Question about Dryers
Hot leg of power supply cord melted
What might have caused this?
dare we risk simply buying another cord and resume operating dryer?
  • 1,543 Answers
This is almost positively caused by a poor electrical connection. If the connections at the cord to the dryer are good and tight, check the receptacle that the cord plugs into. Turn the breaker off, remove cover or receptacle, and tighten all connections. If necessary, replace the dryer receptacle along with installing a new cord.
Posted on Dec 11, 2008
Kenwood KCD1W tumble dryer not heating up replaced element and all three stats still not getting hot ?
Check main cable connections and power from main circuit. Possible one leg is open because of circuit breaker defective, open circuit from breaker through connection on the back of the drier. Sometimes the connector internal at the power connection will fail (see second image).
Check Thermo-fuse. If this thermo-fuse fails it will need to be replaced. (see first image).
If only one leg that supplies 120 volts is powered then motor and controls can operate. the heater elements are the part of the dryer that requires the other leg for the 240.
Hope this helps?
Nov 29, 2016 | Dryers
Will not heat up
Beyond checking for a blown fuse or tripped circuit breaker (find the dryer circuit breaker and turn it off, then back on) I would suggest having a qualified Service Technician look at your dryer. Your dryer operates on 240VAC. One leg of power (L-1, 120VAC) operates the motor and timer. The second leg (L-2, 120VAC) ends up at one side of your heating element while L-1 is on the other side. L-2 goes from your power cord to the juction block, to the motor centrifugal switch and finally to one connection of the heater. L-1 goes from your power cord to the junction block, then through the operationg thermostat and the high limit thermoastat, then possibly a thermal fuse and finally to the other connection on the heating element. L-1 and L-2 together supply 240VAC. No heat at all can be a fault with ANY of the components mentioned.
Nov 18, 2010 | Hotpoint NLL113EYWO Electric Dryer
Dryer is completely dead. Socket and power cord are fine, and insides of dryer are clean.
unplug the unit,then carefully open the power cord connection access panel in the rear area of the dryer,sometimes the incoming power connections of one or more will burn off and disconnect themselves from the terminals,if its this problem,it sound like the "N"neutral center connection,because if either power phase wire burns off you may still have the timer or drum operate because each is connected to one hot leg
Apr 29, 2010 | Maytag PYE2300AY Electric Dryer
I put a new power cord on my Maytag dryer. Now it isn't heating. Could I have installed the power cord incorrectly to cause this?
You should have two hots (one black - one red)(110 VAC each = 220) plus a neutral (white)(which when coupled inside with one of the legs will give you 110 VAC for timer and light) and a ground (green) which should be connected to the frame of the machine. Is that what you have?
Mar 24, 2010 | Dryers
I turned the dryer on, it sizzled and blew, bright flash from area of terminal block, the hot wire, black, is fried, burnt, it may have melted a pair of wires going up into control panel. Dryer, of course,...
I am more concerned about the wire from your machine back to the panel. You might want to get a licensed electrician to look at this. The risk is burning your home down. Please get it checked. If the electrician says the wire is undamaged, you can fix this yourself.
Why did it dead short? Someone dropped a paper clip across the two hot wires (220) or between the hot and ground (120)?
Thanks for your interest in FixYa.com
Jan 20, 2010 | Dryers
Roper drier model rex5634kqo turns but will not heat
Unplug the dryer and remove the rear panel. The element and safety's are on the right hand side. Check each component for continuity. any component that is ope will be the problem. Now here is your basic repair manual for this machine: HERE
I have compiled some repair photos: HERE
Jan 07, 2010 | Dryers
Kenmore dryer dryer model 110.67042600. Won't start. Has power
Check your receptacle to make sure that you have 220v, with 110v on each of 2 legs. The dryer operates some things off of one hot lead, and some off of the other. Your motor circuit sounds like it's on the other.
If the receptacle checks good, check your wiring connections at the terminal strip in the back of the machine wher the cord connects.
Best regards,
--W/D--
Aug 20, 2009 | Dryers
Not drying clothes completely
Check for a build up of lint in the exhaust duct, an excessive build up will block air flow.
Also 220VAC electric dryers use different legs of the electrical supply. (two 110VAC legs tied via a common neutral make 220 VAC) One 110VAC leg runs the motor and controls while the other supplies power to the heater.
It is possible that one side of the 220VAC has a blown fuse and is not supplying power to the heater element.
Other possibilities:
Blown out heater - requires replacement
There is a safety switch attached to the shaft of the motor. THis switch relys on centrifical force to close and is intened to kill the power to the heater if the motor and its attached blower stop turning.
If the motor is not turning fast enough of the switch is worn then it is possible that power to the heater circuit is not being completed. It doesn't take must of a speed reduction to cause a problem. Lint build up on the drum bearings can cause enough drag to slow the drum slightly. Combined with a worn/dirty switch and the switch fails to operate.
Finally there is a blower attached to the motor shaft. The blower is made of plastic and somtimes the blower comes loose on the shaft. Usually you hear a rattling sound or sounds after the dryer drum stops as the loose spinning blower spins to a stop. ( A tight blower stops with the dryer drum) A loose blower doesn't move enough air and causes your dryer to run longer.
Jul 19, 2009 | Estate Dryers
Problem with battery or power cord?
it could be a short in the power cord or a lose dc jack in the back. what model acer is this for as power packs for them dont cost to bad.
Nov 29, 2008 | Acer (56.04145.901) (5604145901) Power...
Dryer Cord melted....
The power cord overheats and melts due to a failing power cord receptacle (the contacts loosen over time). To correct this problem, the receptacle and power cord should be replaced.
Jun 18, 2008 | Dryers
Dryers Logo
146 people viewed this question
Top Dryers Experts
