Question about Gateway M6307 Notebook
Gateway M6340U hard drive problem
When I start the laptop, randomly, it freezes in the start up screen. When I press F10 the computes says that it has no TPM or TPM has problems. When the computer is freezed when I press f10, the laptop seems to be trying to recognize de hard drive. When the computer passes the startup, when I'm in windows vista, sometimes the laptop doesn't respond and after a time it says that it has a problem with the intel matrix storage drive.
  • 64 Answers
It sound like memory problem. Change the memory and test if the problem is solved.
Posted on Dec 12, 2008
Www.fixya.com/support/t1579058-reset laptop its factory default
1.restart the computer
2.when you see the Vaio logo on the screen press and hold the function key + f10 (fn+F10) to load the vaio recovery center
3.in the editboot option screen, press enter
4.it will load the Vaio Recovery Center
5.click restore c: drive from vaio recovery center
6.follow on-screen instruction. process may take 45mins to 1hour to complete with random restarts. hope this helps.
Mar 15, 2014 | Sony VAIO VGN-UX280P Notebook
Boot screen drive dvd key
Did you made any harware changes to your laptop lately? I suggest you press f2 or F12 immediately at the startup. This will open up the BIOS configuration. Navigate to boot devie priority and locate your hard drive. Put it on the 1st priority and hit F10 to save changes and exit. Once the computer restarts the sustem will try to boot from the Hard drive..
Regards
David
Sep 18, 2013 | Acer Gateway 15.6" Laptop PC NV56R14U-US...
Hi i have a gateway mt6705, trying to restore to new. push the on button and gateway comes across the screen. then goes to a blank screen with a blinking line in top left corner thats it. cant use cd to...
The way to restore Gateways is to hold down the ALT Key andrepeatedly hitting f10 then it should bring you to a boot sequence screen thenchoose the HDD and then hold down ALT and repeatedly hit f10 again that shouldprompt the restore feature for gateway. If that doesn't work,the only way to doit is to boot into windows and run the Recovery program.
ALL DATA WILL BE ERASEDON YOUR HARD DRIVE IF YOU PROCEED. YOU WILL NEED TO ENSURE THAT YOU HAVE THEPOWER ADAPTER PLUGGED IN. DO NOT SWITCH OFF OR RESTART YOUR COMPUTER DURINGTHIS PROCESS.
Hope this helps,
Feb 26, 2011 | Gateway MT6705 Notebook
Laptop freezes at bootup
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold and hold thet key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Dec 11, 2010 | Acer Aspire 3000 Notebook
My Gateway GT5404 Freezes
1. your hard drive may be at what is called the "end - of - life"
2. I suggest that you try to backup important files if you can get into the pc screen again.
3. PC freezing is sometimes due to a failing power supply, a failing hard drive, and or a depleted CMOS battery.
May 15, 2010 | Gateway GT5404 PC Desktop
Computer startup problems
Likely the hard drive is bad. I would suggest testing the hard drive or having a technician test the hard drive, replace it if it is bad and restore your operating system
Jul 08, 2009 | Gateway M-6750 PC Notebook
Gateway laptop computer freezes during system recovery
Turn the computer off, then start it back up and press the f2 key repeatedly til a blue screen called the BIOS screen comes up, press the right arrow on your keyboard so it goes to the advanced tab. go down to speedstop and disable it, press f10 to save changes and start computer over. Now it will work no freezing :)
May 31, 2009 | Gateway MX8711 Notebook
Laptop not booting up after XP install
Can you press f10 to get to the HP recovery screens?
May 28, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I have a gateway laptop model MA7and it wont start up.
It is not a hard drive issue. If hard drive is a problem system wont boot till motherboard processor. Try to reinstall your OS. It will fix your issue.
May 14, 2009 | Gateway (M520HD80G) Hard Drive
My recovery CD (gateway 7330gz PC) are no working
I have the same problem with my Gateway 7330gz. My laptop got infected with spywares and it was so annoyed that I have to think about recover the system. So I did it with Gateway Recovery software. I chose the recovery option (press F11 when boot up)from hard drive since my dvd drive was broken. It went well but when it boots up again and Windows XP says detecting and installing the drivers and such, it was frozen haft way through. I turned off power many times to reboot but it kept freezing at that point. I search Internet for help and seen this post. Wonderful! I press F2 to go to BIOS setup screen, use right arrow key to move to Advance menu option. There I use down arrow key to select SpeedStep, hit (-) key to disable it. Then F10 to save and exit, hit enter for OK button. The system boots again but this time it was no longer freezing, the setup process went through ok and continues...I am so happy and type this message so it might help others with the same issue. Thanks
May 23, 2008 | Gateway 7330GZ Notebook
Gateway M6307 Notebook Logo
399 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
