 24, 2008
    Problem Solver:
  • 17 Answers
If MioNet says the drive is offline, the drive either:
1. Does not have Internet access, but has local network access
2. Needs to be re-attached to the MioNet account
3. Needs a firmware update
To check if the device has Internet access you can attempt to do a firmware update. If it does not detect new firmware, the device cannot access the Internet.
To re-attach the My Book World to your MioNet account:
A. Login to the Shared Storage Manager
B. Go to the General Setup tab. Login with your MioNet username and Password (if you change your MioNet password, use your old password)
C. Click the WD Anywhere Access Settings link
D. Select Stop, then select Reset
E. Go to MioNet Manage (double-click the MioNet icon in the tray), then go to File > Scan for Cameras and New Devices
F. Give your My Book World a new name (alternatively you can remove the drive before scanning for cameras and new devices)
If your firmware is lower than 02.00.19, you can perform a firmware update. First you must set the Security settings for each folder under File Sharing to None, then set the WD Anywhere Access settings to Off. The firmware update page is under the General Setup tab.
Posted on Jun 01, 2009
Mybookworld is not visible in mionet
Give up. I've had Mionet for over a year, and I have not been able to reliably access it remotely using Mionet, even on a 32-bit system. Mionet is finally advertising a 64-bit system, yet it still doesn't work--the drive shows "offline". Advice from Mionet in my many attempts to get support says to reset the hard drive--kinda hard when you're away on vacation. Even using Mionet web doesn't work reliably. In the end, the many, many chances I've given Mionet and Western Digital support to fix this have only resulted in frustration, delays, and ineffective advice. Overall, Western Digital has failed to produce a product that's remotely accessible, and you're left with a local-access-only outboard hard drive.
Oct 28, 2009 | Western Digital My Book World Edition 1TB...
Can't map network drive WD Blue ring edition
The Failed Mount issue is usually caused by Internet Security settings. The most common way to resolve it is to add the following files/ports to the exceptions list of your firewall(s) -- in some cases you will need to add it to the Windows Firewall, even if you have another Firewall installed as well:
MioNet.exe (C:\Program Files\MioNet\jvm\bin\MioNet.exe)
MioNetManager.exe (C:\Program Files\MioNet\MioNetManager.exe)
ServiceStatusGui.exe (C:\Program Files\MioNet\ServiceStatusGui.exe)
These ports are also required for MioNet to create a drive-letter for remote drives:
TCP In/Out 443
TCP In/Out 445
Aug 21, 2009 | Western Digital My Book World Edition 1TB...
Cant connect my 1TB WD world edition to my linksys router
Your My Book World should not be formatted or you will lose all ability to access it through the Network -- it will simply become a hard-drive at that point. There is software installed on the hard-drives that communicate with your Router in order to obtain an IP and be available as a Network Drive. If the drive and the Router are communicating, you should see an IP in the DHCP list of your Router. It is possible that the My Book World is not setup for DHCP, so if it is placed in an alternate environment with incompatible static IPs, it won't be able to access the Internet or be available locally. You can try a hardware reset on the drive and see if it pops up in your Router's DHCP/Client list, at which point it should also appear locally and over MioNet (MioNet will need to register the device to an account before it will appear in MioNet, but it must detect the drive locally in order to attach).
1. Turn off My Book World
2. Identify the reset button on the back of My Book World
3. Depress the reset button while restarting My Book World
4. Keep the reset button depressed for about 10 seconds after you see blue lights on My Book World
Jul 02, 2009 | Western Digital 500GB My Book World...
I can't access my drive through mionet. My son accidently unplugged the world book and I can't access it ever since. Should I reinstall the mionet. I can't remember if there were any installation CD that...
Once the My Book World has been plugged back in, it will request a new IP from the Router. If the drive was unplugged accidentally, the ethernet cable may have also been knocked loose: make sure all cables are attached to the Router and the My Book World.
If your drive is still not appearing properly in MioNet, you can do a Hardware and Software reset on the drive. It will not affect your data, and it will allow you to re-attach the drive to your MioNet account. You do not need to reinstall MioNet to do this.\
You should now be able to sign in to the Shared Storage Manager as admin/123456.
5. Please open your web browsers and enter (without the quotes) "http://<IP address of My Book World>" or "http://mybookworld" in the address bar. The Shared Storage Manager web page will appear.
6. Once you have accessed the Western Digital Shared Storage Manager please select "General Setup" then choose "WD Anywhere Access settings." Use the default username of "admin" and default password of "123456" (without the quotes). On the following page you will have three buttons to select, please click on the "Reset" button. This will return the MioNet software on My Book World to default settings.
7. From within the MioNet Client, go to File > Remove Computer. Locate the My Book World (WDStorage, MyBookWorld, or whatever you named it) and remove it.
8. If you do not see a new window from MioNet informing you that you have a storage device available, "Scan for Cameras and New Devices…" to detect the unit.
Jun 11, 2009 | Western Digital My Book World Edition 1TB...
MioNet does not see my WD MBWE (1T)
I do have a MBWE but have been using the explorer and not Mionet, so just a suggestion:
1. I would uninstall Mionet completely, restart the pc and then reinstall Mionet.
2. I would also try assigning a static IP for the MBWE; this can be set through your router's setup page;
If you're following anyone of these two and want to post response please do so, and good luck !!!
Jan 09, 2009 | Western Digital My Book World Edition 1TB...
Problems with Western Digital My Book World Edition
I have the same drive. It works great with windows XP but with Windows vista has difficulty seeing this type of drive and keeping the connection once it is established. Take it back if you have windows vista and then search for which 1TB drives work well with windows vista. It really has problems with windows vista 64bit. I was able to finally see the drive when I was using photoshop file/browse/network... then I dragged the shortcut Icon to my desktop and access the drive that way from that point on. Mine stopped completely tonight... I think the power cord went bad or something.
Jan 04, 2009 | Western Digital My Book World Edition 1TB...
Mionet application doesn't show files in subfolders of shared folders
I believe you have a choice of using either the web interface or the desktop version of Mionet when you are on the same network (LAN), and as you mentioned both of you have no problem when you are on the same network as the NAS drive (MBWE) is.
When you are out of the local network where your NAS drive is, the only choice you would have is the web interface of Mionet. Eventhough you may have installed the desktop version of Mionet tool on a remote PC, I don't think you can access through that desktop tool. Sorry !!!
Oct 30, 2008 | Western Digital My Book World Edition 1TB...
Offline mybookworld (WD)
I've never even heard of mionet till now , went to the site , I can see it's a webcam device with a hard drive ?
reguardless of all that , tripple check the hard drive of the mionet webcam device as if you would a regular hard drive , of course remember if your ibook see it , it could be because the drive is somehow compatable with ibook , it could mean the hard drive is formated in a manor compatable with ibook , aka a mac type partition created by the mionet program , either way diagnostic proceedures apply , this all sure smells like a cheep webcam scam to me , but thats a little unprofessional of me to say that , lets just start with the basics , is the drive partitioned by any special sofware , is it a MAC partition , is it a DOS partition , is it an Non Dos parition
honestly don't blame the hard drive if you don't know what altered it.
lets dig in slowly , lets have a look at the parition table.
shalom
Jul 05, 2008 | Western Digital 500GB My Book World...
My WD 500GB My book (world edition) keeps going offline
Is your drive warm/hot like mine was/is ?
Mine dropped offline 2 or 3 times a week.
Put a small fan blowing on it.... been up for two weeks now.
Sep 30, 2007 | Western Digital 500GB My Book World...
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
2,139 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
