Question about Vtech Whiz Kid Learning System by
Touch screen not working
My whizkid learning system turns on, and I hear the woman telling me to touch the screen to play a game, but when I touch the screen, nothing happens.
  • kristeehart Feb 27, 2009
    whiz kid turns on and tells us about the activity and then when we click on the item it says goodbye see ya later and shuts off
Leapster restarts select cartridge game
Try this
Ensure that a cartridge is not inserted
Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.When the LEAPSTER menu screen appears, press the A button.Touch each of the crosshairs that appear with the stylus, Restart unit
Aug 13, 2014 | LeapFrog Leapster 2 Learning System
How do you calibrate the leapster learning game system?
  • Follow these steps to calibrate your Leapster Learning Game system -
  1. Remove any game and turn the Leapster off.
  2. Turn the unit on.
  3. When the sign in screen appears immediately press and hold down "home"(house), "hint"(question mark), and "B" buttons together for 4 seconds.
  4. Now you will see a few options.
  5. Press the "A" button for the touch calibration option.
  6. Now just touch the stylus on the cross-hairs and it will be calibrated.
  7. Now you want to restart the unit.
  8. Redo the steps if this should not work the first time.
Regards, Tony
May 19, 2011 | Toys
My ps3 is the one that plays both ps3 and ps2 games and it says cant start cannot find correct hard drive
1. turn off system completely (this means the switch on the back)
2. hold touch sensitive reset button down till you hear 3 beeps, than let go.
3. hold down touch sensitive reset button until you hear 2 beeps and a double beep.
4. follow on screen directions, choose what option you want (i pick 3, it
seems to work the best)
5. follow on screen directions
http://www.youtube.com/watch?v=c0e-oO6l9kk
Mar 09, 2011 | Sony Playstation 3 (PS3) Console
Ps3 games will not play ps3 games it will play ps2 games and movies whats wrong with the system?
Welcome to Fixya
Try the troubleshooting procedure below:
Step 1 - Turn off the playstation 3 by holding the power button on the front of the unit till the power light is red.
Step 2 - Touch and hold the power button, you will hear the first beep, meaning the playstation 3 is powering on. Continue to hold the power button and after about 5 seconds, you will hear a second beep, indicating the video reset. Continue to hold the power button and after about 5 seconds, you will hear a third beep and the system will power off (power light is red).
Step 3 - Touch and hold the power button, you will hear the first beep, again for the playstation 3 to power on. Continue to hold the power button and after about 5 seconds, you will hear a second beep for video reset. Continue to hold the power button and after about another 5 seconds you will hear a quick double beep. At this point release the power button. if you succeeded in activating the safe mode, you will see a message on the screen saying 'connect the controller using a USB cable and then press the PS button.
Step 4 - Perform the safe mode options in the following order until one of the options works for you. If one option works, do not continue onto the other options.
Restore Default Settings
Restore File System
Rebuild Data Base
Restore PS3 System etc...
Thank you
Dec 27, 2010 | Sony Playstation 3 (PS3) Console
TOUCH SCREEN IS NOT WORKING
We have the same problem and our leapster is only 2 days old.Do Touch Screen Calibration,it should help.I do it everytime for my son when he wants to play and it does help...But once u turn leapster off,u'll have to calibrate it again next time...
Just hold down hint button while turning on.When the Leapster menu screen appears,press the A button.Touch each of the crosshairs that appear with the stylus.restart unit. ..That what we do everytime.
Oct 24, 2009 | LeapFrog Leapster 2 Learning System
Game console is frozen after you turn on power and it goes to the sign in page
My son had the same problem. Remove the game cartridge, while holding down the button with the "?" turn the unit on. Then the screen should tell you to press the "A" to calibrate the stylus. Finish the calibration by touching the crosshair when it appears. After I did this everything was fine. Good luck
May 19, 2009 | LeapFrog Leapster 2 Learning System
My daughter has a Leapster 2 (pink) hand held game. We can not get it to sign into her name, so she can not play games. Can you help?
Remove the game cartridge, while holding down the button with the "?" turn the unit on. Then the screen should tell you to press the "A" to calibrate the stylus. Finish the calibration by touching the crosshair when it appears. After I did this everything was fine. Good luck ....thaks to Nicksdad who posted this response to a previous post. Worked for me...try it.
May 16, 2009 | LeapFrog Leapster 2 Learning System
Our brand new leapster2 has froze up at the sign-in stage. It will not bepass to play any games. Could you help?
you need to do pen calibration....call leapfrog and they will tell u how to do it and it should work
Jan 20, 2009 | Leapster Learning System
Touch screen doesn't work
Contact Customer Service they may be able to replace the unit even after warranty 800-701-5327
Jan 02, 2009 | LeapFrog Leapster Learning Game System
Vtech Whiz Kid Learning System by Logo
29 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
Are you a Vtech Toy Expert? Answer questions, earn points and help others
