Question about Acer Aspire 9300 Notebook
My Monitor turns off randomly
Hi i was wondering if any one could help me work out why my screen just turns off and says there is no input?
I got a GTX 280 GPU which is set to stock speeds. I ony set up my rig a few months ago with a cosmos S case and a srtiker II extream MOBO?
Dose any one have a clue whats going on? over heating/faulty gpu?
Your computer is going to sleep, its under the energy saver settings in display on control panel. Change this if you don't want it to enter sleep mode.
Posted on Feb 11, 2009
  • 413 Answers
First check to make sure your drivers are up to date and the card is seated properly. Then If your graphics card is still under warranty take it back and get a new one. For some reason it is cutting out the signal to the monitor.
Posted on Dec 29, 2008
Hi, i was wondering if anybody could help. my acer laptop was not being used for lontime due to a broken screen. Now that i tried to use it from the external screen, it gives me an error message . Input...
turn off the laptop and then plug in the external monitor, and make sure you update the driver. It should work. My only other suggestion is to log in and access the device manager as administrator. I'm sorry I don't have more answers for you.
Mar 13, 2014 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Optiplex 745 monitor goes to sleep randomly
In regards to your issue with your monitor: For a monitor to display "no signal input" there is likely a problem with the monitor making a connection to your input source (yes I know duh). First and easiest thing to fix this is to check your cables going between your computer and monitor, if your computer and monitor start out working and then fail to communicate, there is a good chance that the cable might be coming loose just enough that the connection fails. I might suggest that if you have, as you say another computer, that you try swapping monitors to check where the problem lies.
Hope this helps some.
Aug 12, 2013 | Dell OPTIPLEX 745 PC Desktop
My computer screen randomly turned white and won't
Your screen might be going bad. Try plugging an another monitor and see if it works or has the same problem. If the other monitor works, it's definitely your screen is bad. If the other monitor fails and does the same thing, then the video card in the computer is bad.
Mar 28, 2012 | HP Computers & Internet
Montior goes black i turn off the monitor and turn it back on i can do about 2 things and screen goes black again repeat this as many times as i want. Gateway FHX2300 monitor
My monitor has been switching connections on me randomly. Hit the menu button. The one to the left of the power butter when facing the screen. Hit the left arrow twice then hit the menu button again. This will open up the screen where you can choose one of three inputs. I'm going to assume that it is on the incorrect input so use the arrow keys highlight what input you are using and the hit menu button again and your screen should return to normal. Mine only does this randomly when it goes into screen saver, hibernate or sleep. I don't know how to permanently get it to stop doing it though.
Aug 23, 2010 | Gateway FHX2300 LCD TV
Hi, my screen just randomly turned pink im wonderi...
Check all the pins on the VGA cable, also try it on another PC to make sure it is not the PC that is causing the problem. Hopefully it will not be bad lamps.
May 20, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
DVI connection fault
I had the same problem, you must call Viewsonic to change your screen. The DVI input on the screen is dead.
Jul 08, 2008 | ViewSonic VX2255 Monitor
Monitor Randomly Turns Black
I have exactly the same problem with my Benq FP71E+ ..
What i found is a temp fix is this :
When monitor dims and goes black i turn it off , hit the bottom left side (near the BENQ logo) turn it on again and it works ..
This works every time for me . But after a while it switches off again , could be 5 minutes could be 5 hours . Its random
May 02, 2008 | BenQ FP71E 17" LCD Monitor
VGA input not displaying
Hi, insert the monitor driver of screen on swicth reinstall driver in order to detect screen.
Jan 17, 2008 | Samsung SyncMaster 713BM 17" LCD Monitor
Acer Aspire 9300 Notebook Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
